screen printing
2008-05-26 by scx31114
Hello, i have made a tests with Bungard solder Mask and direct white printing over it with UV hardered INK before solder mask hardering. It works. I have tried it with a 7feet industrial printer. Now i must check, if modifying a epson printer and using this ink, i can reproduce the same result. On the industrial machine, i had the feeling, that the UV curing is a combination of UV and heat curing (70-80 degree). Because i have only access to high resolution piezo printing, i probalby must filter the ink prior using it in order to not obstruse the head. Do your have a idea, how i can build a 5um filter ? The industrial machine had a 300 dbi piezo print head. Further updates are coming as i have resolved this problem. As note, i have access to the ink as 1 Liter refill tetrapack. Chris
