Homebrew PCBs
Ferric Chloride - Alternatives
2008-06-27 by John Michaud
I didn't expect to generate so much attention to Ferric Chloride and with that living in Oregon I've been concerned with the environment so is there a environmentally safe method to etching?
Thanks for all the comments and information,
John
Re: [Homebrew_PCBs] Ferric Chloride - Alternatives
2008-06-27 by DJ Delorie
John Michaud <greyfox1143@...> writes:
I'm switching to CuCl etching for that reason - nothing to throw away,
unless you grow too much etchant.  Even then, you can precipitate out
the copper and recycle it.
http://members.optusnet.com.au/~eseychell/PCB/etching_CuCl/
That's what you need the HCl and H2O2 for.
2008-06-28 by Russell Shaw
Well Geez, i've been etching with the same tank of FeCl for 2 years.
Enviroweenies need not worry because this stuff is inorganic, just
like the naturally occuring lead, uranium, and radiation in the soil.
What's more, one of the bulk uses for FeCl is for treating sewage
to make it more "environment friendly" like.
2008-06-28 by Dylan Smith
I've been using the same batch of FeCl for over a year (and many boards)
too, it does seem to last well.
Someone told me that salt helps rejuvinate FeCl - not being a chemistry
geek I have no idea if this is right or not - is this true or is it BS?
Re: Ferric Chloride - Alternatives
2008-06-28 by Dennis
Hi John,
--- In Homebrew_PCBs@yahoogroups.com, John Michaud <greyfox1143@...>
Most places that recycle hazardous material (like paint and oil) will
also take used ferric chloride.  I've been etching boards for several
years now and still don't have enough to make it worth a trip to a
recycler.
Dennis
2008-06-28 by Leon
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Saturday, June 28, 2008 4:30 PM
Subject: Re: [Homebrew_PCBs] Ferric Chloride - Alternatives
I  doubt it. HCl and H2O2 works - I think that the H2O2 oxidises the ferrous
chloride and cuprous chloride to ferric and cupric chloride, and the HCl
provides additional Cl ions.
Leon
2008-06-28 by Stefan Trethan
Yes, but doesn't that just produce CuCl contaminated with dirty FeCl
(AKA "Stain from Hell")?
ST
>  Leon
2008-06-28 by Leon
Sent: Saturday, June 28, 2008 6:59 PM
Yes, but they are both etchants, so the regeneration works. Do it for long
enough and the FeCl3 will gradually disappear. 8-)
Leon
2008-06-28 by Adam Seychell
It will become environmentally unsafe if you decide to dump your *spent*
etchant in a pond full of aquatic life.
Copper are the toxic atoms here, not the iron ions, chlorides,
persulfates, peroxide. Copper is an essential nutrient in trace amounts
so it ok if soil concentrations are not allowed to get too high. I
forget what the figure is. You should precipitate the salts by adding
lime before sprinkling it on your garden.
Adam
2008-06-29 by Russell Shaw
Leon wrote:
> From: "Dylan Smith" <dyls@...>
Every few weeks when i use it, i top it up with HCl. It's a bubble
etcher, so maybe the air has some kind of regeneration.
2008-06-29 by Leon
Sent: Sunday, June 29, 2008 8:23 AM
I think that would be the case.
I do that with my manual agitation technique, and add a little H2O2 if I
have it.
Leon
2008-07-03 by YD
If you "revigorate" it with a slug of HCl after etching a board or two, over time the Fe will oxidise and settle as insoluble FeO. Then just decant it. That's how I quite unintentionally converted from FeCl to CuCl. Didn't dawn on me until I started looking at the chemistries involved.
Date: Saturday, June 28, 2008, 3:02 PM
To: <Homebrew_PCBs@ yahoogroups. com>
Leon
2008-07-03 by Leon
Sent: Thursday, July 03, 2008 1:12 PM
> Here are a couple of webpages giving a bit more detail on the reactions:
> http://artmondo.net/printworks/articles/ferric.htm
> http://www.p-m-services.co.uk/ferric_chloride.htm
All I could see is that HCl removes the sludge. Adding ammonia precipitates
the iron hydroxide, not HCl.
Leon
