Homebrew PCBs
Homemade inkjet printer test results
2008-07-20 by v_sahin
Hello All,
I completed my homemade inkjet printer. I did some tests and uploaded
under Homebrew_PCBs/files/Epson_inkjet_Volkan. As seen in the pictures
 without any short/open it is possible to use 4mil/4mil (width/space).
This homemade printer has a resolution of 1440x1440 dpi and it is a
flat bed type. Sorry for the quality of the  microscope captured images.
New uploaded files:
Volkan
Re: Homemade inkjet printer test results
2008-07-20 by Steve
Wow....
Steve Greenfield
--- In Homebrew_PCBs@yahoogroups.com, "v_sahin" <v_sahin@...> wrote:
> Hello All,
> New uploaded files:
> Cheers,
> Volkan
2008-07-21 by gsi11135
Fantastic work!
> Hello All,
uploaded
pictures
(width/space).
images.
> New uploaded files:
> Cheers,
> Volkan
2008-07-21 by James Newton
I showed these pictures to a friend who had tried hacking an R220 and
his reply is that it's great, but he doubts that it is possible to get
the registration close enough to do double sided boards. I'm curious if
you have any reply to that.
He uses unmodified inkjets to print transparencies, aligns them as a
set, then uses a vacuum table to hold them on a pre-sensatized board
while exposing under an UV lamp. He says he regularly gets 5 and 5 and
is happy to be able to do double sided.
I think a possible solution is to purchase thinner than normal single
sided stock, etch seperatly, and then bond the two with the backing
together and the copper sides out. No registration problems because the
registration is done after the etch. Someone else had described this
here in more detail.
James.
Re: [Homebrew_PCBs] Re: Homemade inkjet printer test results
2008-07-22 by Volkan Sahin
>the
In the past, I used below method but it requires accurate X/Y positioning and I'll use it for this printer also, it has a starting point accuracy of
~+/-10micron meter.
You need to have reference holes on
printer bed on  center of X-axis, which requires fixed board size or
multiple reference holes. Your board also needs to have pre-drilled
reference holes. Something like below,
              X-axis
*Reference holes
Prepare your image centered at
	reference holes, after printing 1st side flip on X-axis
	and print 2nd side. You can also eliminate requirement of
	centered image by adding offset but centering is easier.
>set, then uses a
>while
Yes he can get
	it, everybody uses this method . Personally I want to avoid stock of
	photosentized boards or photo resist, developer and for me it is double work and it can be as good as your master film but this method is
	proven no doubt about it.
>sided stock, etch
>together
	described this
It is possible, but how to avoid
	air bubbles between layers without vacuum? If you use oven during
	soldering  bubbles can separate glued layers.
Volkan
2008-07-22 by Mike Young
10 micron repeatability is pretty amazing. Just wondering out loud... would
it make sense to mount the printer head on the spindle of a CNC mill?
Either way you do it, I don't see how you can do second and subsequent sides
without multiple registration features for placement and alignment. (It sure
would be nice to just print out 11 layer boards with micro-vias and
plate-throughs. I'd settle for just 7 layers. :-)
Volkan, I missed the mechanical and control details if you posted them. I'm
curious about the Y-axis drive, and the print head control signals and
timing. Were you able to find those on the web?
Mike.
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Monday, July 21, 2008 11:11 PM
Subject: Re: [Homebrew_PCBs] Re: Homemade inkjet printer test results
>the
~+/-10micron meter.
              X-axis
*Reference holes
>set, then uses a
>while
Yes he can get
>sided stock, etch
>together
described this
Volkan
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
>10 micron repeatability is pretty amazing. Just wondering out loud... >would it make sense to mount the printer head on the spindle of a CNC mill?
>sides without multiple registration features for placement and >alignment. (It sure would be nice to just print out 11 layer boards >with micro-vias and plate-throughs. I'd settle for just 7 layers. :-)
I�m using X-axis of Epson printer, I changed DC servo by DC motor with gear reduction to
have much uniform speed. I add some additional support to avoid shaking. I have also
slotted opto-coupler for starting point detection. Linear operating range of opto-coupler is
300 micron meters (0-3.3V = 0-300 micron meters). I�ve a calibration sw operating during start-up.
Assume that you have reference dowel pins on the bed of printer 1st pin is at position
Y=0 X=Xmax/2 (center of X axis)and 2nd� pin is at Y=Ymax,X=Xmax/2..
Let�s draw a line passing through center of these pins a call it axis of rotation.
Let�s prepare our image centered on this axis of rotation. If you rotate image on
this axis everything will be matched in theory.
The method I explained is used by LPKF PCB milling machines.
>Volkan, I missed the mechanical and control details if you posted >them. I'm curious about the Y-axis drive, and the print head control >signals and timing. Were you able to find those on the web?
There is no web at least I know which explains operation of Epson heads.
I learned it by reading Epson patents and by measuring actual printer.
If you really interested with that and want to design yourself I can help you,
but implementation details are most probably off topic for this group and we need to contact offline.
Y-axis has very precise servo motor coupled with 10000 pulses (in quadrature decoding).
I have also precision linear slides on Y-axis.
Volkan
2008-07-22 by kennytrussell
heads.
printer.
help you,
I don't know if it is off-topic or not, but I, for one, really want to
know ALL the details. If there is a better group for that discussion,
please let me know which one it is and I will move on over there and
follow along! It seems to me that it is right on target for this group,
though.
Kenny
2008-07-22 by Derward Myrick
Kenny, I agree with you on this.
I think this list is the place for
this.
Derward Myrick
  Sent: Tuesday, July 22, 2008 4:17 PM
  Subject: [Homebrew_PCBs] Re: Homemade inkjet printer test results
  heads.
  printer.
  help you,
  though.
  Kenny
2008-07-23 by Mike Young
I'm of the opinion that the nuts and bolts of your machinery is as much a
part of making PCBs as is a bubbler for the etch tank, or a high speed drill
press. It is specialized, and has opportunities and needs not common for
general purpose CNC machines. I can think of no better place than here for
the discussion.
Linear slides and precision ballscrews for small boards and very light
mechanical loads are relatively inexpensive. In whole and in sum, the cost
and complexity are manageable for many of us, and the capabilities of very
great interest. I realize that documenting something of this scope is a
significant commitment. If you can find the time to share the details, I
think you'll find a receptive and eager audience. However, if you would
still like, I am happy to respect your wishes and keep the conversation
off-line.
But first a question about your process. Did I understand you correctly,
that you etch directly using the ink as the resist?
Mike.
Sent: Tuesday, July 22, 2008 11:59 AM
you,
decoding).
2008-07-23 by Volkan Sahin
Hi Mike,
>part of making PCBs as is a bubbler for the etch tank ...I've the same idea, for me inkjet printer is not different than tools that we're using.
The problem is, if we enter the implementation details that will be mostly electronics and sw and it'll be boring for those who're not interested. In the past, I saw such things in the group. That's why, I do not want to cause/initiate such discussions.
Concerning cost, it's around ~ $200 including inkjet head. It's not a huge amount and
finding linear slides is easy in US, no problem. I got them from ebay.
Yes, it is a direct inkjet pcb printing and it is an etch resistant.
Volkan
Sent: Tuesday, July 22, 2008 11:04 PM
> amount and
Is it a special ink and inkjet head?
Ink is from MISPRO Yellow pigment based and head is Epson CX4200.
Volkan
Date: Wednesday, July 23, 2008, 4:14 AM
not a huge
> amount and
2008-07-23 by kennytrussell
interested.
There are always threads in any group that are not of interest to
everyone but I think a significant number of folks here would be
interested. I would think anyone interested in making PCBs is
interested in electronics an sw, etc.
Whereever and however you choose to describe your project (if you can
find the time), I hope you will allow those of us who are interested to
follow along somehow. I've been making PCBs for a number of years. I am
really interested in your inkjet printer mod. I'm ready to start
building one!
Kenny
Hi Kenny,
...I am really interested in your inkjet printer mod. I'm ready to start building one!
No problem for me, I can explain. Keep in mind that it is not a inkjet printer modification.
I only used Epson head, x-axis remaining ones requires new design for both electronics and sw.
Volkan
Date: Wednesday, July 23, 2008, 4:31 AM
interested.
building one!
Kenny
2008-07-23 by Viper62pr
Greetings
I have been reading your posts and seen the pics(amazing), I have not etched a board for quite some time, I have them made at a board house but if I only need one or two it seems a waste.
I too would like to see how one of those things are made, after all aren't pcboards mainly used in electronics? I think putting that info up is like putting up the info for a homemade etching system or a homemade CNC pcboard machine.
Thanks for posting it.
Date: Wednesday, July 23, 2008, 1:50 AM
Hi Kenny,
Volkan
--- On Wed, 7/23/08, kennytrussell <kenneth.trussell@ thielekaolin. com> wrote:
From: kennytrussell <kenneth.trussell@ thielekaolin. com>
To: Homebrew_PCBs@ yahoogroups. com
interested.
building one!
Kenny
RE: [Homebrew_PCBs] Re: Homemade inkjet printer test results
2008-07-23 by Bertho Boman
I too like to know more.  It one of those things:  I probably never will
have time to build it but I like to KNOW.
Great work!
Bertho
________________________________________
From:  kennytrussell   Sent: Tuesday, July 22, 2008 17:17
though.
Kenny
Thanks for clarifying that, Volkan. I had missed that point but I am
still very interested. I've got a couple of other guys who would be
happy to help me build one if we can understand what you did. Thanks
for taking the time to help us!
2008-07-23 by Steve
--- In Homebrew_PCBs@yahoogroups.com, "kennytrussell"
> interested.
Speaking as listowner, I agree. I think it would be a shame if the
discussions took place outside of the public eye.
However: this is going to cover a very -broad- area of hardware,
firmware, software, inks, printhead driving signals, etc. So with that
in mind, I've created the Inkjet_PCB_Construction group. Volkan, and
everyone else involved or interested in modifying or building such a
beast, I hope you'll join there.
http://tech.groups.yahoo.com/group/Inkjet_PCB_Construction/
Monthly Reminder for the Inkjet_PCB_Construction group, please read:
Messages and threads:
  Please do NOT start a new thread by replying to another message.
Even if you change the subject line completely and trim all the
original messages off, there is information in the hidden header that
Yahoogroups detects and then lists it as if it were part of that thread.
  To start a new thread, start a new message to the list address.
homebrew_pcbs@yahoogroups.com
On Topic vs off topic:
   The list is meant to be quite specific to the subject of inkjet
printing resist directly onto copper for acid etching. However, within
that is a very broad area covering modification of existing printers,
printhead/printer selection, ink selection, design and construction of
flatbed plotters, proper drive to inkjet printheads, firmware,
software, baking/post-processing of resist, suitable
acids/temperatures, etc. So I ask that any questions or comments whose
purpose is not strictly on topic to take place off the list or on
another more suitable list.
   General electronics questions not related to the above should go to
the Electronics_101 list:
http://groups.yahoo.com/group/Electronics_101
   For other topics about making printed circuit boards such as toner
transfer, photosensitive boards, scratch 'n etch, etc. please join the
Homebrew_PCBs list:
http://groups.yahoo.com/group/Homebrew_PCBs/
Subject lines:
   Remember to change the subject line if you are straying from the
original thread. Please change the subject line if you are on digest,
as "Digest 1044" means nothing to anyone. If you are on digest, I
suggest changing yourself to "new and improved" so you can more easily
reply to individual messages.
   If you want an answer to a question, use a descriptive subject
line. "Help Me" is bad subject line. "Will my Canon BJC 3000 work?" is
a better subject line.
   Subject lines affect whether or not people even read your message,
and affect people searching the archives for help at a later date.
Trim messages- especially if you are receiving messages in digest
form. By the same token, quote enough so we know what you are
responding to. "Yeah, I agree" means nothing if no one knows who you
are answering or what you are agreeing with. And it is just irritating
if it is added to an untrimmed huge long quoted message(s).
Uploading files and photos:
 Please use the Description field. Think of a future member finding
this, and put enough description so they'll know why it is on the
Homebrew_PCBs list out of context of any messages you may have posted
about it. Examples: "Test with HP pigmented black ink #15 cartridge
baked at 240F for 5 minutes" is good, "My latest project" is bad. I
may at any time delete files and photos with insufficient description.
Remember to check the Links and Files if you have questions, you may
find the answer there already. Don't be shy about asking, but keep in
mind people are more likely to be helpful if they feel you've done
some homework before asking. "What is a printed circuit board?" shows
you didn't even try, but "I have an HP inkjet printer, will its black
printheads work for resist printing?" shows you have put some effort
in first.
Do not send "unsubscribe" messages to the list. Either send an email
to "Inkjet_PCB_Construction-unsubscribe@yahoogroups.com" or log onto
your groups at http://groups.yahoo.com/mygroups to edit your groups.
If you are unable to unsubscribe following these instructions, email
the listowner at Inkjet_PCB_Construction-owner@yahoogroups.com.
Please do -not- post virus warnings. This has been hashed to death on
this list and others. If we want to hear about soccer, we'll sign up
on a soccer list, if we want to hear about virii we'll sign up on a
virus list. Sports, religion, and politics are OFF TOPIC for the list,
feelings run high and it is too easy for a passing comment to flare up
into a flame war.
Suggestions, recommendations and such, to and from professionals and
companies are welcome. If you are posting for your own business,
please limit ads to once a month and feel free to post your site in
the Links area. Company representatives are encouraged to respond to
legit requests for information as long as you identify your
connection. IE, don't pretend to be an unconnected customer, there are
enough savvy people here that you'll be found out quickly. Just use
common sense about replying or people might think you are flogging
your business.
Spam- Spammers will be treated with all the respect they deserve. Off
Topic sale ads, links, uploads, etc. will be treated as spam and may
result in your removal from the list and banning from every other list
I am listowner or moderator of.
Thank you,
Steve Greenfield
listowner Homebrew_PCBs, Inkjet_PCB_Construction, and Electronics_101
2008-07-23 by James Newton
The details of the method and the initial technical details of the
first version of V's modification are all here:
http://techref.massmind.org/techref/pcb/etch/cx4200-vs.htm
and I will be overjoyed to post any additional technical details on
that same site.
While this list is fantastic for discussing those sorts of thing, it
makes more sense to have a distilation of the details, leaving out
all the chatter, on a web page.
Other simular modifications and general information about direct
inject etching are here:
http://techref.massmind.org/techref/pcb/etch/directinkjetresist.htm
James.
--- In Homebrew_PCBs@yahoogroups.com, "Mike Young" <mikewhy@...>
much a
speed drill
common for
here for
> the discussion.
light
the cost
of very
is a
details, I
would
conversation
> off-line.
correctly,
> Regards,
> Mike.
