Homebrew PCBs
Eagle PCB board file for testing min widths
2008-08-20 by Henry Liu
I got eagle pcb and pcb-gcode working great on the Haas CNC machine at
work.  Anyway, I want to test how fine a resolution my lines can be.  Would
be nice to get a good assortment of 1-12mil widths and clearances.
Does anyone have a good pcb board for testing?  I think I'll just draw
straight lines if not.
I set .00001 mil isolation and .001 mil step, max .010mil and can get 12mil
lines with 13mil clearance no problem using some generic router bit.
Will try smaller tomorrow.  I think I can easily get 5mil lines and 5 mil
clearances.
Re: [Homebrew_PCBs] Eagle PCB board file for testing min widths
2008-08-20 by Mark Brueggemann
> Would be nice to get a good assortment of 1-12mil widths and
> clearances.
Do you have much experience with the Haas machine?  I use a
QuickCircuit at work, and anything smaller than the 10mil bits
is virtually impossible.  I can't find a combination of bit
and feed speed that won't break the bits.  12 mil gaps is about
as fine as I can do reliably, saving the 8 mil to carve out gaps
between IC pads.  Widths of course aren't much of a problem as
it's a subtractive process.  EAGLE generates the gerber and
drill files for the quickcircuit software just fine, just getting
the flippin' thing to carve it out is a challenge.  Time consuming
at best.  A complex board takes hours and hours...
Mark B.
Albuquerque, NM
We just got the haas recently so I haven't played with it out much but it's
pretty much effortless.
On my first go, I used 6in/min, 7500rpm (max on the haas).  I noticed the
spindle was very hot without coolant.  Maybe that makes a difference in your
bits wearing out sooner without coolant.  I just used the machine vice on
the machine without any sort of glue or vaccum table.  The only problem I
encountered was it was too deep for the tool to go in so I had to machine
only the inside of the pcb.
I can get 1-2mil thick cutting lines with each pass using the engraving tool
and ordered some 30 deg carbide tips.  The haas has .1mil repeatable
accuracy so I run about 4 passes to make sure I get a good cut,
.1mil*4+2mil=2.4 mil separation of the traces is easily achievable.
It's reasonable fast if you don't do too many passes.
I just ran the singlesided and demo2 boards included with Eagle.  If I had a
big board, I'd just spend the $60 and send it out.
I'm used to Protel and Orcad and Eagle seems a long way from either so my
next task is figuring out how to import gerber files into eagle.
> > clearances.
> Mark B.
> Albuquerque, NM
