Homebrew PCBs
My first photo transfer
2008-08-27 by Brian
I started out by putting on rubber gloves. I cleaned my board with
sandpaper but it was kinda rough. Need to use a finer grade next
time. and a final cleaning with aolchol.
I set the iron on high. I taped my board to the paper with scotch
tape and placed a paper towel on it, folded in half. I pressed as
hard as I could and moved it around for 4 minutes and WOW!! The white
specks are pieces of the paper.
(see figure 1)
I put it in the etchent for 15 to 20 minutes or so, no heating or
bubbles, stirring every 30 seconds. and washed with water for 1
minute after all the copper was gone.
(see figure 2)
I had to use the sand paper again to get off the toner being carefull
not to sand too much and POW! There it was...
(see figure 3)
I will get the model of the laserjet printer and the paper later. My
friend did it for me. It looked like the lines spread a little during
the ironing. I will have to wait until I get to work to measure the
line widths. My prints look like 10 mil and my board looks like 15 to
20 mil. I still have to do electrical checks but it looks like it
will pass.
Brian
Re: My first photo transfer
2008-08-27 by Brian
--- In Homebrew_PCBs@yahoogroups.com, "Brian" <blue_eagle74@...>
white
> (see figure 1)
> (see figure 2)
carefull
> (see figure 3)
My
during
to
> will pass.
> Brian
I forgot to add that the photos are in the photos section under the
wadester13 folder.
Brian
Re:My first photo transfer
2008-08-27 by RICHARD HEILIGER
I have found that unless the board is badly stained, all that is needed is a quick wipe with alcohol before applying the pattern. I only lay a towel on the counter to keep from scorching it, but nothing between the paper pattern and iron. Iron set on cotton. I use only the weight of the iron, no extra pressure. I do run the tip around the edges of the board since the edges seem to loose heat more rapidly. I don't use tape to hold the pattern, just put a finger on the pattern and put the iron on the other end to get the pattern tacked down. Don't have to remove the melted glue that way. I use 220 grit paper to take off the toner. Acetone works well too.
I put my silk screen on the top of the board the same way. I also give the top and bottom of the board a very light spray of clear acrylic before assembly. You can solder right thru the acrylic and it forms its own solder mask. Helps prevent solder bridges as well.
I use a plastic cereal box with a glass fish tank heater and fish tank bubbler.
All my boards are single side. I find it faster to run jumpers than to mess with doing double sided. You have to put in the via's by hand anyway.
I don't like making things any more complex than necessary ;).
RD
Re: [Homebrew_PCBs] My first photo transfer
2008-08-27 by guja
toner transfer, not photo transfer.
--- On Wed, 8/27/08, Brian <blue_eagle74@...> wrote:
Subject: [Homebrew_PCBs] My first photo transfer
Date: Wednesday, August 27, 2008, 4:34 AM
(see figure 1)
(see figure 2)
(see figure 3)
will pass.
Brian
Re: [Homebrew_PCBs] Re:My first photo transfer
2008-08-27 by Michel Baguet
What kind of paper and printer do you use ?
Mike.
--- On Wed, 8/27/08, RICHARD HEILIGER <rdheiliger@...> wrote:
Subject: [Homebrew_PCBs] Re:My first photo transfer
Date: Wednesday, August 27, 2008, 3:17 AM
RD
2008-08-27 by Brian
HP LaserJet 1020 and Kodak Soft Gloss - CAT 182 0406
It works great. just peal off the paper while its still hot and its
ready to etch once it cools.
The traces are 10mil. I measured them at work. The paper is also 10
mil so it didnt spread out like I thought it did. I looked at it
under a 10X scope and only had one spot where the trace had a dimple,
still connected but only half the width.
Brian
--- In Homebrew_PCBs@yahoogroups.com, Michel Baguet <bagmik@...>
> Mike.
> From: RICHARD HEILIGER <rdheiliger@...>
tank bubbler.
anyway.
> RD
2008-08-28 by RICHARD HEILIGER
For my toner transfer I use Hammermill paper, the office glossy. I looked for it again about a month ago and apparently it is no longer made. Will have to look for another paper when this pack runs out. If any one has found a substitute, or if Hammermill has just renamed it, let us know. Would suspect that most any 32# glossy would work.
I have an old cheap Minolta Page Pro with generic toner refill that works great. I set the resolution to 1200 dpi and print it out.
RD
