Drilling glass (was Re: [Homebrew_PCBs] Re: Copper Foils)
2008-12-21 by dhlocker@comcast.net
If one is set on drilling through glass, the brass tube and abrasive compound is probably the best for a small shop. I used Clover brand valve grinding compound and a brass wire to slice heavy-wall Pyrex tubing many years ago. The abrasive is somewhat self-replenishing (unlike drill bits - when they break, you're done.) Lots of water and renew the abrasive regularly. Donald.
-------------- Original message ---------------------- From: "Stefan Trethan" <stefan_trethan@...> [snip] > I always wanted to see if a carbide PCB drill will drill through glass > but never got around to trying it. If you do try, let us know. > > One thing to keep in mind when using weird and wonderful PCB materials > might be that the thermal expansion coefficients may not match those [snip]
