Homebrew PCBs
What size drill bits?
2008-12-29 by Matthew Mucker
All,
I'm new to the DIY-PCB scene. I've just finished my first test etch and am
just overjoyed at the results I was able to achieve my first time out of the
gate.
I now need to look at drilling my boards.  Does anyone have any
recommendations on what drill bit sizes I should get for general
through-hole work?
Given an Eagle .brd file, what can I do to get an idea of the drill bit
sizes I'll need?   I ran the CAM processor and opened up the .dri file for
one of my projects, which appears to be a good start... but how much
tolerance should I allow? If the .dri calls for a .035, a .036, and a .0394
inch drill bit, I assume I can use a .0394 for all of them, right?  (I mean,
that's what... 4 and a half thousandths of an inch there.)
What rules of thumb do you use? What drill bit sizes are your most commonly
used sizes?
-Matthew
Re: What size drill bits?
2008-12-29 by tsescrl
Hello,
For example:
0.6mm = 24 mils
0.7mm = 27 mils
0.8mm = 32 mils
0.9mm = 35 mils
1.0mm = 39 mils
etc...
Convertion is: mm/0.0254 = mils
But, it si very necesary to prepare your components in your library
file to obtain a good result, a correct diameter from your mecanical
diameter dimmension, the part off Eagle are just for example, not sure
they are correct!!!
0.9mm, 35 mills are commonly use
0.8mm, 32 mils for IC, resitor, capa etc...
Patrick
--- In Homebrew_PCBs@yahoogroups.com, "Matthew Mucker" <matthew@...>
wrote:
> All,
and am
out of the
> gate.
> through-hole work?
file for
a .0394
(I mean,
commonly
> used sizes?
> Thanks,
> -Matthew
Re: [Homebrew_PCBs] What size drill bits?
2008-12-29 by JanRwl@AOL.COM
In a message dated 12/28/2008 7:12:23 P.M. Central Standard Time,
matthew@... writes:
Right.  If you will be using a HSS bit, be prepared to SHARPEN it  every
couple dozen holes.  If you can get some carbide "PCB Drill-bits"  with the
industry-standard 1/8" shank, buy at least ten to start with, as you  WILL bust 'em
very rapidly until you learn techniques to keep the board still  under the
drill, proper feed-rate, RPM, etc.
**************One site keeps you connected to all your email: AOL Mail,
Gmail, and Yahoo Mail. Try it now.
(http://www.aol.com/?optin=new-dp&icid=aolcom40vanity&ncid=emlcntaolcom00000025)
2008-12-29 by leon Heller
To: <homebrew_PCBs@yahoogroups.com>
Sent: Monday, December 29, 2008 1:11 AM
Subject: [Homebrew_PCBs] What size drill bits?
> All,
> the
> gate.
> through-hole work?
> .0394
> mean,
> commonly
> used sizes?
I mostly use 0.7 mm, and 0.6 mm for vias.
Leon
2008-12-29 by John Honniball
> through-hole work?
I use 0.8mm for IC sockets, resistor and capacitor leads, and small
transistor leads.  For larger pins like power transistors, voltage
regulators and the square pins of DIL header connectors, I use
1.0mm.  It might be useful, for some types of leads, to have a
slightly larger drill available, maybe 1.2mm.  And as others
have said, go for the tungsten carbide drills, as they are hard
enough to use on fibreglass PCBs.  I use the type with a 3mm shank,
and I use them in a collet-type chuck in a mini drill.
John Honniball
2008-12-29 by kabowers@NorthState.net
These might be of interest:
href="http://www.goldmine-elec-products.com/prodinfo.asp?number=G15746"
href="http://www.goldmine-elec-products.com/prodinfo.asp?number=G15758"
No interest, just another customer.
2008-12-30 by Dennis
Hi Matthew,
> etch and am just overjoyed at the results I was able to achieve
> my first time out of the gate.
Congrats.  Have you tried ink jet transparencies for transfer?  I
tried paper with mixed results.  With inkjet transparencies, there's
less effort involved to prep the board for etching.  After ironing,
just let the transparency cool slightly and then start lifting from
one corner.  If some toner hasn't transferred, just replace the
transparency and iron more; assuming you haven't removed the
transparencly completely so alignment doesn't become an issue.
Another advantage with iron/transparency is you can monitor toner
melting and apply heat/pressure where needed.  I like to almost close
lead holes so I can use them as pilot holes for the drill bits.
With transferred "properly", there's no toner left on the
transparenc; pictures in my album.  Still should do the
toothbrush/soap cleaning to remove any residue from the transparency,
but no paper fibers to deal with.
As with paper, not all inkjet transparencies are equal.  I'm using
some HP inkjet transparency that I bought in bulk.
The only downside I've seen is minor pitting because toner coverage
isn't as good on transparencies; but it's purely cosmetic.  I go over
ground planes with a Sharpie if it looks like pitting will be ugly.
I've tried running inkjet transparencies through several laser
printers (HP, Lexmark, and Xerox) and have never had a problem with
the printer getting jammed or otherwise damaged; YMMV.
> through-hole work?
I prefer to use #69 (0.0292") for most holes, #65 (0.035") for
headers, and #60 (0.040") for trimmers.  These sizes give a little
friction on the leads so they don't fall out so easily when soldering.
Saw the link that someone posted.  Also take a look at
drillbitcity.com.  They have assortments and shipping in the US is
better; a few dollars for 20 bits with holders vs. $10 for that other
place.  They have 10 piece assortment for sizes 60-69 that should be
around $11 shipped in the US.  I'm not affiliated with them; just a
satisfied customer.  These are resharpened bits, as are all of my
other bits.
Dennis
2013-01-13 by thb201
I was looking to get some drill bits but I only want to get just a few sizes, especially if I spring for the more expensive carbide types.  Just out of curiosity, to get an idea, I measured the lead diameters of a wide variety of components.  Surprisingly the diameters are all over the place - everywhere from 0.016" up to 0.032" in increments of 0.001" for the most common sized components.  I would like to stick to maybe just three sizes of drill bits to (hopefully) cover most parts I'll come across.  I'm thinking maybe 0.035" (#65 bit), 0.025" (#72 bit) and 0.020" (#76 bit) would cover most eventualities.
Are these three sizes workable or am I limiting myself too much?  I don't do a lot of PC boards so if I can keep down the number of sizes on hand this would be a plus.
(I'm in Canada so I'm limited to what I can get here, usually from machine tool suppliers like KBC.)
John
RE: [Homebrew_PCBs] What size drill bits?
2013-01-13 by Rick Sparber
John,
I just went through this myself. It sounds like you have figured out what
you need. I ended up spending $60 on a nice selection based on what my
current circuit board needed.
Let me ask a related question - what do you have to drive them? Assume you
want to run at 200 surface feet per minute. Then the needed RPMs equals
200/(0.26 x D) where D is the diameter of the drill in inches. Given your
0.020" drill you are looking at 38,500 RPM which is about what a Dremel(r)
puts out. The mount must have very little side play because that can snap
these tiny drills too.
Rick
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
On Behalf Of thb201
Sent: Saturday, January 12, 2013 7:59 PM
most eventualities.
would be a plus.
John
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
2013-01-13 by Mitch Davis
Carbide bits stay sharp for a long time, but they are amazingly
brittle.  The slightest sideways movement and *ping*, they're gone.
It's not realistic to use them with something you hold in your hand.
I have used a normal drill press with good results.
Mitch.
2013-01-13 by jackinnj
preset drill sizes from PCBExpress: .008, .014, .020, .025, .029, .033, .036, .040, .043, .046, .053, .061, .067, .080, .087, .093, .100, .110, .125, .141, .151, .167, .193, .251 (.008 available for 4-6 layers only).
2013-01-13 by chris
> Mitch.
I use 0.8mm carbide bits in a hand held proxxon
I can usually manage a few thousand holes before the drill breaks..
My wife usually breaks the drill withing the first dozen holes or so..
I have been through several methods of drilling, including a commercial drill press,  a home made foot operated drill press, a CNC drilling machine and ended up with the following
a pulley at ceiling height
a proxxon hand held drill fittted to about a 3 foot aluminium pole
the pole is suspended from the pulley with a counterweight giving it slightly negative weight so that when you let go it goes upward, away from the board
the very end part of the proxxon has a rubber grommet fitted..  and it it this that is held lightly between finger and thumb..
this setup keeps the holes vertical and reduces hand and arm strain..
using this, my wife can drill almost as many holes as I can before breaking the bit..
I manage about 2 holes a second when they are close together..
with an average of about 1 per second over a longer period
thats a fair bit faster than my CNC machine can do.. when things like clamping and regictration are included.
Chris
RE: [Homebrew_PCBs] Re: What size drill bits?
Chris,
Elegantly simple! You get a very clear view of the place to be drilled and
quick action.
I sounds like it doesn't take long to develop the skill to make this work. I
have plenty of 0.75 mm drills to learn on ;-)
I'm confused about the pulley's role. Is the 3' rod resting on the pulley or
is there a rope attached to the pulley that supports the rod?
Rick
On Behalf Of chris
Sent: Sunday, January 13, 2013 7:00 AM
Subject: [Homebrew_PCBs] Re: What size drill bits?
> Mitch.
the board
the bit..
Chris
2013-01-13 by chris
Rick,
there is a rope (or string really..  I use light switch pull cord)
the string goes from the counterweight (which is an old pill container with nuts and bolts in it), over the pulley and down to the aluminium pole..
the pole is about 3 feet long with the proxxon frmly fixed to the end..  The way I have it rigged, there is 2 foot clear of string between the pulley and the top of the pole
the role of the pole (rhyme  :-) )  is partly to damp oscillation..
I started with about a foot long and quickly realised in needed to be longer, the aluminium pole was just a bit of scrap from under the bench
In retrospect, the pole needs to be as long as possible without fouling on the pulley..  but what I put together works so I'm loath to fiddle with it..
An old fishing pole would probably be ideal..
I've put a picture in the     photos  spiyda   drill
Chris
--- In Homebrew_PCBs@yahoogroups.com, "Rick Sparber"  wrote:
> Chris,
> quick action.
> Rick
> On Behalf Of chris
> > Mitch.
> the board
> the bit..
> Chris
Chris,
I looked at the picture and am now more confused. Can you take the set up
from the side?
Rick
On Behalf Of chris
Sent: Sunday, January 13, 2013 7:32 AM
Rick,
there is a rope (or string really..  I use light switch pull cord) the
the top of the pole
Chris
> Chris,
> and quick action.
> work. I have plenty of 0.75 mm drills to learn on ;-)
> pulley or is there a rope attached to the pulley that supports the rod?
> Rick
> On Behalf Of chris
> > Mitch.
> from the board
> breaking the bit..
> Chris
Photos:
Rick:
I take it then you approve of my selection of sizes ;-)
Sorry, I should have mentioned in my post that I have several Dremels plus the small Dremel drill press type holder.  Hopefully I should be OK in that department.  I have used it in the past for drilling PC boards with HSS bits without issue but this would be my first attempt at using carbide bits so I hope there won't be too much side play.  The holder is an older one, about 20+ years old.  I thought I read somewhere that their newer ones aren't as well made.
I'm thinking in terms of getting some carbide bits plus a bunch of HSS bits as backup just in case.  KBC carries "made in the U.S." carbide bits with 1/8" shanks for only $4.75 a piece.  Their small HSS bits are either $0.47 (probably far eastern) or $1.61 (probably U.S. made) each depending on finish, so I could get a bunch of those without breaking the bank.
John
> John,
> Rick
2013-01-13 by Jeff Heiss
I would like to understand your setup but I am confused too.  I viewed the
picture.  Is the drill/pole on a slide?  Or is it just hanging from the
pulley like a plumb bob?
Jeff
  _____
On Behalf Of chris
Sent: Sunday, January 13, 2013 9:32 AM
Rick,
the top of the pole
Chris
<mailto:Homebrew_PCBs%40yahoogroups.com> , "Rick Sparber" wrote:
> Chris,
> quick action.
I
or
> Rick
<mailto:Homebrew_PCBs%40yahoogroups.com> ]
> On Behalf Of chris
> To: Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com>
> > Mitch.
> the board
breaking
> the bit..
> Chris
Photos:
John,
I only recently started to use these tiny tungsten carbide end mills. They
work much better than twist drills and I've been told that they don't dull
nearly as fast.
The end mills I bought came from
https://www.drillbitcity.com/catalogue/10_piece.asp
I bought 5 different sizes in sets of 10. They came custom labeled in one
box. Since they are re-sharpend, the price is much less than new yet they
work great. I was pleased with this company and will use them in the future.
Rick
On Behalf Of thb201
Sent: Sunday, January 13, 2013 12:34 PM
Rick:
well made.
John
> John,
> what you need. I ended up spending $60 on a nice selection based on
> what my current circuit board needed.
> you want to run at 200 surface feet per minute. Then the needed RPMs
> equals
> your 0.020" drill you are looking at 38,500 RPM which is about what a
> Dremel(r) puts out. The mount must have very little side play because
> that can snap these tiny drills too.
> Rick
2013-01-14 by chris
Sorry  second pic added..
in photos ... spiyda drill2
it just hangs like a plumb bob
Chris
> Jeff
>   _____
> From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@...m]
> On Behalf Of chris
> Rick,
> the top of the pole
> Chris
> > Chris,
> > quick action.
> I
> or
> > Rick
> > On Behalf Of chris
> > > Mitch.
> > the board
> breaking
> > the bit..
> > Chris
> Photos:
2013-01-14 by chris
and a quick video.. of the counterbalanced pulley mounted drill
http://youtu.be/flufbYNz48c
you can see the slight wobble that would be damped by a longer pole...
but it doesn't seem to break bits even as it is..
ps  thats my lot..  if I haven't explained it well enough now..  I never will !
Chris
> Chris
> > Jeff
> >   _____
> > On Behalf Of chris
> > Rick,
> > the top of the pole
> > Chris
> > > Chris,
> > > quick action.
> > I
> > or
> > > Rick
> > > On Behalf Of chris
> > > > Mitch.
> > > the board
> > breaking
> > > the bit..
> > > Chris
> > Photos:
2013-01-14 by Rick Sparber
Chris,
Damn impressive!
Rick
On Behalf Of chris
Sent: Sunday, January 13, 2013 7:17 PM
will !
Chris
> Chris
> > viewed the picture.  Is the drill/pole on a slide?  Or is it just
> > hanging from the pulley like a plumb bob?
> > Jeff
> >   _____
> > On Behalf Of chris
> > Rick,
aluminium pole..
> > bench
fiddle with it..
> > Chris
> > --- In Homebrew_PCBs@yahoogroups.com  , "Rick Sparber" wrote:
> > > Chris,
> > > drilled and quick action.
work.
> > I
> > > pulley
> > or
> > > Rick
> > > On Behalf Of chris
carbide types.
> > > > Mitch.
> > breaking
> > > the bit..
> > > Chris
> > > and
> > Photos:
Chris,
It would be really cool if it could be gyro stabilized.
Rick
On Behalf Of chris
will !
Chris
> Chris
> > Jeff
> >   _____
> > On Behalf Of chris
> > Rick,
aluminium pole..
> > bench
fiddle with it..
> > Chris
> > > Chris,
work.
> > I
> > > pulley
> > or
> > > Rick
> > > On Behalf Of chris
carbide types.
> > > > Mitch.
> > breaking
> > > the bit..
> > > Chris
> > > and
> > Photos:
Chris,
Yes, the second picture really helps.
Rick
On Behalf Of chris
Sent: Sunday, January 13, 2013 7:02 PM
Chris
> the picture.  Is the drill/pole on a slide?  Or is it just hanging
> Jeff
>   _____
> On Behalf Of chris
> Rick,
pole..
> bench
fiddle with it..
> Chris
> > Chris,
work.
> I
> > pulley
> or
> > Rick
> > On Behalf Of chris
types.
> > > Mitch.
> > away from the board
> breaking
> > the bit..
> > Chris
> Photos:
2013-01-27 by chris
Just a footnote ...
Having posted some pics of my hand drilling jig/aid thingy I decided to update it a bit with some improvements I've been meaning to make for the last several years !  (my normal motto is, "if its not broke, don't fix it"!..  but the proxxon drill finally died, so I took that as an excuse)
a) changed the counterweight to a solid steel weight instead of a plastic pot of old nuts and bolts..
b) fitted a new proxxon IBS/E drill as the old IB/E had given up the ghost
c) lengthened the support rod to (successfully) reduce the small oscillations at the drill tip
d) added an LED light to the side of the drill  (6 x 0.5Watt White LEDs..  a bit heath robinson but I had the parts to hand)
e) instead of drilling and tapping a hole in the proxxon casting to fix, since the new one is under warranty, used a cable tie to mount it
The result is that it is now faster, easier to hit the precise centre of the etched hole..  and I can drill more holes before my 57 year old eyes get tired ..
I managed about 1500 holes in one half hour sitting this afternoon before my eyes got tired..
a couple of pics in the photos spiyda folder
Chris
--- In Homebrew_PCBs@...m, "Rick Sparber"  wrote:
> Chris,
> Thanks,
> Rick
> On Behalf Of chris
> Chris
> > Jeff
> >   _____
> > On Behalf Of chris
> > Rick,
> pole..
> > bench
> fiddle with it..
> > Chris
> > > Chris,
> work.
> > I
> > > pulley
> > or
> > > Rick
> > > On Behalf Of chris
> types.
> > > > Mitch.
> > > away from the board
> > breaking
> > > the bit..
> > > Chris
> > Photos:
2013-01-28 by Rick Sparber
Chris,
I was a bit confused about which pictures you were talking about. The first
few showed an arrangement to hold the proxxon that involved some boards and
a spring. I thought that was very good. But your text didn't match those
pictures so I next looked at the last pictures in your file and see an
upgrade to the system you talked about last.
Is the key difference here that you can swing the proxxon around without
moving the board given how it hangs. I can see how the first pictures show a
machine similar to a drill press.
Rick
On Behalf Of chris
Sent: Saturday, January 26, 2013 5:31 PM
Just a footnote ...
tired ..
eyes got tired..
Chris
> Chris,
> Thanks,
> Rick
> On Behalf Of chris
> Chris
> > Jeff
> >   _____
> > On Behalf Of chris
> > Rick,
> > the aluminium
> pole..
> > bench
> > to
> fiddle with it..
> > Chris
> > > Chris,
> > > this
> work.
> > I
> > > pulley
> > or
> > > Rick
> > > On Behalf Of chris
> > > > >carbide
> types.
> > > > Mitch.
> > breaking
> > > the bit..
> > > Chris
> > > and
> > Photos:
Photos:
2013-01-28 by chris
Rick,
the drill press type tool was seven years ago..
after that I went to a CNC drilling machine based on a micro mill
the latest is the proxxon hanging from the pulley, the last two pictures in the album..  'proxxon1'  and 'proxxon2'
This setup gives the fastest and most accurate holes of the three by far..
There are a whole lot of reasons it works better..
the CNC machine could not compensate for size variations in the boards due to temperature variations in the toner transfer process.
the drill press arrangement was very solid..  if the positioning was half a hole out, it would drill a hole half a hole out..
the hand held suspended arrangement solves both of these problems.. the drill wanders into the centre of the hole all by itself..
by the way, the pulley is the same as in the 'drill1' and 'drill2' pictures
Chris
> Chris,
> Rick
> On Behalf Of chris
> Just a footnote ...
> tired ..
> eyes got tired..
> Chris
> > Chris,
> > Thanks,
> > Rick
> > On Behalf Of chris
> > Chris
> > > Jeff
> > >   _____
> > > On Behalf Of chris
> > > Rick,
> > > the aluminium
> > pole..
> > > bench
> > > to
> > fiddle with it..
> > > Chris
> > > > Chris,
> > > > this
> > work.
> > > I
> > > > pulley
> > > or
> > > > Rick
> > > > On Behalf Of chris
> > > > > >carbide
> > types.
> > > > > Mitch.
> > > breaking
> > > > the bit..
> > > > Chris
> > > > and
> > > Photos:
> Photos:
2013-01-29 by Rick Sparber
Chris,
You are a man after my own heart! I'm a real sucker for simple, elegant
solutions to difficult problems. The fact that you can beat CNC with a
dangling drill brings a big smile to my mouth.
Rick
On Behalf Of chris
Sent: Monday, January 28, 2013 4:42 PM
Rick,
Chris
> Chris,
> first few showed an arrangement to hold the proxxon that involved some
> boards and a spring. I thought that was very good. But your text
> didn't match those pictures so I next looked at the last pictures in
> your file and see an upgrade to the system you talked about last.
> without moving the board given how it hangs. I can see how the first
> pictures show a machine similar to a drill press.
> Rick
> On Behalf Of chris
> Just a footnote ...
> as an excuse)
> ghost
> eyes get tired ..
> Chris
> > Chris,
> > Thanks,
> > Rick
> > On Behalf Of chris
> > Chris
> > > Jeff
> > >   _____
> > > On Behalf Of chris
> > > Rick,
> > > the aluminium
> > pole..
> > > the bench
> > > to
> > fiddle with it..
> > > Chris
> > > > Chris,
> > > > this
> > work.
> > > I
> > > > the pulley
> > > or
> > > > Rick
> > > > On Behalf Of chris
> > > > > >expensive carbide
> > types.
> > > > > amazingly brittle. The slightest sideways movement and *ping*,
they're gone.
hand.
> > > > > Mitch.
so..
> > > > pole
strain..
> > > > before
> > > breaking
> > > > the bit..
> > > > Chris
> > > > and
> > > Photos:
> Photos:
Photos:
2013-01-30 by Tony Smith
solutions
> to difficult problems. The fact that you can beat CNC with a dangling
drill brings
> Thanks,
> Rick
Very old, very well-known and studied problem.  That's why in many cases the
robots make the parts and the meatbags put them together.
Robot makers quickly found out doing things like putting a bolt into a hole
is tricky, if you are the slightest bit off it catches.  Human hands have a
bit of 'give' and you can wiggle the bolt until it aligns, the CNC
equivalent is to have the gripper spring-loaded or mounted in soft rubber so
it can move a bit too.
That trick probably won't work with PCB drilling as you'd snap the bits.
Then there's things like Vix bits, or even Philips head screws, that's one
of the reasons they were invented.  You can poke the driver in the general
direction of the screw and it'll eventually catch, that doesn't happen with
other types.  The driver also pops out of the screw when the correct torque
is reached - that's a feature, not a bug!  Robots like Philips head screws.
Tony
2013-01-30 by Rick Sparber
Tony,
Interesting observation. I heard recently that we have more "hand made"
products today than ever before. Those 50,000 workers at Foxcom are doing a
lot of assembly of machine made parts. I have taken apart an iPod touch and
can tell you there are a lot of difficult to fit parts in there.
Since there is money to be made finding a solution to this general problem,
I'm sure one will be found.
Rick
On Behalf Of Tony Smith
Sent: Tuesday, January 29, 2013 8:58 PM
Subject: RE: [Homebrew_PCBs] Re: What size drill bits?
> elegant
solutions
drill brings
> Thanks,
> Rick
Tony
