--- In Homebrew_PCBs@yahoogroups.com, "Leon Heller" <leon355@...> wrote:
> The Pulsonix software I use can only create negative plots for power planes, and I think that it's the same for most other packages. How do those of you using negative-working dry film resist create your transparencies?
> Leon
I use Viewmate. Just import your desired layers then when you go to print just select visible layers, factor by one, and check raster & negative.
