Ultimate Guide Step by Step Directions for Direct Printing Inkjet Printing PCBs + Kit
2009-09-02 by Henry Liu
It has been a common question how to print PCBs using an Inkjet and how to make homebrew PCBs in general. Answers are spread apart and you can find it if you are looking for bits and pieces and willing to try a few things out. However, I made it easier and made an idiot proof step by step guide along with a kit for those that just want to get started and make PCBs quickly and easy without doing any hacking or major modifications. I also made several innovations and improvements such as a special laser cut stencil and finding the best possible ink after many different trial and error tests. Yes there are limitations and sacrifices but I don't claim this is the only way nor do I claim it is the best way but rather a way that works for sure and easy to follow. I have written this guide to provide 100% reproducible results. I cover everything from how to prepare the circuit board, how to save the image, how long to bake the board at what temperature to dry it and how long to etch the board in great detail. Follow these instructions and you can have a board in a matter of minutes. Watch the video here: Check out the tutorial here: http://www.fullspectrumengineering.com/tutorial.html Check out the kit here: http://www.fullspectrumengineering.com/pcbinkjet.html The images got a bit screwed up when I watermarked them but I have the Hi Res originals that I will update once I figure out a better watermarking program. Disclaimer: This is semi-commercial as a kit form so if you don't like it, ignore this message and don't buy it. The information is hopefully still useful. The website still needs work but I threw it all together to get the information out before the refinements are done. Cheers, Henry [Non-text portions of this message have been removed]
