Homebrew PCBs
Success report
Success report
2009-10-07 by davesage12@rogers.com
I have to thanks the members of this group (and possibly others) for two ideas. First is the use of HP presentation paper for toner transfer rather than the Staples glossy photo paper I was using. The removal of the paper is comparatively simple. I'd been fighting with the photo paper for years. Removal of thepaper residue being the biggest problem.
 Second, I made some Cupric chloride according to the intructions from an internet link I think presented here (search Etching with Air Regenerated Acid Cupric Chloride). Although making it is a bit nasty (fuming HCL) and time consuming (about 2 weeks), it is fine once created and works incredibly well. Best of all it can be regenerated and used again. Also it is a lot less messy than ferric chloride (and cheaper too).
 The Cupric chloride etched my board in 3 minutes at room temperature using a sponge brush to swab the board. The toner stood up to it perfectly. I'm considering a bubble tank or a spray system in the future to speed things up even more.
 I'd like to add that I think the direct use of HCL and Hydrogen peroxide - although they can be ingredients to make Cupric Chloride - are being mis-interpreted as to be used directly to etch boards. I think this is why so many mention they have problems with it. I think the acid is much too strong.
 After reading the article carefully it is apparent that it is actually the CU+2 ions produced by making the Cupric Chloride properly that does most of the etching not the acid so much. The article also mentions another link to a site describing the way Cupric chloride is used commercially so it is a valid etchant. The straight HCL and hydrogen peroxide are nly is only a means to an end.
I'm going to start using both of these now. They have certainly improved my results.
Sage
Re: Success report
2009-10-09 by r_twiddy
<davesage12@...> wrote:
>  Second, I made some Cupric chloride according to the intructions from an internet  ...link.. I think presented here (search Etching with Air Regenerated Acid Cupric Chloride). Although making it is a bit nasty (fuming HCL) and time consuming (about 2 weeks), it is fine once created and works incredibly well. Best of all it can be regenerated and used again. Also it is a lot less messy than ferric chloride (and cheaper too).>
> Sage
Hi sage, I searched the messages for the link you mentioned..
http://pacificsun.ca/~robert/pcb/cucl.htm Pretty good
> >>>>page on CuCl. Lots of precision chemistry.
And it appears to be down..
Do you have more specifics on the process you used..
Thanks.
Re: Success report
2009-10-10 by davesage12@rogers.com
It is unclear to me if you had sucess finding the site since you iluded to the fact you noticed the detailed chemistry but also noted the site appears to be down.
You posted:
I any case here is the link.
http://members.optusnet.com.au/eseychell/PCB/etching_CuCl/index.html
I think it explains the process of making it quite well but you need to read past the chemistry lesson. Just be aware that the concentrated HCL is very nasty and should be handled with a respirator and preferably outdoors. Inoors without an exhaust fan and you might notice steel things like tools in your shop rusting. It's quite alright once it has reacted with the copper which reduces it strength. I'm quite excited about it being re-usable. Sort of a green alternative (well almost) and also not having to dispose of expensive ferric chloride or buying ammonium persulphate which cannot be stored once mixed.
Sage
