Homebrew PCBs
HP Presentation Glossy
2009-10-12 by sailingto
Hello all, just a short msg to mention I finally tried the HP Presentation Laser Color Glossy paper.  That stuff works pretty darn good. I have used pages from magazines that worked good, but soaking the paper off after was a hassle.  By FAR the best I've used to date is the Pulsar paper - that stuff just floats off, but a $2/sheet, it's a bit pricey for me.
To bring the cost/board down I cut the paper to size of board so get several PCBs per sheet, then I also have used the same section of paper 2 or 3 times - just dry good between uses (yea, I'm a tightwad!)
Today I tried the HP Presentation paper - it had good toner transfer, and in hot soapy water it came off pretty good. Not as good as Pulsar, but at $15/300 sheets - a LOT less expensive.
73 de Ken H>
Re: [Homebrew_PCBs] HP Presentation Glossy
2009-10-12 by Derward Myrick
Ken,
I use paper from Royal Brites.  This is not very good as
Ink Jet Color Paper but good at toner transfer.
After about 5 min. of soaking in cool water it will float off
whole.
Sam's Club  #747996
Look at
http://www.samsclub.com/shopping/navigate.do?dest=5&item=200337
150 Sheets just over $18.00.
Derward Myrick  KD5WWI
  Sent: Sunday, October 11, 2009 7:04 PM
  Subject: [Homebrew_PCBs] HP Presentation Glossy
  73 de Ken H>
