Homebrew PCBs
correction on TT bad spots
2010-01-03 by Derward Myrick
To the group
Most might know this but to correct scratches and other imperfections
on TT I use a paint pen.  I went to Hobby Lobby and got a Tree House Studio #564815
fine tip Paint-Marker and it works better than any thing I have used.  I am sure any
hobby place would have what you need.  I think any brand with fine tip would work.
Derward Myrick KD5WWI
Re: correction on TT bad spots
2010-01-04 by sailingto
Is that something like a Sharpie? I've been using Sharpies for a while now, they are available in what they call a "Fine Tip" and an "Ultra Fine tip".
If the Tree House is different, I will have to try one.
Thanks for sharing.
Ken H.
--- In Homebrew_PCBs@yahoogroups.com, "Derward Myrick" <wdmyrick@...> wrote:
> To the group
Re: [Homebrew_PCBs] Re: correction on TT bad spots
2010-01-04 by kabowers@NorthState.net
>Thanks for sharing.
>Ken H.
Many years ago (before personal laser printers) I freehanded a rather
complicated board and used multiple colors of Sharpies. Everything EXCEPT
the black lines more or less disappeared when I etched the board. I don't know if
that is still the case or not.
Keith Bowers WB4LSJ- Thomasville, NC
2010-01-04 by Harvey White
>Thanks for sharing.
I bought an "extra fine point etch pen" from All Electronics.  It
turns out to be  a sharpie, but industrial variety, "super permanent
ink" with a chemical resistant label.  Supposed to resist most
chemicals and up to 500 Degrees F.  Sharpie #13801.  It was sold by
Datak.
No idea of how good it is.  I'll be finding out in a week or two.
Harvey
>Ken H.
>> To the group
>Be sure to visit the group home and check for new Links, Files, and Photos:
>http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
2010-01-04 by Derward Myrick
Ken,
This is real paint and comes in all collors.
I think there are many brands of paint pens.
The paint is very resistant to the etch solution.
I used red because you can see it very easy.
When you ask for paint pen they know what
you want.
  Sent: Sunday, January 03, 2010 6:41 PM
  Subject: [Homebrew_PCBs] Re: correction on TT bad spots
  Thanks for sharing.
  Ken H.
  > To the group
2010-01-04 by Stefan Trethan
The problem with the paint pens is that they don't keep so well. If
you are a hoarder like me you'll sooner rather than later be left with
a box of useless hard pens. That seems to happen much faster with the
"laquer" variety where you must pump the tip and hear a steel ball
inside when shaken, the permanent marker variety seems to store much
better.
One pen that works well on most etchants is the staedtler lumocolor
permanent marker. The red color is best (the ink is also used in the
marker for chemical lab glassware).
<http://www.staedtler.co.za/upload/318_2_420_16611.jpg>
It only resists strong etchants without fail if the pen is fairly
fresh, so it is best to get the refill station so you always have a
"new" pen at low cost.
ST
On Mon, Jan 4, 2010 at 3:14 PM, Derward Myrick <wdmyrick@...> wrote:
>  Ken,
> you want.
Re:correction on TT bad spots
2010-01-04 by Lee Studley
What was the line width achieved with this pen. thanks -Lee
__________ Information from ESET Smart Security, version of virus signature database 4743 (20100104) __________
The message was checked by ESET Smart Security.
http://www.eset.com
2010-01-04 by Andrew Mathison
Dear Stefan Trethan
  it may have already been mentioned (my apologies if that is so!), but Edding permanent markers can be "reloaded", do not seem to dry out quickly and at least in black resisted all etchants that I have used. I used them years ago to touch up both foils for PCBs and final PCBs before etching. (though not for some years.)
  I have only used black though for etching, I could not say if the other colors work as well in that respect, but they also do not dry out quickly as long as the cap is properly on....I have a set that I have had for at least 5 years of all the colors......they are still good though only used occasionally....all are reloadable if you buy the refill bottles....I have only reloaded black myself though.
  They also come in several thicknesses too. Check here:-
  http://www.waltersandwalters.co.uk/html/permanent_markers.html
  Andy
  better.
  ST
Re: [Homebrew_PCBs] Re:correction on TT bad spots
2010-01-05 by Piers Goodhew
(Apologies if this is a double-mail, my last attempt seems to have
disappeared)
I've been meaning to ask re Sharpies: I got one, but the results are not
great. The first TT project I saw, the author signed the PCB with a Sharpie
and the result was clearly visible post-etch. But for me, I lose maybe 50%.
(not that I want to sign my every board, but as a touch up tool, I have to
cross my fingers)
Is there a secret with Sharpies (cure time, cure process?) Or is the US
formulation using chemicals banned elsewhere in the world or something?
Anyway, the Staedtler sounds rather promising ....
(re the thickness, mine would be ca. 30 mil. Not thin, but much more
limiting is my ability to draw accurately, and the tip is round so you're
never quite sure which part is going to touch down first)
PG
> http://www.eset.com
2010-01-05 by sailingto
I have to go over the sharpie spot two or three times to get good coverage.  The first "marking" will not be totally dark, but by the 3 or 4th time marking over the same spot it seems to work pretty good.  I've used both the fine point and Ultra fine point - the fine point is NOT what I would consider a fine point, more of a blunt point - 30 mil would be with a new sharp "fine" point.
Ken H>
2010-01-05 by Stefan Trethan
Yes, Edding markers are of the slow drying kind.
I have not found any with tips as fine as the Staedtler pens.
ST
On Mon, Jan 4, 2010 at 6:54 PM, Andrew Mathison
<andrewdavid.mathison@...> wrote:
>  Dear Stefan Trethan
>  Regards
>  Andy
2010-01-05 by Andrew Mathison
Dear Piers Goodhew
  see my previous post on Edding pens, they come from fine upwards!
  regards
  Andy
  disappeared)
  cross my fingers)
  PG
Dear Stefan Trethan
  if you need it so fine then buy a fountain pen (cheapest you can buy, kids quality) and load it up with Edding ink from a refill bottle, or just dip the nib into the ink and clean well afterwards!!!
  This idea has NOT been tried by me personally!!!
  Andy
  ST
2010-01-05 by Kerry Wentworth
> ST
You can lay down scotch tape as a mask to make fine lines.  It won't
pull up properly transfered toner.  It also helps if you are as clumsy
as I am.  ;)
Kerry
2010-01-06 by Stefan Trethan
You could, but the staedtler pen wih a ruler to guide it is good for
10mil lines or so, and I'm just too darn lazy to do much masking up.
Once the process was dialled in I didn't need much correcting anyway.
ST
On Wed, Jan 6, 2010 at 12:53 AM, Kerry Wentworth
> as I am.  ;)
> Kerry
