[Homebrew_PCBs] TT trace widths
2010-03-25 by Mark Lerman
Has any been measuring the actual trace widths produced with toner transfer? I would think that running it through a laminator would significantly spread the trace. I just ordered a stage calibrator to measure widths with my microscope, but I would be very interested in hearing from anyone who had made these measurements. Mark
2010-03-25 by James
--- In Homebrew_PCBs@yahoogroups.com, Mark Lerman <mlerman@...> wrote: > > Has any been measuring the actual trace widths produced with toner > transfer? I would think that running it through a laminator would > significantly spread the trace. I just ordered a stage calibrator to > measure widths with my microscope, but I would be very interested in > hearing from anyone who had made these measurements. > > Mark > I haven't measured the actual traces, but they look identical to the printout prior to transfer, no visible spreading at all.
2010-03-25 by tda7000
--- In Homebrew_PCBs@yahoogroups.com, "James" <jamesrsweet@...> wrote: > > > > --- In Homebrew_PCBs@yahoogroups.com, Mark Lerman mlerman@ wrote: > > > > Has any been measuring the actual trace widths produced with toner > > transfer? I would think that running it through a laminator would > > significantly spread the trace. I just ordered a stage calibrator to > > measure widths with my microscope, but I would be very interested in > > hearing from anyone who had made these measurements. > > > > Mark > > > > > I haven't measured the actual traces, but they look identical to the printout prior to transfer, no visible spreading at all. > When I tried this I used an iron, I found that if I put the iron too hot or left it on too long caused the toner to spread out. I think this is more critical than pressure.
2010-03-25 by designer_craig
Mark, Where did you order the stage calibrator? I need to get a calibrator and a reticle for one of my eye piece for my B&L. Craig --- In Homebrew_PCBs@yahoogroups.com, Mark Lerman <mlerman@...> wrote:
Craig, Ebay, from a company named TaxiMarket . Search under stage calibrator - there are loads of them listed. Mark At 04:35 PM 3/25/2010, you wrote:
>Mark, >Where did you order the stage calibrator? I need to get a >calibrator and a reticle for one of my eye piece for my B&L. > >Craig > >--- In Homebrew_PCBs@yahoogroups.com, Mark Lerman <mlerman@...> wrote: > > > > Has any been measuring the actual trace widths produced with toner > > transfer? I would think that running it through a laminator would > > significantly spread the trace. I just ordered a stage calibrator to > > measure widths with my microscope, but I would be very interested in > > hearing from anyone who had made these measurements. > > > > Mark > > > > > > >------------------------------------ > >Be sure to visit the group home and check for new Links, Files, and Photos: >http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links > > >
If your traces are 10 mil wide and they spread by a mil or so on each side, you might not notice. But that same spread is very noticeable with 7 mil traces. Mark At 11:37 AM 3/25/2010, you wrote:
>--- In Homebrew_PCBs@yahoogroups.com, Mark Lerman <mlerman@...> wrote: > > > > Has any been measuring the actual trace widths produced with toner > > transfer? I would think that running it through a laminator would > > significantly spread the trace. I just ordered a stage calibrator to > > measure widths with my microscope, but I would be very interested in > > hearing from anyone who had made these measurements. > > > > Mark > > > > >I haven't measured the actual traces, but they look identical to the >printout prior to transfer, no visible spreading at all. > > > >------------------------------------ > >Be sure to visit the group home and check for new Links, Files, and Photos: >http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links > > >
2010-03-25 by awakephd
I can't find the recent post where I talked about this (I guess the search function is not yet working right??), but have a look at this test board that I did -- the patterns are 10/10, 8/8, 6/6, and 5/5. As you can see, after etching, the traces are not wider than the spaces; if anything, they are narrower. http://home.earthlink.net/~a_wake/tt_test_closeup.jpg --- In Homebrew_PCBs@yahoogroups.com, Mark Lerman <mlerman@...> wrote:
> > If your traces are 10 mil wide and they spread by a mil or so on each > side, you might not notice. But that same spread is very noticeable > with 7 mil traces. > > Mark > > At 11:37 AM 3/25/2010, you wrote: > > > >--- In Homebrew_PCBs@yahoogroups.com, Mark Lerman <mlerman@> wrote: > > > > > > Has any been measuring the actual trace widths produced with toner > > > transfer? I would think that running it through a laminator would > > > significantly spread the trace. I just ordered a stage calibrator to > > > measure widths with my microscope, but I would be very interested in > > > hearing from anyone who had made these measurements. > > > > > > Mark > > > > > > > > >I haven't measured the actual traces, but they look identical to the > >printout prior to transfer, no visible spreading at all. > > > > > > > >------------------------------------ > > > >Be sure to visit the group home and check for new Links, Files, and Photos: > >http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links > > > > > > >
2010-03-25 by bebx2000
Here is some data on trace measurements with TT, http://www.artemlive.com/cgi-bin/news?c=v&id=751 About halfway down the page. Baxter --- In Homebrew_PCBs@yahoogroups.com, Mark Lerman <mlerman@...> wrote:
Wow, nice research and great result! Mark At 06:39 PM 3/25/2010, you wrote:
>Here is some data on trace measurements with TT, > >http://www.artemlive.com/cgi-bin/news?c=v&id=751 > >About halfway down the page. > >Baxter > >--- In Homebrew_PCBs@yahoogroups.com, Mark Lerman <mlerman@...> wrote: > > > > Has any been measuring the actual trace widths produced with toner > > transfer? I would think that running it through a laminator would > > significantly spread the trace. I just ordered a stage calibrator to > > measure widths with my microscope, but I would be very interested in > > hearing from anyone who had made these measurements. > > > > Mark > > > > > > >------------------------------------ > >Be sure to visit the group home and check for new Links, Files, and Photos: >http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links > > >
