Homebrew PCBs
Developer ate my circuit image - HELP!
2010-04-15 by Steve Maroney
Hey Guys, new here to the group and I love it.
I've tried the Toner Transfer method a few times and wasn't happy with
the inconsistent results, so I tried the photo resist method.
As the subject states, when I put my board in the positive developer
solution, of course it ate away the un protected  areas but also ate
away the circuit image as well.
I'm using this developer:
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1
&productId=156734&catalogId=10001&freeText=156734
And these boards:
https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-
1&productId=156751
I've mixed roughly 1 part developer to 10 parts water.
I've exposed the board / image to a 125 Watt CFL for about 45 mins.  I
wouldn't think longer would hurt anything.
Too strong of  a developer/water mixture ?  Did I keep the board in the
developer too long ? Any ideas  ?
Best Regards,
Steve Maroney
Business Computer Support, LLC
Mobile Phone:504-914-4704
Office Phone: 504-904-0266
Fax: 866-871-7797
Re: [Homebrew_PCBs] Developer ate my circuit image - HELP!
2010-04-15 by Leon Heller
> And these boards:
> 1&productId=156751
Over exposure, probably.
Leon
Leon Heller
G1HSM
Re: Developer ate my circuit image - HELP!
2010-04-15 by James
Yes, it certainly will. Try 4-5 minutes with a 15W fluorescent. I'm fond of those U-shaped tubes for bug zappers, they're unfiltered (/BL) blacklights and work very nicely and are available at any hardware store. They will run from a standard F15 choke ballast and glowbottle starter, the gear from a cheap under-cabinet fluorescent fixture will work fine too. With the use it will get the tube will last pretty much forever so you can just solder wires to the pins and glue it into a reflector with silicone caulk.
Or you could just buy one of the little UV exposure units, but 125W is WAAAAAAAY too much and it's the wrong wavelength.
