My new photo resist spinner
2010-04-17 by designer_craig
I just finished up my new photo resist spinner. Its consists of a plywood box 15" square and 3" high with a modified surplus computer fan mounted in the center. I found a nice 4" Nidec fan with a metal frame and cut off the plastic blades with my band saw. Also took off about 1/2" of the metal frame to allow the fan hub protrude above the frame. I used some JB-weld to glue a 6" aluminum disk to the fan hub. I mounted a push button swithch in the side and power it with a wall-wart transformer. I posted a picture and a short video low quality video clip at: Spin Coater <http://picasaweb.google.com/cschaffter/DYIPCBs#> The board is fastened to the aluminum plate with small loop of masking tape. To coat the board I put about 1/8 tsp of the resist on the board and spread it out with my small brush or my finger. This wets the copper and prevents dry spots when spinning. Then I add another 1/8 tsp in the center and turn on the spinner. I use the power button to modulate the rpm and stop the process by eyeball. I just started playing with the Genesis AQ3000 waterborn negative photo resist and so far I like it. I am getting a nice even coating from the spinner and after baking at 180 deg F the resist is nice and hard with good adhesion. No worry about pulling off the resist with masking tape while doing the second side. I have not etched a board yet but did a test exposure yesterday with an old circuit negative. I think the resist is quite sensitive, but I will know more when I get my UV box built and receive my Stauffer 21 step test strip. Next project will be to build the UV exposure box from a couple of 36W nail polish curing units off ebay. UV lamp <http://stores.ebay.com/eTech-Digital-World__W0QQ_sidZ863785197?_nkw=36w\ &submit=Search> Craig [Non-text portions of this message have been removed]
