Homebrew PCBs
laminator fixed
laminator fixed
2010-05-01 by rlspell2000
Got the replacement rollers from Fellows yesterday. Ran a board after putting it back together. I only put about 1/2 of the original spring tension on the rollers, and I played with the heat setting still the rollers ran at 180C (original highest setting before modification)
I preheated the board at ~150C, 1 minute, flip, 1 minute, then ran the board through the laminator 3 times.
Good adhesion, a significant amount of smearing.
Will adjust temps down a bit more and report results.
Interestingly, the temps aren't linear:
setting   actual (all Celsius)
140       220 (from last time)
120       200
117       196
115       180
110       165
