Homebrew PCBs
HP 45 inkjet video firing
2010-05-08 by Henry Liu
Mass market inkjet control was always a goal of these two groups.
I've developed all the high speed timing/drivers/power to use several of the
HP 45 cartridges.
Watch the following initial test video:
http://www.youtube.com/watch?v=d13WRJaKWF8
The HP 45 has 300 nozzles at 600x600dpi that are all fired in 3 stripe
patterns as a demonstration.
HP 45 cartridges are very interesting for a number of reason:
-low cost, disposable and super cheap (as low as $5) so burning it out just
means you throw it out
-UV curable ink available to print PCBs (I have test results from an UV ink
manufacturer -> this blows away all other pcb methods.  Full cure in 6
seconds).
-bulk ink supply using HP C6119A bulk ink cartridge (same interface):
http://www.addrex.com/hp-c6119a-bulk-black-ink-supply-system.aspx
-high resolution 3d printing
I have an intellectual property license from HP so can fire HP inkjet heads
directly. More importantly I can buy unlimited numbers of cables, printer
stalls and connectors from HP.  Sorry can't share the docs due to NDA but I
will offer a kit soon to integrate these designs into your own printer
design.  You still need FPGA type timing to get it work but I've wrapped it
into a simple C++ DLL over USB.  Right now the interface is simple:
firenozzles(NozzleArray) where NozzleArray has the 300 nozzles (bit packed
into 10x 32bit integers). 1=fire nozzle, 0 = off.
I'm open to suggestions to a MCU interface.  I was thinking high speed 25mhz
SPI mode or can do 3Mbps RS232 or strobed 8bit transfer modes.  300
nozzles*4 colors at 600x600dpi is a LOT of data.
Still lots of work to do but I do have a cost XY gantry already in
production and will show a complete XY printer shortly.
Re: HP 45 inkjet video firing
2010-05-09 by drmail377
HP-45 cartridges are water-based. They dry-out and are notorious for difficult recovery/refill. Why UV ink and not direct etch-resist (Mr. Liu I'm sure you know what I mean)? Why is an FPGA required to do what you want (you provide no substantive details), these cartridges have been driven by even the slowest of MCU's in past projects.
HP-45 cartridges for $5 each - Ha! You are WRONG. The proper way to deal with HP-45's is buy original (difficult, many fakes), get a dozen or so refills out of the original (original 2x45mal Inktec kit for around $10, but these refill kits are also turning up as fakes). I know, I refilled the likes of Deskjets 850 and 970cxi for ages. HP is removing the HP-45 (real not fake) from my market (SE Asia) on purpose IMHO. Getting very hard to find.
David
> HP 45 cartridges.
> seconds).
Re: [Homebrew_PCBs] Re: HP 45 inkjet video firing
2010-05-09 by Henry Liu
I sell direct etch resist kits:
http://www.fullspectrumengineering.com/pcbinkjet.html
As I sell both products I am familiar with capabilities and UV curable ink
is a superior solution.  You need to dry the ink which is a somewhat time
consuming process and UV ink is much harder.  I will show some results when
I have time to etch.
HP 45 original ink is pigment based:
http://h10010.www1.hp.com/wwpc/uk/en/sm/WF06c/A1-12771-64199-69422-69422-3322795-1839940.html
But there is authorized UV curable inks inside HP 45 carts from other 3rd
parties.  I can also sell you a Xaar peizoelectric head and controller at
substantially higher price.
According to google HP 45 carts start at $1.96 and go up from there:
http://www.google.com/products?q=hp+45&scoring=p
The firing pulse generation is under 2us and you need to clock data in/out
at 5mhz on both the rising and falling edges so FPGA solution is easiest but
that's included in my package anyway.
Henry
> find.
> David
> --- In Homebrew_PCBs@yahoogroups.com <Homebrew_PCBs%40yahoogroups.com>,
> the
> > HP 45 cartridges.
> just
> ink
> > seconds).
> heads
> I
> it
> packed
> 25mhz
Re: [Homebrew_PCBs] HP 45 inkjet video firing
2010-05-10 by Andrew Villeneuve
This is interesting, but what's the benefit of driving the jet head directly
from an MCU?  As I understand it, the real challenge is finding a suitable
way to get the ink to resist the etchant.  If you have a process that allows
you to print an etchable design from an inkjet head, than it seems like it
would be easier to leave the printer fully assembled, since it does a much
better job of printing a pattern than one could do manually.
This being said, I can think of some really cool applications for what
you've done here - I just don't think your work is helpful for PCB
fabrication.
-Andrew
> the
> HP 45 cartridges.
> seconds).
2010-05-10 by rlspell2000
I was looking at your kits, and I almost bought one. Then you offered to sell me a 4oz bottle of the "special etch resist ink" for $100...
http://www.inksupply.com/product-details.cfm?pn=MISPRO-4-Y
> Cheers,
> Henry
> > find.
> > David
> > the
> > > HP 45 cartridges.
> > just
> > ink
> > > seconds).
> > heads
> > I
> > it
> > packed
> > 25mhz
