Homebrew PCBs
[Homebrew_PCBs] DLP DS Update
2010-05-24 by Mark Lerman
I am now working on producing ds boards. My first test was to see if
I can print multiple times on one side of a board with good
registration. If I can do that, I'm certain I can do the rest. I
added a reflective sensor to locate the actual position in the motion
(Y) axis. I could have used one of the leftover E260 interrupter type
sensors, but it was easier for me to use black tape an white labels
than to drill holes. In the final version, in the spirit of
recycling, I might use a leftover.  There are some pictures of the
sensor and new mcu board on my pbase site <http://www.pbase.com/mark10970>.
As I mentioned previously, when the carrier moves through the
printer, the leading edge first hits the moving transfer roller,
which pulls it up into the drum/transfer roller interface. This
causes a variable delay, which messes up the registration. The "fix"
is to wait till a couple of inches of carrier is completely through
the interface before starting the actual timing (timing starts when
pis is pulled low).  I still have some work to do, but I'm pretty
sure I can get it to work I printed a test with 5 mil traces - it was
perfect in the Y axis, but about 5 mils off in the x axis. There is a
picture on my pbase site.
One problem I foresee is how to tell whether the sides are registered
before etching. You can't see through the board before it is etched,
and you don't want to etch it without knowing it is correct.
Mark
Re: DLP DS Update
2010-05-25 by sailingto
Mark, you sure are doing some GREAT!!! work and a fantastic job of documenting to allow others to have good results.  My hat's off to  you and THANK YOU for the contribution.
I am pretty happy with my toner transfer now..... but darn, that would be a NICE setup also....  Hmmmmm <:)
I am MORE than impressed with those 2 mil traces... heck, 5 mil is pretty darn good.
Ken H>
Re: [Homebrew_PCBs] DLP DS Update
2010-05-25 by mlerman@ix.netcom.com
One way to do it is to have some registration holes. Print the first side, drill the registration holes, then print the second side and see if they match up. Of course this is dependant on the accuracy of the drilling, but we hopefully will have the camera enabled drill press from a previous thread.
Mark
>From: Mark Lerman <mlerman@...>
>Sent: May 24, 2010 6:54 PM
>To: Homebrew_PCBs@yahoogroups.com
>Subject: [Homebrew_PCBs] DLP DS Update
>Mark
>Be sure to visit the group home and check for new Links, Files, and Photos:
>http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
Re: DLP DS Update
2010-09-08 by smgloser
Hey Mark,
I just wanted you and everyone else to know--you are AWESOME. Documentation is key to a lot of these projects, and your steps made the modifications a BREEZE. I bought the E260 a few months ago, and finally got around to modifying the printer! I just want everyone to know that if you're about to pull the trigger, just do it because the mod is very well documented and easy to do. The only thing I've got to comment on is that the software steps are off from your latest schematic and code, but I've figured that out. I'll probably be publishing code for the PIC12F series in a few days, which I'd imagine might be useful for some with dev toolchain setup.
Once you get the process figured out for yourself, it really does only take <5 minutes per print before etchant. Tape the board, print, heat for 2 minutes at 400F (I use a griddle), and then a few passes through the laminator and you're golden. It's SO much easier than toner transfer, even with transfer paper, and the time savings is definitely worth it for me. You also don't need any serious MechE skills to do the mod, but you will have to get a few things off of McMaster Carr. I'll probably post a few part numbers--I think I found a cheaper version of that drive shaft which works fine.
I've got to admit, I might be saying all of this somewhat early. I'm still optimizing the process at this point, and later I'm planning on working out the E&M and maybe getting control over however the printer adjusts the transfer voltage, which varies depending on substrate and other conditions.
The prints are very very promising so far. I've been printing very large black areas, which I know is most difficult for laser printers, and I am getting pinholes, but much better than what I had with toner transfer. There's still some open areas, but that seems to be because I wasn't very careful with the lubricant spreading. After etching, though, it's very clear that the toner areas are far more solid than I've gotten with toner transfer--there's virtually no leakage through the resist.
I've also tried to print onto metal substrates (specifically aluminum). It works with a few sheets of paper underneath the aluminum carrier, but I'm not sure why. Without them, you get very serious blotching in the image--I intend to work out the E&M calculations sometime in the near future to figure out what's going on. Maybe there's a more optimal stack, or I could try to change the transfer voltage.
Anyway, I just wanted to say thanks--this method is AWESOME. Let me know how double sided is going--it does seem that the feeding configuration doesn't really lend itself to particularly accurate y-axis feeding, but it'd be awesome if double sided worked.
Samson
> Mark
Re: [Homebrew_PCBs] Re: DLP DS Update
2010-09-08 by Mark Lerman
Hi Samson,
Yes, I know that my final design does not fully mesh with the text.
I've gotten bogged down at work and have not looked at this stuff for
months. In conversation with some other people from this group (speak
up if you wish), it seems that the KY can be eliminated by using foil
over the leading edge of the pcb to connect the top and bottom
layers. I'm hoping to get back to DLP in the next month or two -
these are printers that might work even better that the E260.
Mark
At 08:03 PM 9/7/2010, you wrote:
>Hey Mark,
>transfer voltage.
>Samson
> > Mark
2010-09-08 by Jim
Hello Samson
I have also modified an E260d and am getting very good results. I didn't
modify the E260 to the extent that Mark did. I essentially removed all
paper handling parts (front and back) that just left direct access to
the paper platform. I also removed the fuser and removed the EXIT sensor
from the fuser and relocated the EXIT sensor about 1-2 inches past the
TR roller.  I didn't remove (cut) the paper platform as there was enough
clearance for a 0.032 PCB + carrier. For 0.062 PCB's, I took a wood
chisel and shaved the small ridges from the paper platform and that gave
clearance for PCB + carrier thickness of over 0.1 inch. (The TR roller
needs to be removed to do this).
When printing to the PCB, The TR roll is set its design voltage and the
PC roll is set to the opposite polarity. This causes the charge on the
PCB/carrier to be somewhere in between. Depending on the amount of toner
being deposited, the PCB/carrier voltage will vary. I found if I connect
the PCB/carrier to ground,  the printing is much more consistent. I now
use a 0.01 thick card stock paper 7 to 8 inches wide and 18 inches long
with the PCB taped in place and a small wire (#30 wire wrap wire)
soldered to the trailing edge of the PCB. This wire is soldered to a
small copper tape strip on the trailing edge of the carrier. A ground
wire attached to a paper clip is attached to this trailing edge copper
strip with part of the paper clip bent so it will not go through the
added traction roller. This causes an automatic ground disconnect as the
trailing edge of the PCB/carrier enters the printer. I solder the direct
connection because relying on a pressure connection (using a foil strip)
was not reliable. With this direct ground connection, the KY jell is not
required.
I wound up modifying TWO E260 printers. I didn't use the mcu for timing.
I left the input sensors where they were and relocated the EXIT sensor
behind the TR roll. When the PCB/carrier exits the printer, the
PCB/carrier must be removed with in a second or two or a paper jam light
will come on.
I packed everything up last month and took it to our Ham Radio club
meeting and made a presentation to the group. They were amazed at how
fast and how PERFECT the printed patterns were.
With the trace width/spacing this process can do, I had to improve my
etching process to match it!. ( see my posting with a subject line
"Muratic/Peroxide etch".
I will make another posting on this thread as to how to fuse the the
traces to the PCB without using any heat!
Jim KI6MZ
On 9/7/2010 5:03 PM, smgloser wrote:
> Hey Mark,
> Once you get the process figured out for yourself, it really does only take<5 minutes per print before etchant. Tape the board, print, heat for 2 minutes at 400F (I use a griddle), and then a few passes through the laminator and you're golden. It's SO much easier than toner transfer, even with transfer paper, and the time savings is definitely worth it for me. You also don't need any serious MechE skills to do the mod, but you will have to get a few things off of McMaster Carr. I'll probably post a few part numbers--I think I found a cheaper version of that drive shaft which works fine.
> Samson
>> sensor and new mcu board on my pbase site<http://www.pbase.com/mark10970>.
>> Mark
2010-09-08 by Jim
Hello Mark and Samson
Mark, Its too bad your day job interferes with your hobby!
In a previous post today, I briefly described how I modified (with
Mark's guidance) the E260 printer to directly print an toner image to a
PCB or other substrate.
I will now describe how I fix (harden) the PCB pattern to the copper
substrate.
When the PCB exits the printer with its pattern, the pattern is attached
to the PCB by an electrostatic charge. You can BANG the PCB on the table
and nothing comes off the PCB. But if you lightly touch the pattern, it
will smear. The usual way to harden the pattern is to use heat (up to
400 degrees F). Here is a method that uses NO heat.
The toner consists of finely ground poly-ester resin. Acetone will
dissolve this resin. In fact, Acetone solvent is the perfect way to
remove the toner after etching.
To FIX the toner to the PCB, without heat,  in preparation to etch the
board, take a table spoon of acetone and put it in a glass dish that can
be covered and sealed. Put something in the bottom of the dish to place
the PCB on face up. I use stainless steel bolts. Seal the dish with a
glass pane or an acetone resistant plastic cover. Leave the PCB in the
VAPOR of the acetone for at least 2 minutes. Remove the PCB and allow
the acetone vapors to dissipate from the PCB (30 seconds). You can now
touch the toner traces without damaging them and the PCB is ready to etch.
Jim KI6MZ
On 9/8/2010 5:47 AM, Mark Lerman wrote:
> Hi Samson,
> Mark
>> Hey Mark,
>> transfer voltage.
>> Samson
>>> Mark
2010-09-09 by mlerman@ix.netcom.com
Wow - perfect solution to the part that was causing me a lot of aggravation! Great job! It wouldn't surprise me to see a commercial DLP printer in the near future.
Mark
>From: Jim <jhutch17@...>
>Sent: Sep 8, 2010 4:57 PM
>Subject: Re: [Homebrew_PCBs] Re: DLP DS Update
>substrate.
>Jim KI6MZ
>> Hi Samson,
>> Mark
>>> Hey Mark,
>>> transfer voltage.
>>> Samson
>>>> Mark
Re: DLP DS Update
2010-09-09 by jamesmichaelnewton
Hi Ken and Mark,
When Ken says Mark did a fantastic job of documenting, is that a reference to the many photographs on the pbase site, or is there another set of documentation that I missed?
I'm starting a page on DLP on the massmind site:
http://techref.massmind.org/techref/pcb/etch/directlaserprint.htm and I've linked to Marks pbase pictures, but I would love to link to something more if it exists...
James.
> Ken H>
2010-09-09 by Mark Lerman
It's in the files section of this Yahoo Group - Mark
At 01:22 PM 9/9/2010, you wrote:
>Hi Ken and Mark,
>James.
> > Ken H>
Re: DLP DS Update
2010-09-10 by jamesmichaelnewton
Mark, would you be willing to allow me to convert that PDF to HTML and post it on the site at massmind?
PDF's are nice, but they are dead... meaning that they can't be updated with questions, comments, new information from others. The massmind wiki supports living documents which are updated as time goes by and to which others add their experience.
All credit to you for the documentation of course.
James.
> >Hi Ken and Mark,
> >James.
2010-09-10 by mlerman@ix.netcom.com
James,
I guess I have no problem with that. The information is a bit dated in that the conversion can be done much more simply - see the posts by "Jim" - but my original work was designed to be a proof of concept. It morphed into a step by step, but I suspect the E260, though very good for DLP, is not the best printer to convert. I hope to revisit the project in a few months when I have more time.
Mark
>From: jamesmichaelnewton <jamesmichaelnewton@...>
>Sent: Sep 10, 2010 12:35 PM
>Subject: [Homebrew_PCBs] Re: DLP DS Update
>James.
>> >Hi Ken and Mark,
>> >James.
