Homebrew PCBs
Re: [Homebrew_PCBs] Re: light ring conversion for miniature drill press
2010-05-25 by Harvey L. McRae
I use my Dremel tool all the time for drilling my boards.  I use a #70 drill bill.  I don't even use a carbide bit and I have had no problems.
Cheers.
Harvey L. McRae,
838 McKenzie Rd.,
Kelowna, BC. V1X2B3,
www.webs.com/harriscreekcentral
  Sent: Tuesday, May 25, 2010 1:02 PM
  Subject: Re: [Homebrew_PCBs] Re: light ring conversion for miniature drill press
  Is a dremel adequate for drilling pcbs using carbide drills? I know
  it isn't good enough for pcb routing, but just for drilling?? If not,
  what is a good, small, reasonably priced alternative?
  Mark
  At 05:59 PM 5/24/2010, you wrote:
  >On Mon, 24 May 2010 22:40:31 +0200, you wrote:
  > >I think even with a single sided board the light shining through the
  > >center of the pad might be enought to locate it depending on PCB
  > >material. Or one could turn it over, of course.
  >In my experience, trying to locate holes and align them, no. You
  >wouldn't b happy with the results. I'd say either drill from bottom,
  >right side up, or drill from top, top side down.
  >Problem with turning the board over is not the dust collection, it's
  >the large (and bulky) drill mechanism. Clamps are not always needed,
  >but might help. Hydraulics are not needed, but a spring and solenoid
  >might help.
  >It does sound like an interesting project.
  >Harvey
  > >ST
  > >On Mon, May 24, 2010 at 10:37 PM, Mark Lerman <mlerman@...> wrote:
  > >> I was thinking that the board would have to be upside down when you
  > >> drilled it because the camera would have to see the top of the board,
  > >> but you're right, there will be pads on the bottom of the board,
  > >> too. Yes, camera on bottom is probably better, and certainly easier
  > >> to implement. I've got a video otoscope that's made for close focus -
  > >> have to give it a try.
  > >> Mark
  > >Be sure to visit the group home and check for new Links, Files, and Photos:
  > >http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
  Checked by AVG - www.avg.com
  Version: 9.0.819 / Virus Database: 271.1.1/2895 - Release Date: 05/24/10 23:26:00
