> To: Homebrew_PCBs@yahoogroups.com
> From: nuno-t@...
> Date: Tue, 17 Aug 2010 11:44:13 +0100
> Subject: RE: [Homebrew_PCBs] UV: alternatives to glass?
> Hi,
> Have you considered clear acrylic sheets?
> I've been using them for a while on the same UV box that came with normal
> glass on it.
> The difference is considerable in the UV behaviour. Much better for acrylic.
> Flexibility vs. rigidity was solved using a slighter ticker acrylic.
> Nuno T.
> > From: Homebrew_PCBs@yahoogroups.com
> [mailto:Homebrew_PCBs@yahoogroups.com]
> On Behalf Of DJ Delorie
> > Sent: segunda-feira, 16 de Agosto de 2010 21:55
> > Subject: [Homebrew_PCBs] UV: alternatives to glass?
> > Ok, shame on me, I broke the glass in my UV box. Too much vacuum.
> > We've checked a few local places, the glass they have has UV
> > blockers on it. I've got more places to try, but I thought I'd ask...
> > What else can be used besides glass, which will still pass UV
> > without bending or blocking it? Something less brittle, more
> > flexible, but still stiff enough to mostly hold it's shape
> > (my UV box has a foam gasket along the outside edge of a
> > piece of plywood, the glass rests on it and is sucked down
> > onto the board).
> > Even rubber-like flexibility is OK, I suppose - I can make a
> > wooden frame to hold the edges and use an even thinner
> > gasket, but that's more work, and it means I have to cut up
> > my films into individual sections so I don't bend or crease
> > them from the shrink-wrap effect.
> > DJ
> > Be sure to visit the group home and check for new Links,
> > Files, and Photos:
> > http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
