Homebrew PCBs
Difference between FR-4 and CEM material??
2010-08-31 by acidblue
I found some copper clad boards on ebay that use CEM material
instead of the FR-4 that I'm familiar with.
Has anyone used CEM before?
Is it any different from FR-4?
Re: [Homebrew_PCBs] Difference between FR-4 and CEM material??
2010-09-01 by Slavko Kocjancic
acidblue pravi:
Depend's what you want!
Mechanicaly is not so good. If you use shear to cut it the edge is bad.
On the other side the drill bit's last much longer. It's less heat
resistant and has different dielectric constant. But if you do ordinar
hobby project's (not for radio frequency above 100MHz) the CEM is just
good choice.
Slavko.
2010-09-01 by Leon Heller
I've been using CEM-1 for years. It's a fibreglass-paper composite and
is much easier to cut and drill than FR4. I buy mine (precoated) from
Mega Electronics.
Leon
Leon Heller
G1HSM
Re: Difference between FR-4 and CEM material??
2010-09-02 by gandolfreefer
The only caution I would give about CEM is consider your end-use environment: CEM, if memory serves, is more susceptible to wicking water over time, internally, and between layers (in multi-layer boards) in high humidity environments, with eventual (years, but still...) corrosion of traces and connections.
Also, as a side note that might be slightly relevant and perhaps of use to someone here, in tests on Peltier modules, sealing out water vapor, epoxy was the only sealant that performed well. Silicone, surprisingly, did not...I guess it's fine for bathtubs and aquariums, but where there's heat cycling water vapor can still get through the molecular matrix.
The sealants that are used on boards are acrylic based, if I remember correctly. However, potting a board usually involves epoxy. I dunno how well acrylic performs at keeping water vapor out of CEM boards, although I would think a coating of epoxy on all surfaces would work well...the key phrase there being "all surfaces"....
Best, Charlie
> Mega Electronics.
> Leon
> Leon Heller
> G1HSM
Re: [Homebrew_PCBs] Re: Difference between FR-4 and CEM material??
2010-09-02 by Leslie Newell
Yes, silicone is quite porous. It will stop liquid but vapor penetrates
it quite easily.
Les
