Homebrew PCBs
Again on tinning!
Again on tinning!
2010-09-12 by Alessio Sangalli
Hi, I was about to place an order for the precision scale and the
chemicals needed for tinning but:
- I use the H2O2 + HCl method for etching
What was not clear from the thread that was going on several weeks ago,
is if it can be used after etching the PCB and if it delivers a good
result. Somebody reported it may create a layer of high impedence on the
board; as my applications can be low-power electronics to SMPSs, I do
not really like to deal with such "problem".
The tinning method I am referring to is the one explained here:
http://www.voodooengineering.com/index.php/pcbprocess/tinning
And I was going to order the chemicals from:
http://shop.ebay.com/quartzpegmatite/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p4340
as suggested by bebx2000
Thiourea 98% Lab Chemical One Pound  --> $11.99
Stannous Chloride Anhydrous 98% 1/4 lb --> $8.99
Sulfamic Acid 99.8% Lab Chemical One Pound. --> $5.99
What to do? I'm quite confused.
bye
as
Re: Again on tinning!
2010-09-12 by designer_craig
Not to worry, this electroless tin solution works by a redox reaction with the copper and does not deposit any tin on the epoxy.  I used it for years and never had any surface leakage issues.  As with any material its important to wash the board completely to make sure you remove any ionic salts from any microscopic pores and fishers on the material surface.
Craig
> bye
> as
Re: [Homebrew_PCBs] Re: Again on tinning!
2010-09-12 by Malcolm Parker-Lisberg
It does deposit tin on the FR4 surface, and will prove problematic if you have high impedance circuits, it also causes problems when the board is conformally coated, with tin migration under the coating.
Conformally coating the board first and then applying the tin is a better solution for high impedace or low leakage PCB requirements.
It should not be a roblem with normal home PCB CMOS circuits.
Malcolm
I don't suffer from insanity I enjoy it!
--- On Sun, 9/12/10, designer_craig <cs6061@...> wrote:
Subject: [Homebrew_PCBs] Re: Again on tinning!
Date: Sunday, September 12, 2010, 6:49 PM
Craig
> bye
> as
2010-09-12 by Andrew Leech
For what it's worth, I've been using Cool-Amp silver plating powder for a little while on my pcb's now, it's so much easier than any chemical tin plating I've heard of. Previously I was using a hot solder pot (solder in a frypan on a camping oven) using a windscreen squeegee to level the solder. Worked great but not the safest, what with lead fumes and spitting hot molten solder and all.
But yeah, the cool amp is as simple as tapping a little bit of powder onto freshly etched copper, putting a drop of water down on it and rubbing it into the copper (i use my finger). In a minute or two it's silver plated.
Admittedly silver does get tarnished etc so not as easy to solder if you leave it a while, but if I'm making a pcb I'm using soldering it pretty soon in which case it's great.
I don't think I'm getting any surface leakage like this suggestion, I used it on an fpga board that's running at 90Mhz and haven't seen anything to cause concern.
Andrew
> Malcolm
> From: designer_craig <cs6061@...>
> Craig
> > bye
> > as
2010-09-13 by Alessio Sangalli
Do you have more data on this? This is chemistry, I am not qualified to
understand the process for which the tin may deposit on the board, but:
- is this measurable?
- how much it changes a board? Can one see it with a multimeter?
- do you have any kind of number or data?
bye
as
2010-09-13 by Bob Macklin
I just checked a PCB that was tinned with Datak "TINNIT". There is no
measurable resistance between adjacent traces.
Bob Macklin
K5MYJ
Seattle, Wa.
"Real Radios Glow In The Dark"
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Sunday, September 12, 2010 9:04 PM
Subject: Re: [Homebrew_PCBs] Re: Again on tinning!
> bye
> as
> Be sure to visit the group home and check for new Links, Files, and
> Photos:
2010-09-13 by Malcolm Parker-Lisberg
Alessio
The high impedance present due to electroless tin manifested itsself on a sample and hold 14 bit A to D circuit and associated amplifier. Six boards had excessive errors whilst two worked perfectly. The two working boards were not electroless tin plated. The effect of the tin caused the sample and hold capaicitor DC value to droop during the A-D conversion. It could not be measured with a multimeter. The associatd DC amplifier had incorret gain, The leakage across the gain setting resistor was sufficient to cause errors. All the boards had been cleaned in Arklone to remove flux residues.
Malcolm
Date: Monday, September 13, 2010, 5:04 AM
bye
as
2010-09-14 by Larry Battraw
On Mon, Sep 13, 2010 at 5:57 AM, Malcolm Parker-Lisberg
<mparkerlisberg@yahoo.com> wrote:
> Alessio
> Malcolm
To sum up, unless you are using circuits that are going to be affected
by very minute amounts of resistive coupling (probably 10's or 100's
of megohms) you're going to be fine.  As mentioned above, there was a
small capacitor that was being discharged by the slight conductive
layer of tin over the entire board, and in this type of high-accuracy
circuit even a few micro-amps of leakage is too much.  Probably not an
issue unless you're working with very high-impedance circuits with
MOSFET-input op-amps, instrumentation amplifiers, and medical
equipment meant to measure extremely small changes in voltage and
current (As well as needing to be almost perfectly isolated).
High-voltage circuits may also be affected (maybe 1KV+) since leakage
current corresponds directly to voltage.  I would be curious to know
if there would be a certain voltage where the conductive layer would
be vaporized between the traces at the highest potential.
There might be one last problem triggered where you could have traces
running over or around the tin-contaminated area at microwave
frequencies, which might produce odd problems with parasitic
capacitance, particularly with amplifiers (Or amplifiers suddenly
becoming oscillators!) or oscillators themselves undergoing unwanted
frequency shifts.
Larry
2010-09-18 by acidblue
Has any one have any experience with MG Chems. liquid Tin?
http://www.mgchemicals.com/products/421.html
Seems a lot easier to use.
Here it is at Mouser:
http://www.mouser.com/search/refine.aspx?N=4294953381&Keyword=liquid%20tin
2010-09-19 by mlerman@ix.netcom.com
>From: acidblue <sunblaster5@...>
>Sent: Sep 18, 2010 7:06 PM
I use it all the time - seems to work fine.
Mark
2010-09-19 by Alessio Sangalli
Sure but what is the shelf life? I do not make so many boards... and
anyway, how can it be "easier" it works the same way: you have to put
the PCB in the liquid and wait few minutes
bye
as
2010-09-19 by Bob Macklin
I just used hot tap water and the TINNIT works fine.
It has no shelf life until mixed.
Bob Macklin
K5MYJ
Seattle, Wa.
Sent: Saturday, September 18, 2010 6:18 PM
> The other brands like "Tinnit" you have to mix it up in hot water over
> the stove.
> Liquid Tin there isn't any mixing
> Photos:
