Homebrew PCBs
Etching with Ferric Chloride
2010-09-20 by csit044
Getting back into this after many years absence, and am looking to etch my first simple PCB - the idea is to create the mask via a laser printer on inkjet photo paper, and then 'ironing' on the mask and etching with ferric chloride. My question is what do people do with the 'used' solution - I used to stick it back in the bottle and replace it when it took too long to etch a board, ie it was 'saturated'?
Is this a good approach or is it better to use (fresh) small amounts each time and dump it, in which case where?
In any event I would end up with a bottle of old etchant to get rid of, is there a safe/green approach?
Any comments/observations are welcome
Thanks
Chris
Re: [Homebrew_PCBs] Etching with Ferric Chloride
2010-09-20 by Malcolm Parker-Lisberg
Look up Edinburgh Etch, by adding citric acid to the ferric you can make it last a long long time.
Malcolm
I don't suffer from insanity I enjoy it!
--- On Mon, 9/20/10, csit044 <parsons.cj@...> wrote:
Subject: [Homebrew_PCBs] Etching with Ferric Chloride
Date: Monday, September 20, 2010, 1:27 PM
Thanks
Chris
2010-09-20 by Leon Heller
I make up a litre of the FeCl3 solution. I use a small quantity each
time, with constant agitation in a small container with an outer
container of very hot (just boiled) water. I just pour it back into the
bottle when I've finished. It does lots of boards.
Leon
Leon Heller
G1HSM
