Homebrew PCBs
Eagle layout
Eagle layout
2011-02-12 by RL
I need some help getting to the next level in this whole
complex PCB design. I designed a PCB using the Egale software,
the sch. and board, but I got hung up on getting it from there to
my CNC. When I coverted the board to a dxf and then to a gcode the
file was huge, and did not appear to be close to routing a actual
board. It sound like a lot of you are using print a silk screen
process, but I have a small CNC I would like to use.
So I would like to get it to the route/ drill stage,
even if it is just a test board to see how the whole process works.
Any help will help, I have read alot of info and totorials but did not
find alot of help on this.
Thanks, Mark
Re: [Homebrew_PCBs] Eagle layout
2011-02-12 by Paul Ward
This is from a reply I posted to the list about two weeks agoŠ
Generating Gcode from Eagle:
Once you've designed a layout, you'll need to generate gcode from the board.
Eagle has a user expandable scripting feature called ULP.  I've seen quite a
bit of discussion about a ULP script called pcb-gcode.  You can find it at
the Eagle ULP download page
(http://www.cadsoftusa.com/cgi-bin/download.pl?page=/home/cadsoft/html_publi
c/download.htm.en&dir=eagle/userfiles/ulp).
From what I've read, the Gcode that pcb-gcode creates is not very well
optimized.  There's another ULP on that same page that will supposedly
optimize the generated gcode called pcb-gcode-wizard.
Reply-To:  <Homebrew_PCBs@yahoogroups.com>
Date:  Sat, 12 Feb 2011 13:42:22 +0000
Subject:  [Homebrew_PCBs] Eagle layout
Thanks, Mark
