Homebrew PCBs
Problems with GBC H220
2011-02-18 by acidblue
Just bought a GBC H220 and must say I am very disappointed, and plan on bringing it back.
I cannot get the toner to transfer to the pcb.
I am using the Pulsar toner paper and following the directions from their site.
I have tried as little as 5 passes and as much as 12, the toner will just not transfer, only a little bit has, but washes right off with water.
I don't get it, this is the laminator they recommend on their site.
I am using a HP Laserjet 2200D and have used the clothes iron process before with success, so I know it's not the toner,
I bought the H220 so I could get consistent results as sometimes using the iron method is a PIA.
Anybody else having problems with the H220?
I've tried both 3mil and 5mil settings.
If anybody has any insight please let me know
Re: [Homebrew_PCBs] Problems with GBC H220
2011-02-19 by Jan Kok
The H-220 works a lot better if you swap the two gears between the
motor and the rollers in order to slow down the rollers. The mod is
described at http://www.pulsarprofx.com/special/h-220/
2011-02-19 by rocko
Thanks I swapped the gears and after 5 passes I got almost perfect
traces, about 80%
Tomorrow I'll try 7-10 passes.
Been using the Pulsar toner paper, but I like to try magazine paper as I
hear it's just as good.
> their site.
> water.
Re: Problems with GBC H220
2011-02-19 by leeleduc
I've been using the GBC H220 for a few months now and it works fine. Changing the two gears helps. I set the thickness for 5 mil. Also, you should ignore the "beep" that says it's ready and let the unit preheat for at least 20 minutes. I can get a good transfer using Pulsar paper with 2 passes doing this.
Re: [Homebrew_PCBs] Re: Problems with GBC H220
2011-02-19 by rocko
Thanks for the tip. :)
Yeah I kinda noticed I was getting the "Beep" after about only 10
minutes, even though the manual says can take up to 30min.
> their site.
> water.
