Homebrew PCBs
Harbor Freight Laminator
2011-10-20 by leeleduc
Just tried a Harbor Freight 9" laminator (#92499) costing $28. The box it came in says it reaches 300 degrees. After a 0.032" board was run through a few times,it was very hot to the touch. Shows promise. I've posted a photo of my first try in the Harbor Freight Laminator file. The board outline is 10 mil in width. Looks like it may be a viable, inexpensive laminator.
Printer used: Samsung ML-2525W
Paper used: Staples Color Laser Paper #633215.
I'm going to try this again when my Pulsar TTP arrives. Pulsar is the paper I usually use.
Re: [Homebrew_PCBs] Harbor Freight Laminator
2011-10-21 by jeremy hodder
that Laminator is currently on sale 19.99
http://widgets.harborfreight.com/wswidgets/common/displayCoupon.do?week=4211&campaign=b&page=coupon14.html&single=true&cust=00138550794&keycode=1003
> I usually use.
Re: Harbor Freight Laminator
2011-10-22 by nps0
For what it's worth, I just got an HF coupon for this laminator for $19.99.  For that price, I had to try it.  I'll light it off tomorrow for a try.  It's also cheap enough to take it apart and see if it can be worked over to accept thicker boards - I prefer to work with .062 stock.  I can send copies of the coupon, if anyone else is interested.
Norm
W6NIM
2011-10-22 by leeleduc
This laminator feeds faster than my GBC. It runs at 12 inches per minute. I ran my 2X4 inch board through it 8 to 10 times. I also let it warm up for about 30 minutes before using it.
> Norm
> W6NIM
RE: [Homebrew_PCBs] Re: Harbor Freight Laminator
2011-10-22 by MIKE DURKIN
Is this to be used instead of a toaster ivan to set ink?
Mike KC7NOA
Date: Sat, 22 Oct 2011 14:06:53 +0000
Subject: [Homebrew_PCBs] Re: Harbor Freight Laminator
> Norm
> W6NIM
Re: [Homebrew_PCBs] Re: Harbor Freight Laminator
2011-10-22 by Donald H Locker
Used for toner transfer - laser printer toner printed on magazine or some other special papers can be melted off of the paper and onto circuit board copper laminate.  The plastic toner acts as etch resist.
Look for more posts here about toner transfer.
Donald.
*Plain Text* email -- it's an accessibility issue
()  no proprietary attachments; no html mail
/\  ascii ribbon campaign - <www.asciiribbon.org>
> From: "MIKE DURKIN" <Patriot121@...>
> To: "homebrew pcbs" <homebrew_pcbs@yahoogroups.com>
> Sent: Saturday, October 22, 2011 10:12:39 AM
> Subject: RE: [Homebrew_PCBs] Re: Harbor Freight Laminator
> Mike KC7NOA
> From: leeleduc@...
> > interested.
> > Norm
> > W6NIM
> Be sure to visit the group home and check for new Links, Files, and
> Photos:
2011-10-23 by bklyngrrl1
Would greatly appreciate a copy of the coupon!  Any idea if the laminator will work with sheet metal?  It's heavier, so just wondering if the laminator's motor will be strong enough to pull the pieces through.  (I don't make PCBs, I'm an artist, but the transfer and etching techniques I use are the same and this group is an amazing resource.)
> Norm
> W6NIM
2011-10-24 by leeleduc
Laminator Coupon, expires 10/26.
http://widgets.harborfreight.com/wswidgets/common/displayCoupon.do?hdr=mag&week=4211&campaign=b&page=4211b_retail.html&cust=99999999999&keycode=1002
> > Norm
> > W6NIM
2011-10-25 by bklyngrrl1
thanks!
> > > Norm
> > > W6NIM
2011-10-25 by Donald H Locker
Laminator should work with sheet metal if it's not too thick.  I don't have experience with this particular laminator, but many printed circuit boards are 1/16 inch (1.6mm) thick.  If your sheet metal is thinner than that, you shouldn't have a problem.  It may take several passes to get it up to temperature, but you have to do that with circuit boards, too.
What sheet metals do you use?  I'm thinking of trying to etch or electro-etch some titanium sheets and would accept any guidance.
HTH,
Donald.
> From: "bklyngrrl1" <alltrouble@...>
> To: "Homebrew PCBs" <Homebrew_PCBs@yahoogroups.com>
> Sent: Sunday, October 23, 2011 1:28:43 PM
> resource.)
> > interested.
> > Norm
> > W6NIM
> Photos:
I use mostly non-ferrous metals - copper, brass, bronze, nickel silver, etc.  Stainless and mild steel are next on my list of metals to try, but that means switching etchant.  (I'm working with muriatic acid etchant, but would have to switch to ferric chloride I think.)  I haven't worked with titanium yet.  Not sure what the etchant is for that - any idea?
> HTH,
> Donald.
> > resource.)
> > > interested.
> > > Norm
> > > W6NIM
> > Photos:
Etching Titanium (was Re: [Homebrew_PCBs] Re: Harbor Freight Laminator)
2011-10-26 by Donald H Locker
I'll let you know when I figure out a safe one.  I believe HydroFluoric (HF) acid etches it quite well, but is extremely hazardous to handle.  Most of the formulae I've seen use HF and H2O2.  Sorry to all that we've wandered a bit off-topic.
Donald.
> Sent: Tuesday, October 25, 2011 3:53:08 PM
> that - any idea?
> > HTH,
> > Donald.
> > > wondering
> > > resource.)
> > > > > The
> > > > > board
> > > > > Shows
> > > > > Freight
> > > > > like
> > > > > is
> > > > for
> > > > tomorrow
> > > > can
> > > > .062
> > > > interested.
> > > > Norm
> > > > W6NIM
> > > and
> > > Photos:
> Photos:
Re: Etching Titanium (was Re: [Homebrew_PCBs] Re: Harbor Freight Laminator)
2011-10-26 by David Griffith
If you're interested in pursuing Ti etching, try a mechanical approach.
Suppose we put a pattern on a sheet of thin rubber, then dissolve away
what we don't want.  Use that rubber as a mask for sandblasting.
David Griffith
dgriffi@...
A: Because it fouls the order in which people normally read text.
Q: Why is top-posting such a bad thing?
A: Top-posting.
Q: What is the most annoying thing in e-mail?
2011-10-26 by IƱigo
Forgot about HF. It can kill you quite easily.
2011/10/26 David Griffith <dgriffi@...>
> David Griffith
> dgriffi@...
> A: Top-posting.
RE: Etching Titanium (was Re: [Homebrew_PCBs] Re: Harbor Freight Laminator)
2011-10-26 by Tony Smith
> > HydroFluoric
what we
Laser the pattern instead (vinyl or plastic masking), then sandblast.
Common enough technique.
Tony
2011-11-01 by arvidj01
For what ever reason this just showed up on November 1st. The coupon expired on October 26th.
Never mind.
--- In Homebrew_PCBs@yahoogroups.com, jeremy hodder <hodder.jeremy@...> wrote:
> > I usually use.
2011-11-02 by Larry Battraw
For the record I have tried .040, .062, and (barely) .080 through it.  .040
and .062 seem to work fine in it as long as you're not trying to run a
board wider than around 6 inches in it.  .080 was a stretch and needed
assistance to make it through successfully.  Mind you these are bare boards
without anything like toner transfer paper or photoresist on them.
Larry
> through a
> photo
> is
> paper
> > I usually use.
2011-11-03 by Mike
Hello,
Just finished running a 0.062 double sided pc board with Techniks Press and
Peel toner transfer through the Harbor Freight Laminator, Model 92499.  The
toner was put on the Press and Peel using a copy machine at a big box
store.  After seven runs through the Laminator, the result was mixed at
best.
First, the circuit was not transfered evenly over the length of the board.
Second there was a series of pin holes in the toner transfered to the board
- as if a roller in the Laminator is a diamond pattern (or whatever this is
called).
Haven't opened up the Laminator to see what is inside.  Anyone else getting
any results using the Harbor Freight Laminator?
   73,
   Mike, K4GMH
2011-11-03 by Tim Hills
Been lurking for a while and it's been years since I had Ferric Chloride
stains on my fingers.
Just a thought or 2 on laminators.
Has anyone tried adapting a plain paper copier fuser roller? Widen the
gap and slow it down, I don't see why it wouldn't work.
When I was repairing them 30 years ago a local Ham bought one of our
scrap units for the purpose of using toner transfer onto blank boards.
That was coated paper to transparency then fused to the Copper clad.
Never laid eyes on it but later I did ask him about it. He changed out
the adjustment bolts for longer ones to widen the gap between the
rollers and upped the temp a bit. Silent Key now so exactly how he did
it may be forever lost.
When I worked for HP in the late 1990s they were using Laserjets for
direct printing onto prototype boards. They had the R&D department so I
doubt that's something I could do in my basement with a vice grips and
duck-tape...
Still, the modern low end dry toner printers use heat and pressure to
fuse the toner and it seems to me that they could be used. The fuser
drums (mostly) have an almost mirror polish and operate as high as 450F.
Just a suggestion, I have too many Irons in the fire as it is.
Tim Hills
In both cases the printers were modified
On 11/2/2011 22:09, Mike wrote:
> Hello,
> Press and
> best.
> board
> this is
> called).
> 73,
> Mike, K4GMH
2011-11-03 by Harvey White
I have one as a potential project, stalled as any number of projects
are due to real life(tm).
Not that hard.  Slow it down, temperature ought to be pretty good if
the board gets that hot, then make sure that you can adjust the
spacing to fit the board.
You'll have to experiment with a few things, I think that pressure is
rather important.  Keeps the pattern from spreading when you get it
right.
>duck-tape...
Laser printer fuser roller, temperature controller, thermocouple, DC
motor with small power supply, Bet you could do it in your basement.
(leave out the tape....)
Old laser jets at thrift stores for me.
Know that one,
Harvey
>Tim Hills
>> Hello,
>> Press and
>> best.
>> board
>> this is
>> called).
>> 73,
>> Mike, K4GMH
2011-11-04 by Mike
Opened the Harbor Freight Laminator and found the cause of having to shove
the board to get it to start progressing through.  The upper and lower
aluminum assemblage which houses the heater elements has a couple of lips
through which the board has to pass.  This opening between the upper and
lower aluminum assemblages was just too small to allow the board and the
toner transfer material to freely pass  before being taken up by the rubber
heat transfer rollers.
There is enough play in the plastic end brackets holding the aluminum
assemblages to expand the opening to allow the board and toner transfer
material to pass.  A piece of 0.062 double sided PCB wrapped in aluminum
flashing was wedged between the two aluminum assemblages to maintain the
opening.
A board with a Techniks Press and Peel toner transfer circuit was passed
through the Laminator over eight times, but, unfortunately, the toner was
not evenly transfered.  Suspect the board was not getting hot enough even
with all the passes.
The Laminator is advertised to get up to 300 F (Techniks Press and Peel
directions says the temp. should be between 275 - 325 F).  However, doubt
if anything near that temp. is getting transfered to the board by the
rubber like rollers.  Next step is to make the Laminator's temp. adjustable
so it can get hotter and/or slow down the motor driving the rollers pulling
the board through the Laminator.
On Wed, Nov 2, 2011 at 11:09 PM, Mike <k4gmh@...> wrote:
> Hello,
> and Peel toner transfer through the Harbor Freight Laminator, Model 92499.
> The toner was put on the Press and Peel using a copy machine at a big box
> best.
> board.  Second there was a series of pin holes in the toner transfered to
> the board - as if a roller in the Laminator is a diamond pattern (or
> whatever this is called).
> getting any results using the Harbor Freight Laminator?
>    73,
>    Mike, K4GMH
   73,
   Mike, K4GMH
2011-11-06 by kx4om
Some Laser printers have toner that melts at considerably higher Temps. Tech support at Techniks told me this a few years ago. Use the search feature for many discussions on this issue and various paper media. The Brother printers (I had one of the early ones) use high temp toner. The best success I had was printing on catalog paper.
I used an old-type iron to transfer the brother output to PC boards employing a digital turkey thermometer to set the high temp needed (mine has a long flexible lead to the sensor prong.)
For Press and Peel Blue work, I take the ink jet copy to a library or print shot and have them copy it onto the blue sheet. I use the iron preheated to about 325 degrees for these transfers.
2011-11-17 by Mike
Hello,
Got back to the seeing what are the limitations of the inexpensive Harbor
Freight Laminator for use with toner transfer.
The temp. is not fixed nor can it be adjusted.  The temp. is controlled by
a simple open/close thermostat.  The thermostat is attached to the extruded
aluminum used to hold one of the heating element (bottom one).  The
thermostat allows the aluminum to have a heat variation from 278 F to 230
F, as measured by a thermocouple.  Do not have a temp. measurement of the
rollers that will transfer the heat/pressure to the toner transfer material
and PCB.
Although the thermostat has a 40 degree max. - min. temp. range, Press and
Peel says a temp. between 275 -325 F, 50 degree variation, should be used
for toner transfer.  By the way the Laminator does have a 180 C max. cut
out in line with the heaters and mounted on one of the aluminum heater
holders.
Now  a way to set the temp. within the 275 - 325 F range and is needed
(will have to remove the thermostat).  It should be simple as the Laminator
cost less than $20.  Any ideas would be welcome.
   73,
   Mike, K4GMH
> opening.
>> Hello,
>> best.
>>    73,
>>    Mike, K4GMH
>    73,
>    Mike, K4GMH
   73,
   Mike, K4GMH
2011-11-17 by Tony Smith
for
> toner transfer.  By the way the Laminator does have a 180 C max. cut out
in
> line with the heaters and mounted on one of the aluminum heater holders.
(will
> have to remove the thermostat).  It should be simple as the Laminator cost
less
Here ya go:
http://www.dealextreme.com/p/digital-temperature-controller-66334.
Or http://www.dealextreme.com/p/digital-temperature-controller-66125,
48x48mm vs 76x76mm for the first one.
http://www.dealextreme.com/p/omron-e5c2-temperature-controller-ac-220v-81620
if you don't like LEDs & buttons.  Cheaper too (but presumably no autotune).
The relay in these will only handle 3 amps, you might need to add one to
switch the laminator (easy to replace the existing one though).
Plenty of these on eBay as well (DX are pretty slow to ship at times).
Tony
2011-11-17 by Bob Butcher
I noticed these are 220 VAC controllers and I am not sure if they would work on 120 VAC. The two links to the digital controller do not work.
Bob
2011-11-17 by Jeff Albrecht
Looking around on ebay I found this and a mind dazzling array of others
temperature controllers and thermocouples http://bit.ly/skd09n They also had
bi metallic thermostats.
If I'm reading the spec sheet there is an internal relay capable of
switching 220 at  amps. And a digital out for electronic relays.
Contact capacity of output: 250V AC 3A (resistive load)
Voltage pulse output: 0/12V (suitable for solid state relay SSR)
I think the bottom line for me is to first determine which laminator to
obtain. If the new GBC laminators can be converted like the older ones that
have been successfully hacked by members of the homebrew_pcb community.
-                      jeffa
Bob
2011-11-17 by Norm
If you want to try one - - -
product15
barcode
ftr
2011-11-17 by Norm
> product15
> barcode
OOPS!  The coupon didn't come thru.  Anyway, it's available for $19.95
until the 23rd.
There's about a billion variations of these.  Re-post of the links:
The first is a REX C700, the second a REX C100, Google those and you'll be
kept out of trouble for hours.  Those two are basically the same, the first
is a bigger physical size and can set to control a freezer rather than just
a heater, not sure about the second one.
Manuals here: http://www.rkcinst.co.jp/english/product/single2-e.htm under
REX Century Series.  The manuals aren't much use unless you know what you're
doing, btw, but they're not hard to figure out.  The code on the side of the
unit tells you what features it has.
These are 220v, but you can get them in 12v, 24v, 48v, 120v and 100-250v.
Relay only (3A) on these, but some will control a solid state relay (SSR).
These can too if you open them up, pull out the relay and run the 12v out.
Or just replace the relay with a 10A version or whatever your laminator
needs.
The alarms are handy too, hook up a big light so you can see when it hits
temperature.
The more expensive ones simply have more options, like accept different
sensors, bigger ranges, dual control (heat & cool so you can maintain a bath
etc), network output, logging and so on.
These are fine for a laminator, and for under $20 cheaper & simpler than
anything you could build yourself.  You can get timers in the same format as
well, they're handy.
Tony
switching 220
obtain. If
> the new GBC laminators can be converted like the older ones that have been
> -                      jeffa
work on
> Bob
2011-11-17 by kabowers@NorthState.net
>Bob
Take a look at SKU# 66334 at dealextreme.
Keith Bowers WB4LSJ- Thomasville, NC
2012-07-28 by zawy
The Harbor Freight Laminator is a good thing because they keep the same items for years and years, so posting our experience with it could help others. It's also as simple as a any device gets (no electronics) and takes apart completely and unusually easy.
Currrently $25, $5 off.
Max thickness:
0.025" in instructions (error on website saying 6 mm instead of 0.6 mm)
A poster here said 0.080" could be pushed through.  Another said a simple modification (which he detailed about spreading a plastic gap wider with a piece of 0.064" and alumunium sheeting to make it a little wider) allowed double-sided 0.064".
Temperature:
There is a 185 C 1-shot temp FUSE, a 90C 5A rectangular bimetal NC switch on the top heating element that only turns on a green "ready" LED (it shorts the LED below 90C), and a round 125C 10A bimetal NC switch on the bottom heating element that turns off the heating element.  This switch turns back on when it drops to 110C (230F). There are no electronics in it except for 2 LEDs with supporting 100k resistor and rectifier.  The 5 RPM 4W 120AC synchonous motor (TYJ50-8A, many of them on ebay) is simply wired in parallel with the heating element after the main on/off switch.  Synchonous means the speed is set by 60 Hz, so I don't know if 2W of 15k series resistance can slow it down at a given torque without harming it.  Someone mechanically inclined could put in a smaller 1/4" "half-moon" shaft gear (1.5 cm diameter for half speed instead of 3cm), but then a new support for the motor would need to be created. I might do it if I come across that gear, maybe even 1 cm.  There were 26 2mm teeth on the 3 cm.
Both temp switches can be bought on ebay (they are the only bimetal switches for sale on ebay) at 150C (300F), and the round one is also available at 180C (350F).  I'm going to try it with the high temp ink of a brother printer.   They're only a couple dollars, but you have to buy 5 and pay $9, half the price a nice thermal controller on ebay or the previous links people gave.
The specs say it's only a 3A device, so the rectangular temp switch should work and two 300F are on ebay for $3, including shipping.  At least I can replace the 90C switch with one of these so it will tell me when it's really up to temp.
I'm curious as to what temperature the rubber rollers start to give off a lot of fumes.
2012-07-30 by zawy
The digital temperature controller looks nice and hard to figure out, but I'm going to use my multimeter's thermocouple (the first time I've ever used it) to watch the temp, and use a mechanical switch to bypass the thermal limit, in addition to the 150C new bimetal switch that is in the mail.   I saw an easy to use (hardly adjustable) analog temperature controller on ebay for $15 that accepts an L thermocouple which is outdated but within a couple degrees of type J.
== Motor Speed ==
I used a 555 timer in astable mode with a bypass diode (see wikipedia) to get <50% on time, to control a relay to turn the motor on and off to more slowly feed the PCBs.  After reading a little about synchronous motor speed changing, this seemed by far simplist method.  This model's 12"/min means 5 mm per second, which means the width of a PCB hole is covered in less than 200 ms.  After experimenting, I found the shortest possible on time for this motor and gear assembly without skipping is 150 ms, which is 9 times longer than 1 AC cycle of 17 ms which the motor can't even theoretically get down to.  So, I can make it feed 1 hole width and stop for however long I think the rubber next to the heating elements is not melting.  Others have said 4 or 5 passes is needed, so 4 times off-to-on ratio seems about right.  Maybe less since multiple pass allow cooling.  I'm drilling a hole in the laminator's plastic case to include a potentiometer adjustment to control the 555 circuit to go from the motor being constantly on (POT at zero, the "off" time) to about 4 times longer than the "on" time.  This has worked out a lot better than I expected, but I haven't tried it to see how bad it might create lines from stopping and starting.  It might depend mostly on the transfer method and chosen temperature.
My parts list, which I had on hand:
LMC 555NC to burn out before realizing my 12V adapter puts out 16.3V under low current conditions.
LM555 which can take 18V instead of 15V
12VDC relay capable of driving 6A 120VAC
1 uF for astable
220k for on time (150 ms)
1M pot off time (693 ms)
diode
2012-07-31 by KalleP
Laminator ideas (untested :-).
If you are ok with reading a manual you can work out most temperature controllers, it is a single setpoint so not rocket science.
The correct way to slow those tiny motors is to drop the frequency.
You would need to make a low wattage inverter and then use a mains:6V transformer backwards to drive the motor.  They will be happy with a square wave (or a three level sine wave approximation) as long as they do not over heat and this you can control with the voltage.  You should be able to control from 30 to 150% without too much trouble I recon. They are essentially el-cheapo stepper motors with one winding proken and could be replaced with a low voltage flat stepper and suitable drive circuit if you find a reasonable mechanical fit you gould sprice on to the input rotor shaft, a little stepper will not direct drive the rollers reliably.  It would let you run it fast when idle to have evenly distributed temperature and then run slowly at any speed you want to feed a board through.
The AC motors may give slightly erratic results if you use a stop start method to regulate the speed as they are usually single phase motors that start in either direction, there is a tiny little cam inside that causes the motor to hit a stop and bounce into the opposite direction half of the time when it starts, takes less than one turn of the rotor to engage so not likely to be much distance but still a random variable that might be better left out.
> cooling.
In one office I visited years ago they had a interesting laminator that had two sets of rollers with radiant heating between them, the rollers would also warm up, so the material was pushed and pulled carefully through.  With these home/office laminators it might make sense to put two of them one behind the other (lot of work), one would do the bulk of the heating of the substrate and the other would then squash the evenly heated stuff together, perhaps more pressure on the second roller.
Kalle
Johannesburg, South Africa
2012-08-01 by zawy
I thought a temp controller should be easier to figure out, and I guess once I had it in hand the 4 pages of instructions in the 8 page manual would convert from japanese to english. It might be interesting solve the riddle of what the following terms in the manual mean when programming it:
LBA deadband
autotuning
proportional band/cycle
integral time
derivative time
anti-reset windup
proportional cycle
For example, I know what an integral is, but I don't understand their bad-English explanation: "eliminates offset occurring control is performed".
I could not tell from ebay which controller I would be getting: what type of thermocouple it needed, if it included a thermocouple, and if it had a relay or voltage output, as determined by the unseeable extended model number.  I also could not tell from the contradicting manual if the relay was 1A or 3A at 240VAC, the second being enough for the heater, the first requiring my own relay.
So, I put a switch on it and stuck in my MM thermocouple.
My ugly but simple control of the motor worked good.  No "jerk" lines showed in the final product.  I didn't have the parts on hand to change the frequency.  It seems to work better with 2 passes instead of one, another less perfect alternative to your double laminator.  The second pass could be made higher pressure as you suggest by using an aluminum plate, although this would reduce the heat.
If I wasn't using a brother printer, the control of both temp and motor speed should allow 1 pass with good results, where I see others in the database using 3 to 12 passes with better printers and more expensive laminators (not including my time for the motor control circuit).  Maybe they are using paper that's less optimal than my press-n-peel.  I'll test the HP photo laser paper soon, and then maybe staples.
2012-08-01 by Tony Smith
once I had
from
following
> LBA deadband
> autotuning
> integral time
> derivative time
> anti-reset windup
> proportional cycle
Ignore everything bar autotuning - it sets most of those options for you.
They are pretty simple, but it's one of those things that's simple when you
know how, but in general you set the temperate you want, run autotune and
that's it.  You won't find a 'Dummies' guide, like most industrial stuff
you're supposed to know what you're doing if you buy one.
The manuals are generic and list every possible option, it's unlikely the
controller you buy supports it.  For example one I brought has a C/F degrees
display option, you can change it but it only shows Celcius (fine for me,
YMMV).  The $20 eBay ones are usually REX C100 series clones, Google will
find plenty of info.
For a laminator these are fine, bearing in mind the output is a 3A relay.
'LBA deadband' triggers an alarm if the controller detects the heater isn't
warming up fast enough, so for an oven maybe you left the door open or
something.  Nice but not something you really need.
Tony
