Homebrew PCBs
Re: [Homebrew_PCBs] Re: Sponge etching with HCl and H2O2?
2011-11-27 by Piers Goodhew
Still, if something can be reused, no shame in that.
I've been to nz several times. It was great except all the cakes were unleavened due to the prohibitive cost of NaCO2...
PG
Sent from my phone, anything lewd or incomprehensible is probably autocorrect and not my fault.
----- Reply message -----
To: <Homebrew_PCBs@yahoogroups.com>
Subject: [Homebrew_PCBs] Re: Sponge etching with HCl and H2O2?
Date: Sun, Nov 27, 2011 3:28 pm
No worries, I can understand your point of view.
However having never actually purchased any I had no idea of the price, nor do I live in USA and in my country (New Zealand) things can be a bit of a ripoff.
For example, You can buy this (almost 1 litre) of hydrogen peroxide for $2-3
(http://www.instructables.com/id/Stop-using-Ferric-Chloride-etchant!--A-better-etc/#step1) but it costs me $3.50 just for 100ml (about 10 times the price!)
No local shop sells more than 100ml bottles either, you can special order larger ones but the price is even worse for some reason. (have they not heard of bulk discounts?)
Take the HCl too, according to that instructable, "The acid I got is 31.45% (or 10M) and should run around $5 per gallon"
Google tells me 1 US gallon = 3.7 litres, yet 1 litre of HCl here is $18. That would make 3.7 litres around $60!
You don't want to know the price of liquid tin crystals! (nobody sells the liquid itself)- not that I buy them, of course. Some cheap flux and a soldering iron is what I do in the way of tinning.
I don't know if the prices for your chemicals are that cheap everywhere in USA, so I'm sorry if I am wrong there, but in comparison they do not seem very cheap here.
However a quick look online suggests the baking soda IS pretty cheap, so I guess that part wouldn't be too bad... thanks for the advice, I guess once you used it you couldn't use it again anyway.
--- In Homebrew_PCBs@yahoogroups.com, Roland Harriston <rolohar@...> wrote:
> Sometimes, I am truly amazed!
> A pound box of Arm and Hammer Baking soda costs about a dollar-fifty in
> any supermarket in the USA.
> Cheaper at WalMart.
> If you live in the high altitudes of Nepal or Tibet, and you have to
> ride your yak down a mountainside to buy a box, then you might think
> about saving
> the cost of an ounce of bicarb.
> Sorry.........I just could not resist.
> Roland F. Harriston, P.D.
> tda7000 wrote:
> > Thanks - I guess then that just a water rinse isn't good enough?
> > Also, do you re-use the baking soda mixture or make a new lot each time?
> > <mailto:Homebrew_PCBs%40yahoogroups.com>, "leeleduc" <leeleduc@> wrote:
> > > One thing I should mention. I keep a bowl with about 1 quart of
> > water and 1/4 cup of baking soda dissolved in it. When I'm done, I
> > toss the foam brush and any tools I've used into the bowl to
> > neutralize any acid on them. I do the same with the PCB, quick dip in
> > the bowl and a quick rinse under the the tap and I'm good to go.
> > <mailto:Homebrew_PCBs%40yahoogroups.com>, "tda7000" <Tda7000@> wrote:
> > > > Sounds good, I think I will try that. Like the idea of a foam
> > brush, should be easier to use than just a kitchen sponge and less messy.
> > > > > I use this technique all the time. I can do a 4X6 inch board in
> > about 2 minutes. I use 1 Part HCL and 2 Parts 3% H2O2. I make just
> > enough etchant to cover the board about 1/8 to 1/4 inch and lightly
> > brush the surface with a foam Paint brush. I etch at room temperature.
> > Works very well for me.
> > > > > I've also tried 1 part HCL and 2 parts 12% H2O2 but the reaction
> > was too fast and hot to control easily.
> > > > > > I see some people get very fast etch times with a sponge and
> > ferric chloride...
> > > > > > But has anyone tried that method with the HCl and H2O2
> > solution, or the cupric chloride?
> > > > > > Or anything else for that matter?
(CO3) 2
I'm not a chemist, just trying to save some typing.
PG
> Cheaper at WalMart.
> about saving
> > ferric chloride...
2011-11-29 by Piers Goodhew
As in Bunnings? I'm in aus but I've never looked..
PG
Date: Tue, Nov 29, 2011 3:46 pm
> > Available at Hardware, Building Supply, and Pool Supply stores
> > Hydrochloric Acid / Muriatic Acid 31%
> In our local hardware store, it's in the paint aisle, as it's used to
clean concrete
> before painting.
Same in Australia.
Tony
2011-11-29 by Bill Maxwell
Yes, in Bunnings but look in the garden or pool section rather than the
paint department. These days in Oz they charge a hefty deposit on the
container. Probably its most common usage here, apart from adjusting Ph
levels in swimming pools, is to wash down brickwork after the joints
have been pointed, raked or whatever. It removes all the surplus cement
and lime.
Bill
> PG
> From: "Tony Smith"<ajsmith1968@...>
> To:<Homebrew_PCBs@yahoogroups.com>
> clean concrete
>> before painting.
> Same in Australia.
> Tony
RE: [Homebrew_PCBs] Re: Sponge etching with HCl and H2O2?
2011-11-29 by Tony Smith
Yup, it's down the back with the building supplies.  Amuse yourself by
trying to lift the little rolls of lead flashing while you're there.
From memory it comes in 500mL, 1L & 5L bottles.  20L if you're really keen.
Cheap, maybe $10/5L (it's been a while).
Makes an excellent toilet cleaner btw...
Tony
and after getting your exercise lifting the lead flashing, have a look
at the aluminium ( no, that's not misspelt ) flashing now available. I
think it has great potential for shielding, groundplane construction etc.
Bill
> > From memory it comes in 500mL, 1L&  5L bottles.  20L if you're really keen.
> Tony
> and after getting your exercise lifting the lead flashing, have a look at
> aluminium ( no, that's not misspelt ) flashing now available. I think it
has great
I've seen that stuff, not cheap but still much cheaper than the lead.  I was
thinking of doing some plating so the lead would have been handy, I didn't
need a whole roll though.
Drink cans are a good source of thin aluminium sheet - plastic coated too.
Tony
Thanks mates, I'm about to move to the UK (where persulphate seems a lot less common :-/ ), so I don't want to be lugging a litre of HCl, but is it just called "muriatic acid"?
PG
> the
> has great
> Tony
2011-11-29 by David C. Partridge
In the UK it is commonly called any of: brick acid, hydrochloric acid, or surprisingly muriatic acid (I had thought that terminology was long dead).
Easy to get - I bought 20Ltrs not long ago.
Dave
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com] On Behalf Of Piers Goodhew
Sent: 29 November 2011 10:48
Subject: Re: [Homebrew_PCBs] Re: Sponge etching with HCl and H2O2?
PG
less
called
> "muriatic acid"?
Same stuff.  Just check the percentage.
Tony
2011-11-29 by Leon Heller
Over here, it rejoices in the name "Spirits of salt", or just
hydrochloric acid. Muriatic acid is hardly ever used.
Leon
Leon Heller
G1HSM
