Homebrew PCBs
Tips for making PCBs
2011-12-03 by Steve Greenfield
From Advanced Circuits:
7 Common Mistakes With Gerber Files
http://www.my4pcb.com/easy_design_order_printed_circuit_boards_common_mistakes.htm
10 Most Common Mistakes in Flex Designhttp://www.my4pcb.com/advanced_circuits_common_flex_design_mistakes.htm
Tips and tools
http://www.4pcb.com/index.php?load=content&page_id=296
Steve Greenfield AE7HD
http://www.linkedin.com/in/stevenjgreenfield
Metal Core PC boards
2011-12-04 by John Dammeyer
Has anyone done any metal cored PC boards at home?  Or even know the
process for fabricating them?
John Dammeyer
Re: Metal Core PC boards
2011-12-28 by marc
HI John
is same as for multilayer board
it use very thin FR-4 PCB (single or 2 side)
then it hot laminate it to aluminium plate whit a Prepreg
bethen pcb and the metal core
but for laminate it you need a hydraulic press capable of heating
to 230-250 deg Celsus so above glass transition point of FR-4
Prepreg sheet was aviable from lpkf or local pcb shop
it look like paper thin fibre glass fabric whit resin on it
as for press i personally use 2 1/2" thick aluminium plate
on on a metal frame 1" thick bolted together the 4 corner
and put it on kitchen over
for 60 minute then let it cold down for another 60 minute
for multilayer it same but you replace metal core whit 2 or more 2 layer PCB each one separated by a Prepreg sheet
then drill and plate via
Best regard
Marc Lalonde
> John Dammeyer
RE: [Homebrew_PCBs] Re: Metal Core PC boards
2011-12-28 by John Dammeyer
Thanks for the feedback.  I take it that the thin FR4 is etched with the
layout first before pressing. Otherwise the etchant would damage the core?
John
Automation Artisans Inc.
http://www.autoartisans.com/ELS/
Ph. 1 250 544 4950
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
On Behalf Of marc
Sent: Wednesday, December 28, 2011 5:35 AM
Subject: [Homebrew_PCBs] Re: Metal Core PC boards
HI John
Best regard
Marc Lalonde
<mailto:Homebrew_PCBs%40yahoogroups.com> , "John Dammeyer" <johnd@...>
> John Dammeyer
2011-12-30 by marc
Hi
yes PCB was etched and via made before lamination
then after lamination solder mask and silk was made
it not good idea to put aluminium on etch thank ;-)
Best regard
Marc Lalonde
> John
> Ph. 1 250 544 4950
> On Behalf Of marc
> HI John
> Best regard
> Marc Lalonde
> <mailto:Homebrew_PCBs%40yahoogroups.com> , "John Dammeyer" <johnd@>
> > John Dammeyer
