Homebrew PCBs
Explosive Byproduct: what are the risks with muriatic acid?
2011-12-29 by poofjunior
Hello, fellow PCB makers,
I'm new to the etching community, and most of my learning has come
either from here or other places online.
I've made 3 successful boards so far using the Toner Transfer method and
Muriatic Acid with hydrogen peroxide, but I'm worried about a critical
step:
After removing the etched board from the etching solution, I dried it
with a paper towel and then cleaned it with acetone.  Am I at risk of
creating small particles of the friction-based explosive Acetone
Peroxide because I didn't first rinse the etched board with water?
Without knowing about this accidental byproduct beforehand, I've already
soldered components onto the board and added a layer of epoxy to the
bottom as a sealant.
Because this board is going to have to  take a lot of vibrations (it's a
quadcopter controller board), should I trash it to e-waste and start
over?
Lastly, has anyone had any bad experiences in accidentally making
acetone peroxide on their PCBs using HCL, H2O2, and Acetone?
Thanks everyone!
Sincerely,
Poofjunior
Re: [Homebrew_PCBs] Explosive Byproduct: what are the risks with muriatic acid?
2011-12-29 by Leon Heller
> step:
> over?
There isn't any danger of an explosion, but the copper on your board
might corrode because you didn't rinse it.
Leon
Leon Heller
G1HSM
2011-12-29 by Michael Zappe
I wouldn't think you'd have much to worry about.  If you made anything you would have heard it popping by now, especially while soldering. :-)  The quantities would also be minute.
However, I would, in the future, rinse in water first just to get the etchant down the drain rather than in the trash can, where it can mix with all kinds of other stuff.
Of course, I haven't actually *seen* your board, so if there are white crystals hanging off of it and/or your quadcopter blows up, it's not my fault. ;-)
	Mike
> step:
> over?
> Thanks everyone!
> Sincerely,
> Poofjunior
When I was about 12 I made some nitrogen tri-iodide, another very
unstable and powerful explosive, and left it to dry on a piece of filter
paper. The next morning my mother came into my room, complained about it
being untidy, saw the filter paper with what she thought was some dirt
on it, picked it up to illustrate the point she was making, and there
was a very loud explosion!
I also made some in the chemistry lab at school and sprinkled it about
the floor. Explosions resulted when the other kids stepped on it.
Leon
Leon Heller
G1HSM
RE: [Homebrew_PCBs] Explosive Byproduct: what are the risks with muriatic acid?
2011-12-30 by Ronald Cody
You are safe, it takes a little more than just Muriatic Acid and hydrogen
peroxide. It's also a bit more complex than simply mixing it all together.
Ron Cody
KF7MKY
"You learn from your mistakes...Today I hope not to learn to much."
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
On Behalf Of poofjunior
Sent: December 29, 2011 7:44 AM
Subject: [Homebrew_PCBs] Explosive Byproduct: what are the risks with
muriatic acid?
step:
over?
Thanks everyone!
Sincerely,
Poofjunior
2011-12-30 by Dylan Smith
El 29/12/11 22:33, Leon Heller escribi\ufffd:
> paper.
We did that at school, putting it around things like door frames so when
someone closed a door there would be a very loud bang. It all sort of
backfired when the head of Chemistry happened to be the one to close the
door one time, it wasn't exactly hard for him to figure out what it was,
and he had a pretty good idea who was responsible...
Today in our increasingly paranoid and scared society you could get put
in prison due to anti-terror legislation for making the stuff, I think :-(
2011-12-30 by David Griffith
On Fri, 30 Dec 2011, Dylan Smith wrote:
> El 29/12/11 22:33, Leon Heller escribi?:
>> paper.
I remember a story in which someone dipped the ends of a pair of pencils
in the stuff.  The pencils were owned by a student who was well-known for
playing "Wipeout" with them.
David Griffith
dgriffi@...
A: Because it fouls the order in which people normally read text.
Q: Why is top-posting such a bad thing?
A: Top-posting.
Q: What is the most annoying thing in e-mail?
2011-12-30 by Piers Goodhew
For me, NI3 to me is the very embodiment of the dawn of the internet: in the late 80's a friend of ours said he was over BBSes and wanted to get on this new thing, the internet. Which was Usenet trickle-fed via modem, and all of rec.pyro could fit on one floppy. NI3 was one of the things they listed. Even in pre-internet Australia, you already couldn't get iodine crystals anywhere, but he eventually found some (he told the pharmacist it was to make an explosive) and we got to see some little brown/purple puffs of smoke where the little blobs he'd laid out to dry got set off by falling drizzle.
PG
> >> paper.
> David Griffith
> dgriffi@...
> A: Top-posting.
Re: Explosive Byproduct: what are the risks with muriatic acid?
2011-12-30 by psykhon@yahoo.com
By guessing your level of knowledge on the matter, I would recommend that you shoul be more carefull with the chlorine gas that may be released from the etching solution, please wear a gas mask with appropiate filter for chlorine gas, if you cant get a chlorine filter, any carbon activated filter will be better than nothing, just replace it more ofther. Also make the mix, etch, and store the solution in a well ventilated area, and do not close the container too tigth, there are some gasses that keeps going out of the solution once bottled.
Final advice, DO NOT THROW IT ON THE DRAIN, first it can be regenerated indefinitely and seccond, copper leads to malformation in fish gills.
Please do not be scared with all of this, cucl is the best etch out there, more and more pcb manufacturers are converting to cucl because its clean, cheap,reusable, you can get very precise lines and more important fact: ECOLOGYC
--- In Homebrew_PCBs@yahoogroups.com, "poofjunior" <seeifyoucanmeetme@...> wrote:
> step:
> over?
> Thanks everyone!
> Sincerely,
> Poofjunior
