Homebrew PCBs
Re: [Homebrew_PCBs] Re: Printer and Pulsar Paper
2012-02-19 by Piers Goodhew
I can do 10/10 traces with an old HP 5mp, but I only do small boards that need very thorough checking prior to etching (and sometimes after) (and maybe 1/5 still don't make it). Def not suitable to runs of more than 1, but technically possible.
PG
Sent from my phone, anything lewd or incomprehensible is probably autocorrect and not my fault.
----- Reply message -----
To: <Homebrew_PCBs@yahoogroups.com>
Subject: [Homebrew_PCBs] Re: Printer and Pulsar Paper
Date: Sun, Feb 19, 2012 3:20 am
Joe, I think your results are more the exception than the rule.  I have been able to get down to 8mil traces with the Pulsar paper, and just as good with the HP Presentation paper.
The problem with the photosensitive steps is there are just too many chemicals and steps involved for it to be quick.
And, I agree with Harvey, run the board and paper sandwich through the laminator several (8-12) times then immediately into a warm water bath to release the paper from the toner.
The only real problem I had with the Pulsar was the stretch...I use a cnc mill to drill holes before laminating and the holes don't line up so well.  Luckily the stretch is mostly in the long direction of the paper.
--- In Homebrew_PCBs@yahoogroups.com, joe M <joe9mail@...> wrote:
> Mark, I had better luck with the photosensitive process than the toner
> transfer process. I tried all kinds of paper from magazine paper, HP
> Presentation paper, to photo paper, without much luck.
> What is the size of your traces? I could get 15mil with photoetching, which
> I could not with toner transfer process.
> I want to try the cnc approach some time. What machine did you use?
> Joe
> On Sat, Feb 18, 2012 at 11:22 AM, RL <rlrc2003@...> wrote:
> > I had just purchased some Toner Transfer paper from Pulsar.
> > Do any of you have any suggestions on the type
> > of printer that you have had good luck with this product?
> > I saw some one used a samsung laser 1200x1200 dpi with reg.
> > photo paper. Any one else with sug?
> > And any other tips on this product would be helpful.
> > I tried the CNC way for a few weeks now, but there are to many
> > problems, when dealing with such small traces.
> > Thanks,
> > Mark
