Green Film temperature
2012-04-13 by sailingto
Hello all, the green film from Pulsar - what is the best temperature to run it thru laminator? I ran thru at 370ºF and that "seemed" like it "might" be a tad hot. It sorta "smeared" on a couple of close traces and I had to use a probe to clean before etching. Only 1 time thru? Thanks to all for any info, Ken H>
2012-04-13 by Harvey White
On Fri, 13 Apr 2012 02:55:27 -0000, you wrote: >Hello all, the green film from Pulsar - what is the best temperature to run it thru laminator? I ran thru at 370\ufffdF and that "seemed" like it "might" be a tad hot. It sorta "smeared" on a couple of close traces and I had to use a probe to clean before etching. "foil" setting, no idea of temperature. Run it twice. I have a similar problem at times, but I've also had the film simply not adhere, regardless of temperature. You want to see an absolutely clear area where there used to be green. On the other hand, it saves more boards than it ruins.... Harvey
> >Only 1 time thru? > >Thanks to all for any info, > >Ken H>
2012-04-13 by David
Ken, I use a modified GBC laminator, and its limit is 165'C - 169'C [329'F -336'F], i put the green TRF and white TRF through two times and get good results, occasionally there are a few patches [especially over ground planes] that don't adhere, but thats probably due to fingerprint contamination!! are you able to adjust the temperature setting on your laminator? I cannot, but it works fine for TT and TRF. hope this helps David --- In Homebrew_PCBs@yahoogroups.com, "sailingto" <sailingtoo@...> wrote:
> > Hello all, the green film from Pulsar - what is the best temperature to run it thru laminator? I ran thru at 370ºF and that "seemed" like it "might" be a tad hot. It sorta "smeared" on a couple of close traces and I had to use a probe to clean before etching. > > Only 1 time thru? > > Thanks to all for any info, > > Ken H> >
Thank ya'll for info David, Harvey - I've got an Apache laminator and the temp is fully adjustable from 100ºF up to 379ºF - it is better than the GBC I had before. I had put a temperature controller on it but still could only get max of 310ºF due to sensor limits. Just wasn't hot enough for good transfer, but worked with several passes thru. At 370ºF the green is completely transferred to board - need to cool film/board before removing. Yes, I do think the green film helps. Ken H> --- In Homebrew_PCBs@yahoogroups.com, "David" <dgh2259@...> wrote:
> > Ken, > > I use a modified GBC laminator, and its limit is 165'C - 169'C [329'F -336'F], i put the green TRF and white TRF through two times and get good results, occasionally there are a few patches [especially over ground planes] that don't adhere, but thats probably due to fingerprint contamination!! are you able to adjust the temperature setting on your laminator? I cannot, but it works fine for TT and TRF. > hope this helps > David > > --- In Homebrew_PCBs@yahoogroups.com, "sailingto" <sailingtoo@> wrote: > > > > Hello all, the green film from Pulsar - what is the best temperature to run it thru laminator? I ran thru at 370ºF and that "seemed" like it "might" be a tad hot. It sorta "smeared" on a couple of close traces and I had to use a probe to clean before etching. > > > > Only 1 time thru? > > > > Thanks to all for any info, > > > > Ken H> > > >
2012-04-13 by Shannon Haworth
Unfamiliar with the green film from Pulsar, do you have a link to it? On Thu, Apr 12, 2012 at 10:55 PM, sailingto <sailingtoo@...> wrote: > ** > > > Hello all, the green film from Pulsar - what is the best temperature to > run it thru laminator? I ran thru at 370�F and that "seemed" like it > "might" be a tad hot. It sorta "smeared" on a couple of close traces and I > had to use a probe to clean before etching. > > Only 1 time thru? > > Thanks to all for any info, > > Ken H> > > > [Non-text portions of this message have been removed]
2012-04-13 by David
Take a look at this: http://www.pcbfx.com/main_site/pages/start_here/overview.html Regards, --- In Homebrew_PCBs@yahoogroups.com, Shannon Haworth <shannon.haworth@...> wrote:
> > Unfamiliar with the green film from Pulsar, do you have a link to it? > On Thu, Apr 12, 2012 at 10:55 PM, sailingto <sailingtoo@...> wrote: > > > ** > > > > > > Hello all, the green film from Pulsar - what is the best temperature to > > run it thru laminator? I ran thru at 370ºF and that "seemed" like it > > "might" be a tad hot. It sorta "smeared" on a couple of close traces and I > > had to use a probe to clean before etching. > > > > Only 1 time thru? > > > > Thanks to all for any info, > > > > Ken H> > > > > > > > > > [Non-text portions of this message have been removed] >
A direct link to the green foil: http://www.pcbfx.com/main_site/pages/products/toner_foils.html --- In Homebrew_PCBs@yahoogroups.com, Shannon Haworth <shannon.haworth@...> wrote:
> > Unfamiliar with the green film from Pulsar, do you have a link to it? > > On Thu, Apr 12, 2012 at 10:55 PM, sailingto <sailingtoo@...> wrote: > > > ** > > > > > > Hello all, the green film from Pulsar - what is the best temperature to > > run it thru laminator? I ran thru at 370ºF and that "seemed" like it > > "might" be a tad hot. It sorta "smeared" on a couple of close traces and I > > had to use a probe to clean before etching. > > > > Only 1 time thru? > > > > Thanks to all for any info, > > > > Ken H> > > > > > > > > > [Non-text portions of this message have been removed] >
