Homebrew PCBs
Long-Term CuCl2 setup
2012-05-08 by poofjunior
Hi everyone,
I noticed that a few people have mentioned regenerating a cupric chloride etching solution with a few options: aerating it with a fish pump, adding Hydrogen Peroxide, or even using some form of electrolysis.
Has anyone had any long-term success with this process?  How long does it take to aerate?  Is there any excess waste that needs to be dumped eventually?  Are there any circuits I can create to duplicate an electrolysis setup?
I'd greatly appreciate more details on anyone's success or any insights on maintaining a CuCl2 solution for use over and over again.  If I can duplicate a setup, or make my own, I'd be happy to write up a tutorial.
Many thanks in advance!
Sincerely,
Poofjunior
Re: [Homebrew_PCBs] Long-Term CuCl2 setup
2012-05-08 by John Anhalt
Remember that chloride (Cl^-1) is consumed in the etching process.  That must be replenished by addition of HCl or something equivalent.
Whether the copper is oxidized to Cu^+2 can be determined by color.  I just bubble air until all traces of brown/mud are gone as per Seychell's instructions.
John
  Sent: Tuesday, May 08, 2012 9:39 AM
  Subject: [Homebrew_PCBs] Long-Term CuCl2 setup
  Hi everyone,
  Sincerely,
  Poofjunior
2012-05-08 by Russell Shaw
On 08/05/12 23:39, poofjunior wrote:
> Hi everyone,
> eventually?
No.
Ferric chloride is commonly known as Profloc-F for floculating in sewer treatment.
You shouldn't dispose of ferric chloride if using air agitation such as
bubbling, because it'll eventually turn green and work as copper-chloride etcher
and last forever (the oxygenation is needed iirc). My etchant is years old and
still working well.
I use a bubble etcher same as the first in this list:
   http://www.esr.co.uk/electronics/pcb-tanks.htm
The only aeration that's needed happens during etching anyway.
That one comes with a heater, but i get a complete etch of double-side pcb at
room temperature in ~12mins.
Just keep the stuff topped up with hydrochloric acid every few months and it'll
work well instead of the water evaporating out. Keep a cover over the container
when not in use.
When starting with new ferric chloride, first dilute it 1:1 with water, then put
a bit (like half a cup per litre) of hydrochloric acid in it.
Copper saturated etchant is excellent weed killer. Apply only selectively, or
you'll end up with a large black spot on the lawn.
2012-05-08 by DJ Delorie
"poofjunior" <seeifyoucanmeetme@...> writes:
> eventually?
I put together my CuCl etchant around March 2008, so four years ago.
I'm still using it.  I run the air pump only when I'm actively using it
(i.e. from "plug in the heater" to "done"), and it's been jade green the
whole time.  I occasionally test the HCl levels and add acid, and/or let
some of the water evaporate, but otherwise I just use it to etch.
> setup?
There's no electricity involved in my tank at all, aside from the heater
and air pump.
Re: Long-Term CuCl2 setup
2012-05-08 by Aaron
He had a great web page describing the process but it seems to be down. Does anyone have an archived copy of the page?
http://members.optusnet.com.au/~eseychell/PCB/etching_CuCl/index.html
It covered how to determine optimum pH, specific gravity, temperature, etc and was probably the most thorough coverage I have seen given to the topic.
Aaron
Re: [Homebrew_PCBs] Re: Long-Term CuCl2 setup
I just added a text and MHT version to our files section: Seychell_Cupric Chloride
John
  Sent: Tuesday, May 08, 2012 3:25 PM
  Subject: [Homebrew_PCBs] Re: Long-Term CuCl2 setup
  Aaron
2012-05-08 by Aaron
John, thanks for posting that. It has a lot of good info.
I have been wanting to try a CuCl2 setup but had to wait for summer, when classes are over.
Aaron
> John
>   ----- Original Message -----
>   From: Aaron
>   Aaron
2012-05-08 by KeepIt SimpleStupid
The Wayback Machine has one:  http://web.archive.org/web/20100206170229/http://members.optusnet.com.au/~eseychell/PCB/etching_CuCl/index.html
Date: Tuesday, May 8, 2012, 3:25 PM
Aaron
2012-05-09 by kabowers@NorthState.net
Why can't someone just put a copy of this information (with proper credit) into the files
section since the original page is no longer active?
Keith Bowers WB4LSJ- Thomasville, NC
2012-05-09 by epareja2
Hello, I found a PDF document here:
http://www.goldrecovery.us/goldrecovery/documents/CuCl.pdf
2012-05-09 by Donald H Locker
YES! That's the real deal, complete with his pictures.
Donald.
*Plain Text* email -- it's an accessibility issue
()  no proprietary attachments; no html mail
/\  ascii ribbon campaign - <www.asciiribbon.org>
> From: "epareja2" <epareja2@...>
> To: "Homebrew PCBs" <Homebrew_PCBs@yahoogroups.com>
> Sent: Wednesday, May 9, 2012 10:17:08 AM
> Be sure to visit the group home and check for new Links, Files, and
> Photos:
2012-05-09 by poofjunior
Thanks, everyone,
I've added a "Long Term Cupric Chloride Setup" folder to the files section for storing a few insights I've found.
Cheers!
Poofjunior
2012-05-09 by James Irving
Hi John,
Thanks for the files!  Wayback Machine had a number of captures, but some of the images and charts are missing.  I couldn't find any other sources for this article.
Jimmie
To: Homebrew_PCBs@...m
Sent: Tuesday, May 8, 2012 4:07 PM
Subject: Re: [Homebrew_PCBs] Re: Long-Term CuCl2 setup
John
2012-05-10 by AlienRelics
There is already an Acid Etching folder, I put the PDF file in there.
http://tech.groups.yahoo.com/group/Homebrew_PCBs/files/Acid_Etching/
The problem with listing folders by someone's name, is what if someone doesn't know who Adam Seychell is but is looking for information on acid etchant?
Steve Greenfield AE7HD
--- In Homebrew_PCBs@yahoogroups.com, James Irving <k9jfk@...> wrote:
> Hi John,
> Jimmie
>  From: John Anhalt <janhalt@...>
> Â
> John
> From: Aaron
2012-05-10 by John Anhalt
Are there any etchants used by hobbyists that are not acid?
Why not just have an "etchants" folder for everything?
John
  Sent: Wednesday, May 09, 2012 8:34 PM
  > Hi John,
  > Jimmie
  > Â
  > John
  > From: Aaron
Are there alkaline etchants?
Sure, I can change the name to just Etchants.
I've moved the other files/folders I've found about etchants into that folder. So if you've recently created a folder about etchants and can't find it, look in there.
I'm changing it to "Etchants" now.
> John
>   From: AlienRelics
2012-05-10 by Adam Seychell
> John
Copper (II) Ammonia chloride/sulfate etchants are alkaline but really
need a automatic replenishing system to keep them working well. They
also inherently release ammonia so not practical for just the occasional
use. There have been attempts to run the ammonia concentration very low
so it doesn't smell, but solution turns to sludge  (copper chloride
precipitation) at the drop of a hat.
Air regenerated acid copper chloride is still my favorite. :)
Its only disadvantage is its etches about 1/2 speed of fresh strong
solution of ferric chloride in the same conditions.
Re: alkaline etchants
Yes, there is an etchant that is considered alkaline.  It apparently is used commercially and is discussed here:
http://www.dtsc.ca.gov/PollutionPrevention/sb14/upload/sr-technologies-printed-circuit-board-manufacture.pdf
http://www.chemcut.net/downloads/Chemcut%20Thoughts%20on%20Undercut_Doc.pdf
John
  Sent: Wednesday, May 09, 2012 8:47 PM
  > John
  > From: AlienRelics
That is the reason I qualified my comment.  Also responded with some links.
John
  Sent: Thursday, May 10, 2012 2:46 AM
  > John
2012-05-11 by Donald H Locker
Hey, Adam.
Is it OK to save and distribute to friends copies of your [excellent] write-up of CuCl2 etchant chemistry?
Many thanks,
Donald.
> From: "Adam Seychell" <a_seychell@...>
> Sent: Thursday, May 10, 2012 2:46:46 AM
> > John
> occasional
> low
2012-05-11 by Adam Seychell
On 11/05/2012 10:12, Donald H Locker wrote:
> Hey, Adam.
> Many thanks,
> Donald.
Yes sure. I'm note sure what happened to the original web site. Someone
converted to PDF and made it available at:
In a week I'll be using a new ISP, so I'll upload it again.
This document I wrote back in 2005,  was only a first draft and I
planned to one day make it more complete with better illustrations.
It'll have to wait one day when I get my lab set up again.
Thank you, Adam.
I downloaded your original file back in 2007 or 2008 and printed it for my library, but have wondered since why it disappeared. I find it hard to believe it was a "first draft" - it has proven to be an excellent reference. Good to know you're still around.
Donald.
> Sent: Friday, May 11, 2012 7:22:27 AM
> > Hey, Adam.
> > [excellent]
> > Many thanks,
> > Donald.
> Someone
> Photos:
2012-08-07 by Gmm Groups and News
> <http://members.optusnet.com.au/%7Eeseychell/PCB/etching_CuCl/index.html>
> the topic.
> Aaron
The page can be found at
Some of the pictures are missing but all of the content is there.
2012-08-09 by Jim Williams
I have an archived copy of the Seychell paper (with pictures) in the cupric
chloride section of my project notes here:
http://jimlaurwilliams.org/wordpress/?cat=22.  There are still some links
in the paper that don't work, though.
Jim
2012-08-09 by kabowers@NorthState.net
>Jim
Great page Jim, thanks for the info.
FWIW - I recently went looking for 40 Volume peroxide in my area
and found that Sally Beauty Supply stores stock it. It also seems their
stores show up in the same building cluster as WalMart stores.
2012-08-09 by Donald H Locker
Steve put a copy in our files <http://tech.groups.yahoo.com/group/Homebrew_PCBs/files/Etchants/CuCl.pdf> last May. Most convenient.
I found Sally Beauty next to a Target, locally, so you can avoid the WalMart offshore-production world. (Always the low cost; always the low value.) Check your local hair salons, too. When I explained what I was using it for, the people were delighted that one of their lowly products was useful for high-tech electronics development!
Donald.
> From: kabowers@...
> Sent: Thursday, August 9, 2012 10:14:20 AM
> >Jim
2012-08-09 by Derward Myrick
I have been using Baquacil (that I buy at swimming
pool supply stores) as my source of Hydrogen Peroxide.
I do not remember the % but close 30% best I remember.
Just JFYI.
Works great for me.
Derward  Myrick KD5WWI
  Donald.
  > From: kabowers@...
  > >Jim
