Homebrew PCBs
Spray Etcher
Spray Etcher
2012-08-22 by David
Hi All,
Has anyone tried making this?
http://www.instructables.com/id/Printed-Circuit-Board-PCB-Sprayer-Machine/?ALLSTEPS
It looks very interesting!!
Re: Spray Etcher
2012-08-22 by cunningfellow
> David wrote:
> Hi All,
I would advise against it.
Acrylic is not suitable material with CuCl.
(PE,PP, PVC are all OK)
Conical spray nozzles wont get a uniform etch.
The high pressure pump is pressure relived AFTER
going outside the tank with tiny little flimsy
connectors.
See
http://www.prototrains.com/etch2/etch2.html
Where his spray etcher had an accident with large
barbed fittings and hose clamps.
and imagine how much fun it would be to have that
image at 3 min 21 sec into the video on the
OUTSIDE of the tank.
If you are going to spend 100s of $ on building
one, follow Adams build.  You will get good
results with the fan nozzles and motorised PCB.
If you only want small boards and spending $40
sounds like more fun, just be patient.  I am
working on my write up.
Re: [Homebrew_PCBs] Re: Spray Etcher
2012-08-24 by lists
In article <k13l1h+40pi@...>,
That's interesting because an awful lot of designs seem to use acrylic but
I was advised against it by a supplier when I was looking to build a new
tank (Still haven't built it)
Stuart Winsor
Only plain text for emails
http://www.asciiribbon.org
2012-08-24 by Kevin Byrne
Thanks Pulsar Pro's appears to be Acrylic. Hard ware store sold me glue of industry and said if seam was tight I should not have a problem. It will not be storage. Petcock for drain into proper container. Kevin
Sent: Friday, August 24, 2012 2:57 AM
Subject: Re: [Homebrew_PCBs] Re: Spray Etcher
In article <k13l1h+40pi@eGroups.com>,
Stuart Winsor
Re: Spray Etcher
2012-09-10 by jcarlosmor
Hi All,
Any update on DIY spray ecthing systems, or at least about the suitable commercial pumps?
Regards.
--- In Homebrew_PCBs@yahoogroups.com, "cunningfellow" <andrewm1973@...> wrote:
> > David wrote:
> > Hi All,
> connectors.
> See
Re: Spray Etcher
2012-09-10 by cunningfellow
I've just built another one for the
purpose of documenting it.  I will finish
taking photos and write up the whole thing
this weekend.
The whole thing takes between 5 and 10
hours to build and cost between $50 and
$100.  Thats for tank, motors, sprayers
PCB holder - the lot.
Just add FeCl3 or CuCl and a power supply.
--- In Homebrew_PCBs@yahoogroups.com, "jcarlosmor" <jcarlosmor@...> wrote:
> Hi All,
> Regards.
> --- In Homebrew_PCBs@yahoogroups.com, "cunningfellow" <andrewm1973@> wrote:
> > > David wrote:
> > > Hi All,
> > connectors.
> > See
Re: Spray Etcher
2012-09-13 by psykhon@yahoo.com
About conical nozzles not having an uniform etch, Im not sure how much this is a problem, Bungard uses it on their splash center/xl machines and they claim a 100 microns (4mils) resolution. Just see the video.
However full cone nozzles are not the same as the one used on the instructables, those produce a mist and a serious cone should produce a much greather particle size.
Cunningfellow, Im looking foward to see your writeup!
> > David wrote:
> > Hi All,
> connectors.
> See
