Homebrew PCBs
Michael's "Green Film" provokes thought
2013-01-01 by alan00463
This Youtube video is labeled
"professional-looking stopping agent (solder resist layer)"
http://www.youtube.com/watch?v=VNYIVZgbi9M
I just watched Michael's Youtube video of solder resist layer, and
thought I'd ask if anybody here had tried it.    The result looks
quite good in the video.
Green film has glossy side & matte side (1/2 way through video)
Does anybody have experience using this green film?
I don't understand why the green film is transparent ONLY over the undrilled holes, as shown in the video at around 15:30.   I must
have missed something.
Does anybody know where I can get this film in the USA?
Does anybody know if this stopping agent layer will work with the toner transfer etching method, as opposed to the UV-photo-etching method shown in the video ?
Am a little disappointed it doesn't put component silhouettes in the green film, but I guess  a white film would be better for that anyway.
Allan
Re: [Homebrew_PCBs] Michael's "Green Film" provokes thought
2013-01-01 by "Zoran A. Šćepanović"
> Allan
Wow, could not watch the video due to the awlfull chewing sound.
And as for the transparency at the hles, it is obvious that there is no
film over the pads/holes :-)
Best Regards,
Q Systems
Zoran A. \u0160\u0107epanovi\u0107
zastos@...
Skype: zoran.a.scepanovic
http://zastos.com
+381 63 609-993
Beam me up scotty,
 there is little intelligent life on this planet!!
Re: Michael's "Green Film" provokes thought
2013-01-01 by tda7000
There's someone selling some here:
http://www.ebay.com/itm/Solder-Mask-Resist-Green-Dynamask-5-sheets-30-x-20-CM-Incl-50-gram-developer-/271109281266
You can put solder-mask on any PCB regardless of how you etched it etc.
No component outlines of course, that is for the silkscreen layer, totally different to solder-mask layer.
> Allan
Re: [Homebrew_PCBs] Re: Michael's "Green Film" provokes thought
2013-01-01 by John Anhalt
There is obviously a lot that is not shown.  How can a laminate resist cover both etched areas and the not etched areas?
It's a hoax -- with a lot of thumb sucking and rap music in the background.
John
  Sent: Tuesday, January 01, 2013 5:36 PM
  Subject: [Homebrew_PCBs] Re: Michael's "Green Film" provokes thought
  > Allan
> John
Hi John,
don't jump to the conclusions too early.
Soldermask is as easy as 1-2-3-4:
Laminate-Expose-Develop-Cure.
I actually watched the video to the end (after some "liquidish sedative"
- beer), and the cow-dude explained it quite accurate.
Best Regards,
Q Systems
zastos@...
http://zastos.com
+381 63 609-993
90% of all statistics are made up.
I realize a solder mask can do that.  But didn't see the your tube producer mention that the board was etched first, then was treated with the solder mask.  I may have missed that.
If I did, I apologize.
Assuming it is two steps, aligning the etch mask and the solder mask could be a bit challenging, but not impossible with proper alignment marks.
John
  Sent: Tuesday, January 01, 2013 5:55 PM
  Subject: Re: [Homebrew_PCBs] Re: Michael's "Green Film" provokes thought
  > John
  Hi John,
  Best Regards,
  Q Systems
  Zoran A. Šćepanović
  zastos@...
  http://zastos.com
  +381 63 609-993
2013-01-02 by Missouri Guy
FWIW....
I've been using a FAUX solder mask.  :D)
After etching the board and cleaning it thoroughly,
I spray it with Testor's all purpose spray enamel,
#1601 "Candy Emerald Green".  It drys in a hurry, but I let mine
sit overnight .  The "trick" is to not spray it on too heavy.  Just a
couple of light, even coats a few minutes apart will do it.  A cardboard
box placed over the board will help keep dust off the fresh coating.
The traces are still easy to see and drill.  It's transparent and melts
away wherever you want to solder.
As with any soldering or painting activity, use adequate ventilation.
If you want to try it, I understand that the color is being discontinued,
but it's still available on Amazon and at least one auction site.  I've
never been able to find it locally.
Charlie
2013-01-02 by tda7000
The video may not be great but the information is all there if you listen. I understand some people may not want to, but I had no big issues with it.
Certainly not a hoax anyway, but yes, aligning the masks will be the hardest part I think.
> John
>   ----- Original Message -----
>   From: "Zoran A. Šćepanović"
>   > John
>   Hi John,
>   Best Regards,
>   Q Systems
>   Zoran A. Šćepanović
>   zastos@...
>   http://zastos.com
>   +381 63 609-993
2013-01-02 by bebx2000
I bought some some solder mask from an eBay seller in England several months ago and it works just fine. It takes a little practice to laminate it with out wrinkles. I pretty much follow the instructions in the link provided by John Anhalt. The developer is sodium carbonate (washing soda). The tricky part is the exposure. If you overexpose, you can't remove the pad areas. I use a 25W UV Damar CFL in a parabolic shop fixture and expose for about 1 1/2 min at a distance of about 5".
2013-01-02 by Paul
Good clear explanation of the whole process here:
http://cms.diodenring.de/de/electronic/mikrocontroller/95-pcb-diy
> issues with it.
> <mailto:Homebrew_PCBs%40yahoogroups.com>, "John Anhalt" <janhalt@...>
> marks.
> > John
> > From: "Zoran A. Å Ä++epanoviÄ++"
> background.
> > > John
> > Hi John,
> > Best Regards,
> > Q Systems
> > zastos@...
> > http://zastos.com
> > +381 63 609-993
> No virus found in this message.
> Checked by AVG - www.avg.com <http://www.avg.com>
> Version: 2013.0.2805 / Virus Database: 2637/6001 - Release Date: 01/01/13
