Homebrew PCBs
photoresist application
2013-01-13 by Jeff
Photoresist is shipped with a clear protective covering film on the top and bottom.  The covering film is removed by the user before the photoresist is applied.  A comment by a poster in a forum says the top covering should be kept on during exposure and removed before developing.  Is that true?  Why is that?
"Note that the dry film resist should be exposed with the cover sheets on, and then held in a dark place for 15 minutes before removing the cover sheets and developing."
http://www.electro-tech-online.com/general-electronics-chat/14427-photoresist-pcb-etching-process.html
Jeff
Re: [Homebrew_PCBs] photoresist application
2013-01-14 by Todd F. Carney
The cover sheet protects the resist from oxygen and from oxidizing the
"free radicals" on which the photo-polymers depend. Here is an excellent
document from DuPont on this:
http://www2.dupont.com/Imaging_Materials/en_US/assets/downloads/techtalk/TT1007.pdf
You will note that from an optical standpoint, leaving the cover sheet on
is not optimum as it inevitably degrades the sharpness of the image. This
is one reason why commercial or professional exposure units use arc light
or a similar "point source" instead of diffused light like we home brewers
use almost exclusively. Actually, for the stuff we typically do, the
difference would probably never be noticed.
73,
Todd
K7TFC / Medford, Oregon, USA / CN82ni / UTC-8
QRP (CW & SSB) / EmComm / SOTA / Homebrew / Design
> is that?
> Jeff
Sorry, Folks. Wrong URL for the DuPont document. Here's the right one:
http://www2.dupont.com/Imaging_Materials/en_US/assets/downloads/techtalk/TT1207.pdf
73,
Todd
> 73,
> Todd
>> is that?
>> Jeff
RE: [Homebrew_PCBs] photoresist application
2013-01-14 by Jeff Heiss
The SEM images are great.  I'm left wondering what the time frame is
regarding the oxygen exposure to resist.  Minutes, hours?  I suppose the
oxygen contamination issue is large enough where it is better to leave the
cover sheet on and accept the more diffused and less collimated light?
Jeff
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
On Behalf Of Todd F. Carney
Sent: Sunday, January 13, 2013 8:38 PM
Subject: Re: [Homebrew_PCBs] photoresist application
207.pdf
73,
Todd
007.pdf
> 73,
> Todd
photoresist
Why
>> is that?
cover
>> Jeff
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
Jeff,
Well, I think some brave soul should experiment with it. Oxidation is only
a problem prior to exposure. If the cover film were removed a few seconds
before being sandwiched and clamped under glass, there may be no adverse
effect at all. It may be that DuPont says to leave the film on because they
can't control the timing of how the resist is used and when the cover film
is removed.
The pcb material sold by FarCircuits (http://www.farcircuits.net/) is
laminated with Dupont PM115 resist. It's also available from other
retailers, but I think I'll get some from Far because I need a other things
from them. I have a few boards I need to do myself. I think I'll try one
with the cover film removed before exposure. If it seems okay, I'll try a
few more. I'll let you know.
73,
Todd
> Jeff
> 207.pdf
> 73,
> Todd
> 007.pdf
> brewers
> > 73,
> > Todd
> photoresist
> should
> Why
> >> is that?
> cover
> >> Jeff
