Homebrew PCBs
How to print Mirror Image
2013-01-20 by michael tenore
I finally Figured out a easy way to get a mirror image. I started with the Info from K4GMH
But my new CutePDF Writer Free Edition is different from the previous versions .
but here it is. below!!
73 Mike WB2LCW
How to Print Mirror Image with CutePDF Writer Free Edition !
1) From "Express PCB" or any other App or Program!
Select item to print ! > select "CutePDF Writer" as your printer !
2) I name my File , for Example ..... Board1normal.PDF  then Print !
3) Open "Adobe Reader"  > File >Open > Select  "Board1normal.PDF"
The image will appear on the screen.
4) In "Adobe Reader" > File > "Print" . Select  "CutePDF Writer" as your printer !
5) PRINT window opens.   Select  "CutePDF Writer" as your printer !
6)  "CutePDF Writer Document Properties" window opens. > Select  Advanced >
"CutePDF Writer Advanced Options" window opens. > Click the plus sign next to
PostScript options > At the bottom of the list it says "Mirrored Output No" >
Click the "No" > Change it to "Yes" > OK > OK > "PRINT".
7) Name New File " Board1Mirror.PDF" > Save !
8) In "Adobe Reader" > File > Open > " Board1Mirror.PDF". Mirror image now on screen 1
9) In "Adobe Reader" > File > Print  "Select you normal printer ( HP etc.)
10) Your printer will print the Mirror image of what you originally had !
