On Tue, Feb 5, 2013 at 8:21 AM, Tony Smith <ajsmith1968@...> wrote:
>> Dentist bits are 1/16". PCB drill bit shanks are 1/8". So you have to
> insert a 1/8"
>> diameter shank into a 1/16" hole. Does the ER collet accommodate this?
> You can't mix & match sizes, 1/16th bits in 1/16th collets, and 1/8th bits
> in 1/8th collets.
> Seems obvious, but using the wrong size means it doesn't grip properly.
> Damages the collet too. ER16 goes down to 1/32th, IIRC.
> You can use a 1/16th bit in a 1/8th collect (dentist bit in a Dremel) by
> slipping a piece of tube (maybe with a slit in it) over the bit to make up
> the different, that's what 'Boot's was referring to as the reducer, though I
> think he missed you're going the opposite way.
> The only way to use 1/8th bits in a dentist handset is to replace the
> collet. Someone with a lathe could make one for you easily enough, boring
> out an existing collet to 1/8th might be possible, but they're usually
> hardened. Well, good ones are.
> You can get what's called an 'emergency collet', basically a blank you drill
> out to the correct size.
> Tony
