Homebrew PCBs
relatively good prices
2013-02-14 by Rick Sparber
I can drive past Circuit Specialists  in Mesa, Arizona, almost every week.
They sell chemicals and photosensitive boards. I doubt they have the lowest
prices on the entire web but they are convenient and I pay no shipping.
Yesterday I was looking at their selection of boards. They had 3" x 5"
single sided boards for $6.64. That is 44.3 cents per square inch. But they
also had 4.6" x 6.6" single sided boards for $4.49. That is 14.8 cents per
square inch. The lower priced boards come from a variety of suppliers so I
figure they are getting rid of old stock. They sure have a lot of them.
http://www.circuitspecialists.com/pp114.html
Rick
Re: [Homebrew_PCBs] relatively good prices
2013-02-14 by Leon Heller
Photo-resist goes off after a few months, which could cause a problem
with old stock.
Leon
Leon Heller
G1HSM
2013-02-14 by Mitch Davis
> with old stock.
When making PCBs at home, I use Kinsten pre-sensitised board.  I
haven't had a problem with photoresist going off, because I seal the
bag tight after I've cut off as much as I need, and store it in a
lightproof box.  I haven't had luck with developer though.  It seems
that once it's made up into a liquid, it doesn't keep for more than a
few weeks.
(Re the Circuit Specialists prices, their prices are about the same
for blank stock as I sell professionally made double sided, routed
silkscreened board for, including shipping :-) )
Mitch.
RE: [Homebrew_PCBs] relatively good prices
Mitch,
Where do you have your boards made for that price?
Rick
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com] On Behalf Of Mitch Davis
Sent: Thursday, February 14, 2013 7:35 AM
Subject: Re: [Homebrew_PCBs] relatively good prices
> with old stock.
When making PCBs at home, I use Kinsten pre-sensitised board.  I haven't had a problem with photoresist going off, because I seal the bag tight after I've cut off as much as I need, and store it in a lightproof box.  I haven't had luck with developer though.  It seems that once it's made up into a liquid, it doesn't keep for more than a few weeks.
(Re the Circuit Specialists prices, their prices are about the same for blank stock as I sell professionally made double sided, routed silkscreened board for, including shipping :-) )
Mitch.
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
On 14/02/2013 14:34, Mitch Davis wrote:
> On Fri, Feb 15, 2013 at 12:32 AM, Leon Heller leon355@...
>  > with old stock.
> few weeks.
The NaOH developer I use (2 tsps per litre) lasts indefinitely.
Leon
Leon Heller
G1HSM
Leon,
I have some marked June 2011. I'll have to test it to see if it is ok. I did
not see a "use by" date on any of my packages.
Rick
On Behalf Of Leon Heller
Sent: Thursday, February 14, 2013 6:33 AM
> lowest prices on the entire web but they are convenient and I pay no
shipping.
> they also had 4.6" x 6.6" single sided boards for $4.49. That is 14.8
> cents per square inch. The lower priced boards come from a variety of
> suppliers so I figure they are getting rid of old stock. They sure have a
lot of them.
Photo-resist goes off after a few months, which could cause a problem with
old stock.
Leon
Leon Heller
G1HSM
I believe my home-use developer is Sodium Metasilicate Pentahydrate.
Mitch.
Re: relatively good prices
Three people have asked me where I got Sodium Metasilicate Pentahydrate:
On Fri, Feb 15, 2013 at 2:33 AM,  someone wrote:
> Hi Mitch,
> Could you please tell me where you get the Sodium Metasilicate Pentahydrate. I'm having a hard time locating some.
> Thanks
I believe it's what you get when you buy Kinsten DP-50 developer.
Here's an example:
  http://www.ebay.com/itm/170952538750
Mitch.
Re: [Homebrew_PCBs] Re: relatively good prices
2013-02-14 by Donald H Locker
Sodium metasilicate pentahydrate is also known as waterglass and sodium silicate. That stuff is available at many pharmacies and some farm supply stores.
Donald.
*Plain Text* email -- it's an accessibility issue
()  no proprietary attachments; no html mail
/\  ascii ribbon campaign - <www.asciiribbon.org>
> From: "Mitch Davis" <mjd@...>
> To: "Homebrew PCBs" <Homebrew_PCBs@yahoogroups.com>
> Sent: Thursday, February 14, 2013 10:48:13 AM
> Subject: [Homebrew_PCBs] Re: relatively good prices
> Pentahydrate:
> > Hi Mitch,
> > Thanks
> Here's an example:
> Mitch.
2013-02-15 by Russell Shaw
>>   >  with old stock.
>> few weeks.
I use 10g/Lt NaOH as *stripper*. What do you strip with?
I use Na2CO3 sodium carbonate as developer.
2013-02-15 by Mitch Davis
Curious.  This seems to suggest that the developer is Na2CO3:
  http://www.ebay.com.au/itm/130690362878
Mitch.
2013-02-15 by tda7000
I use the Na2CO3 Sodium carbonate (washing soda) for both developer and stripper.
For developing, I use a weak solution with warm water. For stripping, a stronger solution with hot water. Just don't mix them up!
> Mitch.
