Homebrew PCBs
Need advice for large PCB and sub-mini SMDs
2013-04-15 by william casselberry
I’m a relative noob trying to prototype a computer keyboard project where my
PCBs are about 12”x6”. They are single sided and have only 14 surface mount components but
these are really small. I would appreciate any advice from you guys with
experience with big boards and small components.
I have two substrates I am working with; .008" FR4 and
Pyralux. I am trying to do toner transfer using Office Depot “glossy text”
paper, but that paper shrinks about 1% when heated, so the toner is not
sticking properly in some spots and the Pyralux is actually wrinkling in the
laminator due to paper shrink.
More details about my project here:
https://geekhack.org/index.php?topic=40111
Thanks
Re: [Homebrew_PCBs] Need advice for large PCB and sub-mini SMDs
2013-04-15 by Dave Wade
On Apr 15, 2013 5:30 AM, "william casselberry" <wcasse@...> wrote:
> I�m a relative noob trying to prototype a computer keyboard project where
my
> PCBs are about 12�x6�. They are single sided and have only 14 surface
> Pyralux. I am trying to do toner transfer using Office Depot �glossy text�
> Thanks
I can't see the geekhack page, but if they are small smd devices with few
pins I would make carriers to allow them to go in normal IC sockets.
> Be sure to visit the group home and check for new Links, Files, and
Photos:
2013-04-15 by n0tt1@...
I think the root of the problem is the paper you are using.
The best paper I've used so far for laser transfer is "regular"
ink jet paper.  I.e., not heavy "photo" paper or the glossy stuff
either.  Try to get a few sheets from a friend and try it out rather
than spending $$ on a new package.
Charlie
On Mon, 15 Apr 2013 07:18:52 +0100 Dave Wade <dave.g4ugm@...>
writes:
> wrote:
> > I\ufffdm a relative noob trying to prototype a computer keyboard
> project where
> my
> > PCBs are about 12\ufffdx6\ufffd. They are single sided and have only 14
> surface
> guys with
> \ufffdglossy text\ufffd
> is not
> wrinkling in
> the
> > Thanks
> with few
> sockets.
> and
> Photos:
> Photos:
Re: Need advice for large PCB and sub-mini SMDs
2013-04-15 by ve7su
Yes, the root of the problem is the "paper" you are using. I have just recently found the best medium for toner transfer. It is Oracal 651 which is a vinyl sticker. It is available on ebay at a very reasonable price http://www.ebay.com/itm/12-x12-Gloss-Craft-Adhesive-Vinyl-Oracal-651-Silhouette-28-Colors-SAME-DAY-SHIP-/380452333884?ssPageName=ADME:L:OC:CA:3160
There is a YouTube "How to use" here http://www.youtube.com/watch?v=FtmJdCBjwXY
Every bit of the toner from your laser printer gets transferred to the copper foil using this stuff!
Jim
> Charlie
> writes:
> > project where
> > my
> > surface
> > guys with
> > �glossy text�
> > is not
> > wrinkling in
> > the
> > > Thanks
> > with few
> > sockets.
> > and
> > Photos:
> > Photos:
sorry about the link, - not secure
http://geekhack.org/index.php?topic=40111
the surface mount components are diode arrays - 1.5mm square with 7 pads.
2013-04-17 by wcasse
thanks missouri_ham and ve7su.
ink jet paper specific paper is difficult to find in any size other than 8.5x11 - my board is 11.8 inches. i will order a sheet or two of that 12 inch vinyl and let you know how it goes.
> Jim
2013-04-18 by ve7su
A tip when applying the Oracal 651 vinyl sticker to the paper.. especially with the large board you are dealing with... You will need to be careful you don't wrinkle the vinyl when sticking it to the paper before running it through your laser printer. I slowly start at one end and apply the vinyl to the paper at the same time I'm peeling off the backing of the Oracal. Three hands would help here! Once it's stuck to the paper, you will never get it off to smooth out any wrinkles so u must make sure there are NO wrinkles in the first place! Order a lighter colour of your Oracal. I use a bright yellow although the blue that's shown in the Youtube video works too. There is a transparent version available too but the "Vinyl Direct" company doesn't stock it. The transparent version would help when making double-sided boards. I've been told that this Oracal 651 product is used a lot by sign companies so scraps of it may be had for free from one of these shops. Anyway, let us know how this works for you.
Jim
> > Jim
2013-04-19 by D
I get 100% toner transfer using HP inkjet transparencies.  An added advantage for transparencies is that you can observe toner melting if you use the iron method.
BR
Dennis
2013-04-19 by David
Jim,
Sorry to butt in on this, but why not feed the vinyl through the printer with its original backing, then there is no risk of wrinkling, or am i missing something? I've tried this before but with a different type of vinyl and it fed through well.
David
> Jim
> > > Jim
2013-04-19 by ve7su
David,
Yes, you can do that but when u have a board that's much smaller than 8.5" by 11" (the size u would have to cut the vinyl for the laser printer), it's a waste of the Oracal 651. The easiest way to avoid wrinkles, other than ur suggestion, is to mark one end on the paper where the vinyl should go, cut a 1/2" or so strip of the vinyl paper backing off the one end, then lay the 1/2" exposed vinyl over your marks, use a flat surface to smooth the vinyl down as you slowly pull the vinyl paper backing off.
Jim
--- In Homebrew_PCBs@yahoogroups.com, "David" <dgh2259@...> wrote:
> Jim,
> David
> > Jim
> > > > Jim
2013-04-20 by David
Jim,
Thanks for that, wasn't thinking the matter through, I should have recalled when I used the "press 'n peel" for smaller pcb's I used to print out on A4 plain paper then cut a piece of p n'p a cm or so bigger all round stick it over the print with bits of masking tape and re~print, maybe worth a try to do the same with the vinyl without taking the backing off, most printers will take pretty thick card so shouldn't present a problem.
David
> David,
> Jim
> --- In Homebrew_PCBs@yahoogroups.com, "David" <dgh2259@> wrote:
> > Jim,
> > David
> > > Jim
> > > > > Jim
2013-04-20 by tda7000
Which transparencies are those? (Do you have the HP product number?)
I would never dream of trying inkjet transparencies as I would expect them to completely melt in the printer's fuser. Did this myself once with some cheap transparencies that I suspect now were actually just sheets of plastic. Had to strip down my printer and carefully remove all the melted crap.
> BR
> Dennis
2013-04-21 by D
I bought them in bulk.
5962-0400
HP INK JET
CLEAR REM TOP STRIPE
Transfer pictures here: http://groups.yahoo.com/group/Homebrew_PCBs/photos/album/793762311/pic/2135995623/view?picmode=&mode=tn&order=ordinal&start=1&count=20&dir=asc
I use a Lexmark Optra E+ with OEM and generic toner.
I suggest ironing a sample with a paper towel over it to see if it melts.
I've tried several injket transparencies.  On CompUAS brand, toner was nice and dark, but it didn't transfer as well.
BR
Dennis
2013-04-21 by ve7su
David,
The trouble with that is that the paper backing on the vinyl is very thick compared with the vinyl itself. This could lead to problems when passing through a laminator and with trying to transfer heat through to the toner and to the PCB. This is especially true when doing a double sided board.
Jim
> Jim,
> David
> > David,
> > Jim
> > > Jim,
> > > David
> > > > Jim
> > > > > > Jim
2013-04-27 by timgmorris@att.net
I have used contact-brand standard shelf liner from kmart ($5 for 12"x24' roll) with good results (8 mil traces). I left comments about the process in the database, if interested...
> David,
> Jim
> > Jim,
> > David
> > > David,
> > > Jim
> > > > Jim,
> > > > David
> > > > > Jim
> > > > > > > Jim
2013-04-27 by wcasse
i tried the Oracal 651 and got pretty good results, but found that my cheap laminator is not as good as my cheap iron. resolution down to about 7 mil. after running out of Oracal, i ran down to the home depot and picked up ... contact-brand (clear) shelf liner (kmart has a better price than the depot). results were better than any paper i have used so far, but not as good as the Oracal; resolution to about 10 mil. i really like that there is no residue on the toner. i might try parchment paper next.
--- In Homebrew_PCBs@yahoogroups.com, "timgmorris@..." <timgmorris@...> wrote:
That's good to know. I did notice on long small traces that i would get distortion but chalked this up to my iron being too hot. I tried using a cheap laminator, but i have a brother HL4040cdn, so a stock laminator doesn't get hot enough. I tried standard Reynolds parchment paper also, but I was never able to get any transfer using iron or laminator. I read about the oracal and had some old contact paper to try. It worked better than water soluble paper! I bought some clear stuff from kmart and the results were the best so far. I've since moved on to cheap photo-resist and LOVE it... unfortunately, they are only 6x8 sheets, so wouldn't work in this case.
