Homebrew PCBs
registration pins
registration pins
2013-06-03 by johannes_taelman
I'm ramping up doing home pcb production using photosensitive pcb with a CNC machine contour-laser-plotting.
Single side works great, now I want to move on to double-sided pcb. One of the advantages of CNC-contour-laser-plotting is that the artwork-to-machine offset is perfectly reproduceable, so I was thinking to predrill 3mm mounting holes in my eurocard-size pcb stock using a drill template.
So I need to mount registration pins on the CNC machine bed. I wonder what would be good pins for this purpose. Ideally something that can be tensioned while maintaining center. Maybe similar to the pushpins used to hold a PC CPU heatsink. Or is just a round 3mm pin good enough? Ideas?
I'd like to use the same holes as guides for solderpaste stencil creation and application.
thanks,
johannes
Re: [Homebrew_PCBs] registration pins
2013-06-03 by Mitch Davis
On Mon, Jun 3, 2013 at 9:54 PM, johannes_taelman
Hello Johannes,
Have a look at the Stencil8 system:
  http://www.hoektronics.com/2012/10/27/super-simple-smt-stencil8/
The genius of the stencil8 system lies in the standardised 10mm pitch
for the mounting holes.  You could drill the bed of your bed on a 10mm
grid and do stencil8 right there and then.
Many of my PCB customers are using stencil8, and they and I really
love it.  When I do panelisation for them, they usually accept my
offer to give them a stencil8-compatible tooling rail.
For those of you who want to use stencil8 but don't have a mill, a
customer of mine sells pre-drilled mounting blocks:
  https://www.tindie.com/products/arachnidlabs/pcb-fixture-block-for-solder-paste-stencilling/
Johannes, you could make a similar block, which would let you take
stuff from your CNC mill to the workbench for doing stenciling.
Hope you like this idea!
Mitch.
Re: registration pins
2013-06-04 by johannes_taelman
Ok, so just 4 cylindrical dowels are good enough for pcb and stencil registration.
I'll try lasercutting acrylic sheet for this purpose, a lot cheaper than milled aluminum. To compensate for non-cylindrical lasercut holes, multiple lasercut sheets could be stacked. Still probably not as tight as machined aluminum, but maybe good enough.
> Hello Johannes,
> Mitch.
