Homebrew PCBs
tracing paper, laser and photoresist
2013-11-08 by Kerry Koppert
I have been using tracing paper (Vellum?) and a laser printer to produce
transparencies for photoresist. I have some good results, but the large
dark areas tend to be less than opaque having a speckled appearance
which tends to be reproduced on the copper. I was reading about some
spray cans which supposedly darkens the toner pattern (Toner Aide and
Casey's toner darkener). Unfortunately I can't find a supplier in New
Zealand and if I could it would probably be around $30-$40 a can.
However they appear (from their MSDS sheets) to be a mixture of solvents
sprayed from a can so I mixed some Acetone and Ethyl Acetate and sprayed
this on the transparency from a small mister spray bottle I had. It
worked, although the vellum curled up a little.
Re: [Homebrew_PCBs] tracing paper, laser and photoresist
2013-11-08 by James
I have read that Toner Darkener is basically a matt clear acrylic, or even hair spray, from this thread...
http://forums.mrprint.com/archive/index.php/t-339.html?s=359ca146435e3d18bd6e16c71e1c7e0f
" you can spray the laser output with Krylon Matte Finish Acrylic and if you find that still too costly, you can purchase AquaNet Hair Spray that has been relabeled as a "commercial" toner darkener."
I tried some clear acrylic rattle can from bunnings a few weeks ago, it did make it darker, but I don't know if it's worth the trouble (I didn't actually try exposing it yet).
On 08/11/13 13:01, Kerry Koppert wrote:
O have some good results, but the large
RE: tracing paper, laser and photoresist
2013-11-08 by <twgray2007@...>
You might try Krylon Crystal Clear Acrylic Coating 1303. It claims to be UV invisable, and it does darken the print up, but, I'm not sure it is worth the extra step. I've had better luck with just doing 2 prints on heavy tracing paper 90#, carefully aligning them both on a light table, and using the the "double" for the mask. This works well...the vellum or heavy tracing paper is nearly UV invisable.
RE: Re: [Homebrew_PCBs] tracing paper, laser and photoresist
2013-11-08 by <andrewm1973@...>
> <SNIP>
I have some of the toner darkening stuff. It is all solvent
as it leaves no residue after spraying.
It definitly works at darkening ground planes etc.
Still not as dark as the inkjet though.
Re: Re: [Homebrew_PCBs] tracing paper, laser and photoresist
2013-11-09 by Jan Kok
A couple of thoughts:
1. Maybe the toner darkener could be sprayed onto copper clad after toner has been transferred to the copper clad. That might work as a substitute for Toner Reactive Foil to seal up the cracks and pinholes in the toner on the board. The toner darkener would have to be solvent only. If there is a residue, it might interfere with etching.
2. On the other hand, perhaps laminating Toner Reactive Foil onto the pattern printed on vellum would improve the darkness of the patterns on the vellum, for use as a photomask!
