On 17 Nov 2013 18:47:05 -0800, you wrote:
>Just tried using the green foil - first try (one pass thru laminator) didn't transfer much. 8-10 passes gave 100% transfer, but broadened the traces. Is there a suggested happy medium??
I use two passes, generally results in 100% transfer. However, I've
had runs where the foil absolutely does not adhere, period. That can
mess up a board. Still, the boards are better with than without.
Harvey
