RE: [Homebrew_PCBs] RE: 10W ~380nm UV LED for exposing Riston & other negative film photoresists
2013-11-18 by Boman33
Interesting thought: If the laser focal point is not needed to very short, the required mirror curvature is very slight. It would be easy to bend a plastic front surface mirror, maybe even a thin glass one. It is easier to bend it into a convex shape so the narrow laser beam section could be expanded to match the wide section and then focused normally. To get a as clean beam as possible I have done the opposite to the beam expander: Using microscope objectives, the beam is focused on a very small pin hole. Any secondary beams or distortions does not get through the pin hole. The beam is collimated afterwards with a matching second objective. High rigidity mounting and accurate alignment is required. Bertho
From: Cristian Sent: Monday, November 18, 2013 08:05 At 12:11 PM 18-11-13, you wrote: > > >I do not think you want to use an aperture to get a round beam since >it will waste power. Expander-round aperture-focusing is the easy way for an amateur. > As you suggested, cylindrical lenses will allow you to selectively > focus X & Y independently. > >Mirrors curved in one plane will also work. > >Bertho Curved mirror will do the job, but I think is hard to find. If you know a cheap 'one piece' producer, let me know, please. I'd like to round-up a red laser. Cristian
