Homebrew PCBs
Any opinions/experience on Epson Stylus 3000 for positives
2013-11-23 by <beefyzee@...>
I've got a chance at an old Epson Stylus Color 3000 (not the R3000). This is a big A2 printer.
I've been told the print heads are blocked. The printer has been in storage for some time. It's cheap but I'm also wondering if I'll end up chucking the printer in the bin.
I've been hearing hear and there these are a good printer for photo positives, but I don't know if that is with $500 RIP software. I'll just be running it with the standard Windows driver.
Keith.
Re: [Homebrew_PCBs] Any opinions/experience on Epson Stylus 3000 for positives
2013-11-24 by Russell Shaw
> big A2 printer.
> in the bin.
The ink is not solvent ink, so there's a chance of unblocking by pulling out the
head (not too hard with some practice, but a teaser at first, maybe see
something on utube), and wiping the head surface with paper towel soaked with a
suitable cleaner (i use nifty, but a window cleaner chemical would be good too).
<http://www.hillsgroup.net.au/CatalogueRetrieve.aspx?CatalogueID=99748&ProductID=5533742>
Putting in an old cartridge filled with the cleaner and doing lots of head-clean
cycles can work too.
If all else fails, you can soak the head in a cheap ultrasonic cleaner. I've
done that on my 10+ year old epson stylus 400. Make sure it's properly dried
before testing in the printer.
If you're in the melbourne area, i'll consider taking it if you want to bin it.
2013-11-24 by David Pickering
Hi
It depends what your paying for it, I personally wouldn't give anything for it, just tell them your willing to take it off there hands to save them dumping it.
In general Non working printers are not worth a toss,In fact even working ones unless there top end of the market and only a few months old don't get much if anything.
 However to you If it is a no go then grab the motors gearing etc out of it and bin the rest.
I got two here you can have free, if you want one or both and can collect your welcome
One is the old reliable Epson C62  which I had plans to convert for direct printing to PCB but never found the time to do, It only ever needed ink which for that model is cheap as chips and the other is a newer model HP, cant remember the model its in the spare bedroom.
Hope my sound advise is heeded lol
Dave
BS-TECH- UK
> big A2 printer.
> in the bin.
RE: Re: [Homebrew_PCBs] Any opinions/experience on Epson Stylus 3000 for positives
2013-11-24 by <beefyzee@...>
Thanks Russell,
I am in the Melbourne area actually, but if I couldn't get the printers to work I'd pull all the motors, etc out of them to put towards a little PCB cnc drill.
I've been doing a lot of research on Google & Youtube about head cleaning, cartridge flushing, cartridge filling & avoiding air locks. I've got a CISS system now, but before that I used to refill the cartridges and often had airlock problems. I solved it by tying the cartridges to a thick peice of wire and centrifuging them on an electric drill running at high speed LOL. Crude but effective.
Thanks for that link to the cleaner spray.
Keith.
> big A2 printer.
> in the bin.
Thanks Dave,
I agree about non-functional inkjets being just about a throw out item. Thing with this particular model of printer is it seems to get good reports for it's ability to print high density, which is what I want for single sheet photo positives. Just read on a forum yesterday that these old "workhorse" printers print more densly than their newer successors. So I'm mainly wondering if anyone here has had the actual experience too.
The guy has two of them and said he'll sell them for $40 each. I might see if he'll do the two for $60.
Refurbished models of these seem to be about the $700+ mark, and just general working ones about $250-$300. They still seem to be in demand by people doing silkscreening and photo positive stuff.
Keith.
---In Homebrew_PCBs@yahoogroups.com, <satdaveuk@...> wrote:
Hi
Dave
BS-TECH- UK
> big A2 printer.
> in the bin.
2013-11-24 by AlienRelics
Realigning Epson heads requires a bit of factory-only software (possibly available online, let's not talk about that here) and is a real pain.
I have rescued a -lot- of Epson printers. The only time I removed the heads for cleaning, it was a nightmare.
I don't buy any fancy cleaning things, I don't use a syringe to force liquid through the heads (bad news!). I wrote this up:
http://www.polyphoto.com/tutorials/PrintHeadCleaning/EpsonCleaning.html
The Epson 3000 is still going for a lot of money because of the dense ink, the built-in bulk ink system, and because it can print on 17x22 paper or 17 inch wide rolls.
I just cleaned one up that had badly clogged heads, had sat for years. I filled halfway empty cartridges with the cleaning solution as described on the link above, then follow those instructions. The most important part is patience.
Steve Greenfield AE7HD
--- In Homebrew_PCBs@yahoogroups.com, <beefyzee@...> wrote:
>  Thanks Dave,
>  Keith.
RE: RE: Re: [Homebrew_PCBs] Any opinions/experience on Epson Stylus 3000 for positives
2013-11-24 by <andrewm1973@...>
Bugger,
If I wasn't a whole day of driving to get to Melbourne
I would grab the other one.
> beefyzee / Keith wrote:
> <SNIP>
Hi
Dave
BS-TECH- UK
> big A2 printer.
> in the bin.
2013-11-25 by <beefyzee@...>
Thanks for that Steve,
I never realised about a built in bulk ink system, I'd better look at the manual to learn more.
Well there may be a little catch after all. I just got an offer of $60 for the two printers accepted BUT there might not be any cartridges in them. The guy is going to check when he gets home. Now to see if empty cartridges are available for these printers and at what cost. I'm hoping I can get one working printer out of the two, but of course two working printers would be great LOL.
I pretty much just want to fill every cartridge with black photo postive super opaque ink so I've got the ultimate printing machine for positives. Bit of an overkill as far as the physical size goes but getting that super opaque photo positive is the holy grail of the UV method.
Keith.
> Thanks Dave,
> Keith.
2013-11-25 by <andrewm1973@...>
Keith,
One thing I did notice about the Epson 3000 is that
it only has a resolution of 720 DPI.
https://www.epson.com.au/products/inkjet/stylusC3000_specs.asp
This is probably fine for screen printers phototools
It might be a bit marginal for a 0.4mm QFN
> Thanks Dave,
> Keith.
> <SNIP something about EPSON 3000>
RE: RE: RE: Re: [Homebrew_PCBs] Any opinions/experience on Epson Stylus 3000 for positives
2013-11-26 by <beefyzee@...>
Thanks for pointing that out. I had to Google QFN, that went straight over my head LOL. Hopefully I'll get by with the resolution for quite some time. I've accumulated four other old Epson inkjets during the course of this thread and the best two have better resolutions.
I'm starting with the cheapest one and completely flushing all the ink out of the colour cartridges. When I get them fully dried out I'll fill them with proper black film opaque ink.
I love these old Epson printers. Cheap, piezo print heads, free 3rd party application available for resetting cartridges and overiding ink pad counter, etc. I've found service manuals for every one so I take them apart if need be.
Jus picked up ONE only Epson Stylus Color 3000 yesterday. This guy is Chinese from the Russian border and absolutely basic communication is futile depite him speaking English. When he answers "yes" to a question, it can just as easily mean "no". Turns out he was only selling one printer MINUS the black cartridge. Got the printer for $40 with 3 empty colour cartridges, and seemingly blocked print heads which I expected. Spent another $25 on a couple of black cartridges from the States.
This is a monster of a printer and seems to have professional functionality. I've heard nothing but great reports for it's ability to print great film positives. It's even got a print setting for film. Hopefully I get it working.
Keith.
---In Homebrew_PCBs@yahoogroups.com, <andrewm1973@...> wrote:
Keith,
> Thanks Dave,
> Keith.
RE: RE: RE: RE: Re: [Homebrew_PCBs] Any opinions/experience on Epson Stylus 3000 for positives
2013-11-26 by <andrewm1973@...>
Keith,
I can't actually read your message apart from the first two lines.
This new Yahoo interface is awesome.
Anyways QFN/DFN packages are the new _EASY_ standard
package. There are a lot of fun things that only available in
QFN/DFN or smaller.
Things with WS and CS in the package name are the new
hard/small.
Keith.
Keith,
> Thanks Dave,
> Keith.
