Homebrew PCBs
Pace Desoldering unit
2013-12-05 by dgminala
I've been given an old Pace PPS-100A desoldering unit, but without a handpiece.
Does anyone have any documentation for this unit, or at least know which handpiece(s) were meant to be used with it? I have downloaded all of the catalogs and manuals that I can find on the Pace desoldering units, but none of them mentions the PPS-100A system.
It doesn't look to be very complicated inside, but it's pretty useless without a handpiece. I *think* that the handpieces had 115VAC heaters because of the 115VAC connectors on the front of the unit, but the vacuum connector appears to be a special connector. The handpiece vacuum hose needs a special twist-lock connector that none of the more modern systems have.
Any info or documentation is welcome.
Dave M
Re: Pace Desoldering unit
2013-12-06 by Paul Alciatore
Have you tried contacting Pace?
http://www.paceworldwide.com/contact-us
They probably supply repair parts. At least they should, considering
the outrageous prices they charge.
You may be better off just buying a new station from a less expensive
maker. I have a Tenma soldering station that works every bit as well
as my older Weller.
Re: [Homebrew_PCBs] Re: Pace Desoldering unit
2013-12-06 by David Bobb
I would agree with Paul on getting a different station. We had those Pace rework stations at work, and were constantly having to replace the glass tube in them.
as my older Weller.
2013-12-07 by <dgminala@...>
Yes, I contacted Pace and APE. APE carries spares for older Pace equipment.
A fellow at Pace sent me a copy of the manual for the PPS-100A power unit. I have found the part numbers for all the stuff I need to make my handpieces work with thit, but so far, they all seem to be unobtanium from Pace, APE, Ebay, Google, etc. I think my best shot at making the vacuum hose fitting is to get some vacuum fittings from an auto parts store and making something that will work.
The reason I'm trying to make this thing work is that it was given to me, and I have a couple handpieces that will work with it if I can make the vacuum connection between them. That should cost a lot less that a new desoldering station. I already have a station that works well, and if I can make this one work, I'll have a second one for my other bench. That way, I won't have to move all the paraphernalia from one place to the other when I need to change work spaces. I've worked with Pace, Hakko and Weller equipment for many years, and am familiar with the strengths and weaknesses of them all. Pace makes good stuff, so I'm not afraid to keep this guy around.
Dave M
as my older Weller.
