Homebrew PCBs
pitted surfaces on vinyl-transferred images
2014-01-02 by <seeifyoucanmeetme@...>
Hi everyone,
I've been using the toner-transfer method with vinyl for some time now, but I'm consistently running into a pitting issue across all of my boards.
On large polygons/planes, and even on fine traces, pits and weathering appear on the surface of the copper. I've added an image in a link below:
https://drive.google.com/file/d/0B4daAsGd6n41aGRRY3QyeVlaS28/edit?usp=sharing
Where the image appears clean, I covered that surface with a sharpie in addition to the toner.
My printer is a Samsung ML-2525. 1200 DPI. (Toner set to transparency and max darkness setting.)
Vinyl is from a local sign retailer.
Currently, I'm not sure if the pitting is from insufficient toner, or from the vinyl, although the vinyl pretty-much always comes out perfectly clean from the transfer.
I picked up some laser foil to try to recoat the board, though I only used it once as I watched it immediately flake off when the pcb entered the etchant bath.
Etchant is cupric chloride.
Thanks for any advice!
Re: [Homebrew_PCBs] pitted surfaces on vinyl-transferred images
2014-01-02 by chuck adams
On 01/01/2014 11:52 PM, seeifyoucanmeetme@... wrote:
> Hi everyone,
> my boards.
> <http://groups.yahoo.com/group/Homebrew_PCBs/post;_ylc=X3oDMTJxNm9oOW4wBF9TAzk3MzU5NzE0BGdycElkAzQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBG1zZ0lkAzMyOTk1BHNlYwNmdHIEc2xrA3JwbHkEc3RpbWUDMTM4ODY0NTU2Ng--?act=reply&messageNum=32995>
I will try to help.  First I use Hammermill Laser Gloss paper, so my
technique
may be different.
Several things that I have found that help prevent pitting.
1.  I preheat board to 40 deg C before running through a laminator
with paper and toner then applied to the board and repeat through the
laminator
until the board and paper comes out at 90 deg C.  I use a cheap
IR thermometer to read the temp.
I soak paper off at cool to luke warm temp.  Do not exceed 40 deg
C at which the toner softens or even melts.  Do not soak for too
long a period as this also seems to cause pitting.  Because I am using
paper and toner I carefully rub off after soaking in water about 5 mins
and do not use a lot of pressure.  Just a gentle rubbing using the
thumbs to roll off the paper.  I can do a video if more is needed.
2.  I am using Hydrogen Peroxide and Muriatic acid bath (2 parts HP to
1 parts HCl).  I do not heat above 100 deg F and only if the lab is cool
around 60 deg F.  Do not leave in bath more than necessary to remove
all copper between traces.
You do not say if the cupric chloride is heated.  The reaction is also
exothermic and may cause the temperature to rise and soften the
toner.
Just a few ideas for you to investigate.  It took me a couple of
boards to find the right combo.
And sometimes you might get what I call the planetarium effect
with small pits that look like star fields in the ground plane when
board is held up to
the light (for single sided boards).
Here is a photo of a board using 0.5 oz FR-4 board.
http://www.k7qo.net/k7qo-photo-0044.jpg
FYI
chuck, k7qo
2014-01-02 by Harvey White
On 01 Jan 2014 22:52:45 -0800, you wrote:
>Hi everyone,
If it's the green TRF from pulsar, then run it through twice on the
highest setting.  The pigment should transfer completely, leaving the
foil carrier completely clear where the pigment has been transferred.
After that you can use the sharpie.
You have (perhaps) insufficient toner, but the usual pits from the
transfer.
If you used a metallic foil from a craft shop, no idea of how well
that'll work under etchant.  The green stuff stands up to ferric
chloride, peroxide/HCL, and persulfates.
Harvey
2014-01-09 by <seeifyoucanmeetme@...>
Thanks for the tips everyone!
I picked up some "Fellowes Heat Transfer Color Foil" and did a side-by-side comparison. The results are strikingly better with the laser foil. (I'm putting the foil through for about 2 passes through the laminator after the pattern has been transferred from the vinyl.) I have an image below at:
http://www.flickr.com/photos/77947059@N05/11792644356/
I will probably look into pulsar paper when my supply of heat transfer foil runs out; but for now, this material is working really well!
