Reducing CuCl etchant foaming
2014-02-16 by Philip Pemberton
Hi there, I've been having problems with my CuCl etching bath (and to a lesser degree my FeCl etching bath). When I turn the air pump on, the etchant starts to foam -- if I have the air valve set above a few percent, it'll foam over the top of the tank in a few minutes. Acid molarity was around 2.3M last time I checked, with a specific gravity of around 1.3. Does anyone know of a way I could reduce the amount of foam being produced? Reducing airflow only slows down the process, it doesn't stop it; the foam seems also seems to be quite resistant to being dispersed and unusually long-lasting. The foam I get when the FeCl tank is being aerated too quickly usually disperses inside a minute - this stuff takes a good half hour to revert to a liquid state. Thanks, -- Phil. ygroups@... http://www.philpem.me.uk/
