Double Sided Boards w/ Laminator
2014-04-13 by Mike
Hello,
What methods are being used for successful toner transfer to a double sided board using a laminator?
I've tried several different methods without much success. Keeping the two toner transfer sheets aligned to the two PCB sides while going through the laminator has been difficult at best. Single sided PCBs are okay with the laminator.
I'm using Techniks "Press n Peel" blue sheets as the medium for transferring the toner to the PCB.
Mike, K4GMH
Mike, K4GMH
