Homebrew PCBs
Yahoo problems again
2014-05-11 by Boman33
Yahoo changed something so now the sender’s name does not show up in the “From” line. See below:
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
Sent: Saturday, May 10, 2014 21:17
Subject: RE: [Homebrew_PCBs] Punching small PCBs, Issues using thin PCB material?
That should work fine.  Just do not have any runners next to the edge.
I have used 10mil and thinner FR4 making PCB that were 3 x 3mm.
I laser cut the PCB for the very small PCBs.
Bertho
Sent: Saturday, May 10, 2014 20:31
Subject: [Homebrew_PCBs] Punching small PCBs, Issues using thin PCB material?
I have a project idea that would require hundreds (possibly thousands)
of very small PCBs, each one being a circle approx. 1/2 inch in
diameter. Does anyone know if it would be possible to punch them out
of thin FR4 with a punch press? That is, use the material that is
normally discarded when punching out a hole.
Aside from that, what (if any) are the issues with using thin (0.010"
- 0.030") PCB material in general?
-p.
[Homebrew_PCBs] Yahoo problems again
2014-05-11 by casy_ch@tbwil.ch
I do not know what you are talking about Yahoo.  See your message header
which just came in.
Jean-Claude
-------- Original-Nachricht --------
Betreff: 	[Homebrew_PCBs] Yahoo problems again
Datum: 	Sat, 10 May 2014 21:46:23 -0400
Von: 	*'Boman33' boman33@... [Homebrew_PCBs]
<Homebrew_PCBs@yahoogroups.com>*
Antwort an: 	Homebrew_PCBs@yahoogroups.com
An: 	<Homebrew_PCBs@yahoogroups.com>
Yahoo changed something so now the sender\u2019s name does not show up in the
\u201cFrom\u201d line. See below:
*From:*Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
*Sent:* Saturday, May 10, 2014 21:17
*To:* Homebrew_PCBs@yahoogroups.com
*Subject:* RE: [Homebrew_PCBs] Punching small PCBs, Issues using thin
PCB material?
Bertho
<https://groups.yahoo.com/neo/groups/Homebrew_PCBs/conversations/messages/33269;_ylc=X3oDMTJxZDdvbDNyBF9TAzk3MzU5NzE0BGdycElkAzQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBG1zZ0lkAzMzMjY5BHNlYwNmdHIEc2xrA3JwbHkEc3RpbWUDMTM5OTc3MjgwNg--?act=reply&messageNum=33269>
Re: [Homebrew_PCBs] Yahoo problems again
2014-05-11 by Malcolm Parker-Lisberg
Blame it on the Spammers, they have done it so they can't harvest email addresses.
I use the old web based version of Yahoo and can see the senders email address on the original message. The one you can right click to open an incoming email in a new page.
Malcolm
I don't suffer from insanity I enjoy it!
Mene, mene, tekel, upharsin
The writing is on the wall.
Ha-ktovet al ha-kir
On Sun, 5/11/14, 'Boman33' boman33@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
 Subject: [Homebrew_PCBs] Yahoo problems again
 Date: Sunday, May 11, 2014, 2:46 AM
       Yahoo changed
 Issues using thin PCB material?  That should work
 edge.I have used 10mil
 and thinner FR4 making PCB that were 3 x 3mm.I laser cut the PCB
 for the very small PCBs.BerthoFrom: Homebrew_PCBs@yahoogroups.com
 using thin PCB material? I have a project idea that
 in
 them out
 that is
 thin (0.010"
 -p.
RE: [Homebrew_PCBs] Yahoo problems again
Thanks for following up.
When I click “Reply” it shows “From” as Homebrew_PCB@yahoogroups.com
That is not very useful!  The senders name used to be seen after the “From”
See the header below.
Looking at your email header I can see my name properly displayed.  Presumably the change Yahoo made might only show up on some email programs.  I have been using Outlook for years on Windows 7-64.  What are you using?
Bertho
Sent: Sunday, May 11, 2014 02:11
To: Homebrew_PCBs@yahoogroups.com >> "Homebrew_PCBs@yahoogroups.com"
I do not know what you are talking about Yahoo.  See your message header which just came in.
Jean-Claude
Betreff:
Datum:
Von:
'Boman33' boman33@... [Homebrew_PCBs]  <mailto:Homebrew_PCBs@yahoogroups.com> <Homebrew_PCBs@yahoogroups.com>
Antwort an:
An:
Bertho
