Homebrew PCBs
success at last over exposure/developer issues
2014-09-05 by mattmoose1969@...
Glad to report that I've had some significant success by changing the UV board type and the developer.
I was experiencing incomplete removal of exposed photoresist layer, when using a combination of CIF's AA16 board (RS 159-6057) and sodium metasilicate universal developer (RS 690-849). Despite a wide range of exposure times and plenty of time in the developer, there was always a fine and laterally-patterned residue of photoresist that refused to dissolve.
After a long chat with Mega UK, they kindly sent me a couple of complimentary Microtrak (mfr = Bungard) pre-sensitised boards to try, and recommended using their Seno 4006 (Mega 600-010) concentrated developer at 1:9 dilution rather than the default 1:19. I also laser printed the artwork onto some LaserStar film using a humble 600dpi HP CP1215 in mono mode, which gave adequate but not quite 100% opacity.
A 5 minute exposure in an LV202E UV box, followed by 2 ~ 2.5 minutes developing in the 1:9 mix, resulted in a very satisfactory etch. Traces of less than 6mil were reproducible, where ground plane polygons had been squeezed very thinly between tracks and 0805 pads. :)
Conclusion:
* This combination is problematic: CIF AA16 (RS 159-6057) + developer RS 690-849, at least at the advertised dilution
* This combination works: Microtrak (Mega 03-5108-1) + developer (Mega 600-010 @ 1:9 dilution)
Next steps:
I might try another CIF board, but develop it in double strength RS 690-849 developer.
Many thanks for everyone's help and support!
Matt
Re: success at last over exposure/developer issues
2014-09-17 by fred27murphy@...
I also get great results with Bungard boards. I used to use 1:9 metasilicate but have now switched back to 1:19 as that works fine. It can take a while to get perfect results but when you do you can then get really consistent results.
Some tips from me (not that you need them now but others might):
It's almost impossible to overdevelop using metasilicate. Try leaving it for 10 minutes to rule out underdeveloping. (3 minutes should be plenty though.) Rinse thoroughly.
I found a good way to check whether it's exposure / developing / etching that's causing the problem. Have one part of your test PCB completely wiped clean of the etch resist using meths or acetone. Problems here and it's got to be the etching. Have another part that you really expose by giving it 10 minutes under UV with no transparency. The rest of the board should still have the protective layer on at this point. Then do the usual exposure test by exposing the rest of the PCB for different times. Problems with the super-exposed area mean it could be the developer but it won't be the exposure.
2014-09-19 by mattmoose1969@...
Hi Fred,
That's a really neat diagnostic idea which I'll try next time I'm working with the chemicals. I'd like to build in techniques such as that in order to make it easier for anyone to carry on where I left off.
I'll try the more dilute developer mix with a Bungard board next time. The 1:9 mix worked frighteningly fast, and I saw that it was slowly removing some of the (supposedly) unexposed areas probably due to imperfect artwork opacity.
Thanks
Matt
